Installed 2" lift - now have a vibration/noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mxracer244, Dec 25, 2015.
  1. Jan 18, 2016 at 5:41 PM
    #101
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    tons of "good" info here, thanks guys.
  2. Jan 26, 2016 at 9:04 PM
    #102
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    I took a 2.8l vr6 gti bored out to 3L 11:1 compression, 268 cams, head work balance/blueprinted bottom end, built transmission with quaife lsd into VW for a timing chain tensioner issue and they fixed under warranty. Why, because the motorwork that was done had zero to do with faulty factory parts not related to mods done. Aussie just being an ass for the sake of it in this thread. He neither works for or represents toyota, yet speaks as if he has some apparent knowledge of how toyota operates as well as blatantly says he turns down warranty work if a cars been modified.
    Hell even audi covered my A6 UCA's under warranty when the car had been on air ride for sometime. Why, because their UCA's are shit and fail regularly on stock cars. Could they have denied the claim, quite possibly, but seeing as how the dealer liked my business and my money they did what was right.
    A needle bearing issue that exists as a tsb on stock vehicles, isnt a denier for being lifted, when the dealer sells lifts. This is a rather simple issue. Its not like someone put a big turbo on a car and roasted the clutch.
    Tacogram likes this.
  3. Jan 26, 2016 at 10:02 PM
    #103
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    So after reading 125 posts, note to self; if I'm planning a lift, complain about a vibration issue and have the dealer service the faulty bearing (under warranty) BEFORE doing the lift.
  4. Jan 27, 2016 at 4:01 AM
    #104
    mxracer244
    mxracer244 [OP] Well-Known Member
    Michael
    Quad Cities
    2016 TRD Sport DCSB
    If that is what you took from the 125 posts on this subject then you should probably re-read the thread. Complaining to your dealer about a problem that hasn't occurred yet won't win you any favors from them. My situation took place after the lift kit and the problem existed. They stepped up and took care of the problem as many other dealers have done for a defective part.
    James_Bond likes this.
  5. Jan 27, 2016 at 5:25 AM
    #105
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    So you don't know if you have the "problem", but you want them to replace a part without being able to verify the issue is present so that you can put a lift on that may have the exact same issue after the repair? Sounds like a solid, well thought out plan plan. While you're there, have them add some missiles to your truck at the same time, Bond, James Bond. :bikewheelie2:
  6. Jan 27, 2016 at 7:15 AM
    #106
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    Yes, pretty much. It's a shame that Toyota is selling trucks with parts they know are defective. My understanding is that the bearings that they are installing in the TSB are different from those that came with the whole assembly... Correct me if I'm wrong. :)
    Oh and a couple of Tommy guns behind that massive grill please. :thumbsup::quickdraw:
  7. Jan 27, 2016 at 7:51 AM
    #107
    mxracer244
    Michael
    Quad Cities
    2016 TRD Sport DCSB
    Yes the bearings are different but the dealer isn't going to fix a problem that doesn't exist. Keep in mind that not all trucks are affected with the vibration after a lift. Some lift their trucks .85 with zero problems. The higher you lift the more chances you will have with vibration issues due to the bearing IMO.
    I guess it isn't good that Toyota is still selling trucks that have this issue but again very few have this problem without a lift kit installed. It would be a bigger issue if Toyota doesn't fix the problem on a vehicle after the problem happens. You will need to have the problem before a dealer will replace a defective part that isn't defective yet.
  8. Jan 27, 2016 at 11:27 AM
    #108
    blackohio
    Cliche Guevara
    white mudflap
    Mcdonalds fries make you fat and unhealthy but they arent going to stop selling them. From a corporate lever to enact a running change on a sub component level that might affect some small global percentage of vehicles is far costlier than simply replacing said parts at the retail level.
  9. Jan 28, 2016 at 12:56 PM
    #109
    K Mac
    K Mac Well-Known Member
    Kyle
    Saskatchewan, Canda
    2016 Quicksand TRD OR ACLB 6MT
    Jeez. I wish my local dealer was more like this one!
  10. Jan 31, 2016 at 7:42 PM
    #110
    tonymtz69er1
    tonymtz69er1 Active Member
    Tony
    2016 Tacoma Limited
    I took my truck in to the dealership, and my truck purred like a kitten. No humming, buzzing or any noise. They technicians took me for a test drive and we did not hear anything. WTF... It acted like it has never made that sound.:mad::annoyed:
  11. Jan 31, 2016 at 10:23 PM
    #111
    Buddha717
    Buddha717 Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    Thats how it works. then the next day its there again
  12. Mar 26, 2016 at 11:12 AM
    #112
    4XO7544
    4XO7544 Active Member
    2016 Inferno TRD Offroad DCSB 4x4
    I have a 2016 DCSB with a 3" Toytec lift with the diff drop and I am experiencing the rubbing of the needle bearing on the drivers side. Goes away when the truck is put into 4H. My truck was lifted at the dealership. I assume they will make good on it. They have to call Toyota Corporate on Monday to get back with me. Options seem to be have them replace the needle bearing assembly, but I am concerned the problem will return. Or I could have them install the East Coast Gear Supply T8CS-BUSHING and be done with the whole matter. Not sure if the dealer would install a non-OEM fix. I need to confirm with ECGS the bushing will fit the 2016. Any thoughts?
  13. Mar 26, 2016 at 5:19 PM
    #113
    SandiestTaco
    SandiestTaco Well-Known Member
    Tom
    2016 Quicksand Tacoma
    OME 887's, Bilstein 5100's, HS AAL/no overload, LR UCA's 17" Method NV's 275/70R17 Cooper Discoverer S/T's
    Dude is your job here to be the dealership jerk or something? Magnuson-Moss Act requires a burden of proof from the manufacturer in regards to warranty work. Considering this part of the driveline on the 3rd Gen matches the 2nd Gen, AND there is already a TSB issued for the 2nd Gen a logical conclusion that the TSB will apply... Especially if an informed consumer pushes it.
    You sound like a real dick to be honest, like the kind of guy with the kind of attitude that hurts dealerships in the long run.
    Blazingbluesport and Nicetacobro like this.
  14. Mar 26, 2016 at 5:44 PM
    #114
    Ultrarunner7
    Ultrarunner7 Well-Known Member
    Northern Virginia
    2016 White Toyota Tacoma Sport 4 door
    Bilstein 5160s in rear with Toltec Progressive 3 leaf spring, Bilstein 6112s in the front
    Same issues with mine. It's intermittent. Installed Diff drop, and carrier bearing...the same. Still a noise.
  15. Mar 27, 2016 at 4:16 AM
    #115
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Burden of proof is on the owner of the vehicle. If the affected system of the vehicle didn't come that way stock, I'm not covering it under warranty. I get paid half my labor rate on warranty work. I'm not running a charity. If you can afford to modify your vehicle, you can afford to pay out of pocket.
    Every employee at my dealer has this attitude, and we are one of the biggest and most profitable in the region.
  16. Mar 27, 2016 at 4:50 AM
    #116
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Its been said repeatedly but I'll say it again. You sound like an ignorant prick that doesn't give two shits about people and would take a dollar out of a tip jar. Refusing to do work for people out of some spiteful juvenile mindset - 'if you can afford to improve your truck, then you have to pay for things that should be free.' Taking advantage of people who won't stand up to your stance is deplorable. I bet you guys love seeing old widows pulling up who know nothing about vehicles and will pay whatever you tell them it costs because you're the supposed experts.
    bryanjoh likes this.
  17. Mar 27, 2016 at 5:31 AM
    #117
    Aussiek2000
    2016 Offroad AC
    just following MFR guidelines.
    Why should a modified system be covered by warranty?
  18. Mar 27, 2016 at 5:37 AM
    #118
    Nicetacobro
    Nicetacobro Well-Known Member
    Adam
    Rhode Island
    2nd gen DCSB
    It's Taco time
    Told threw toyota if its not there lift and there install it will void warranty....
  19. Mar 27, 2016 at 5:39 AM
    #119
    Aussiek2000
    2016 Offroad AC
    That's what I'm saying too.
    Nicetacobro[QUOTED] likes this.
  20. Mar 27, 2016 at 5:40 AM
    #120
    Aussiek2000
    2016 Offroad AC
    Be like someone buying a base Corvette and then putting a supercharger on it and saying "well, the z06 has one, it should still be covered by warranty"
    Nicetacobro likes this.
