Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Nov 29, 2016 at 9:51 PM
    #201
    Sixgun CO
    Sixgun CO Well-Known Member
    16 Tocoma TRD off-road
    Brand new 07-28
    BTW, I talked to Nitro today and had a few questions.
    I asked why the didn't go 5.13s. He said, it would be 5.29s and there is not enough room in the front carrier to make gears that big. I said, I think those would be perfect if you could fit them in there. He agreed. Lol
    It is awesome to have the added power / torque.
  2. Nov 29, 2016 at 9:54 PM
    #202
    winterwolf
    winterwolf Well-Known Member
    Arthur
    Surrey, BC Canada
    16 White TRD Sport SB 6spd
    Agreed. I have the exact same truck as you and I need the 4.56
    Sixgun CO likes this.
  3. Nov 29, 2016 at 9:58 PM
    #203
    Sixgun CO
    Brand new 07-28
    Seriously doubt you would even notice the difference between those two.
    Btw it's not gonna happen.
    winterwolf likes this.
  4. Nov 29, 2016 at 10:18 PM
    #204
    BeaverNation
    BeaverNation Well-Known Member
    I think 4.88 would be perfect for a manual on 285's. I just want reverse to be lower honestly, I'll never know why they've always chose a tall reverse on Tacoma manuals. Anyone calculate what rpms the manual would be at 70 with 4.88s?
    nevadabugle likes this.
  5. Nov 29, 2016 at 11:40 PM
    #205
    brentw59
    brentw59 Well-Known Member
    Brent
    Clovis CA
    2017 Tacoma 4x4 DCSB Manual Inferno
    Basic Shit. Floor Mats, Seat Covers
    Another guy posted this in the 4.88 manual thread
    So i just checked grimmjeeper.com/gears for my setup at 75mph with 285/70r17s
    It shows:
    2352rpms with 4.30s
    2669rpms with 4.88s
    If that's the case I will be completely satisfied with the outcome of 4.88s.
    BeaverNation likes this.
  6. Nov 30, 2016 at 5:18 AM
    #206
    Sixgun CO
    Brand new 07-28
    1600 to 2050 rpms at 65.
    3.90to 4.88s in 6th gear.
    Those are not exact numbers but pretty close.
    Around town I'm still at 1600 rpm's at 40.
    Its an auto.
  7. Nov 30, 2016 at 7:59 AM
    #207
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    thanks - i just don't think these trucks have enough torque low enough to pull 1600 RPM at 65 with any kind of grade or headwind. sounds like your are pretty happy. guessing off the line is much improved.
  8. Nov 30, 2016 at 9:06 AM
    #208
    Sixgun CO
    Brand new 07-28
    Yes, much happier. I am finally starting to feel like I don't want to drive the truck off a cliff.
    Maybe I can start to enjoy it now.
    jetfishn likes this.
  9. Nov 30, 2016 at 9:22 AM
    #209
    DigitalSensei
    DigitalSensei Well-Known Member
    Texas - DFW Area
    2016 4x4 Off Road INFERNO!
    I can't possibly see how this calculator can work, considering it does not take into account the transmission gearing. It has to assume your are in a 1:1 gearing and not in overdrive.
  10. Nov 30, 2016 at 9:30 AM
    #210
    DigitalSensei
    Texas - DFW Area
    Does this calibrator allow you to input tire diameter and gear ratio?
    I'm curious what tires size/gear ratio you are running and how far off your speedo was before the calibration. If the larger tires make the speedo read low, but the gear makes them read high, just wondering how their offset from each other affected the final speed inaccuracy.
  11. Nov 30, 2016 at 10:38 AM
    #211
    ROGUE OFFROAD
    ROGUE OFFROAD [OP] Well-Known Member Vendor
    Shawn
    Yes you can input both. I check the accuracy of the speedo with a few different GPS units and programs to verify and get the ratio correct. Im very picky and cant have speed off for more than 2 mph. If you seen my trucks and the work I do you would understand. I calibrated the speedo the second day I owned the truck cause a hr after I drove off the lot it had 6112s on the front 5160 in rear and new wheels and tires 285 70 17. So first thing I did was lift and wheels and tires then I added the calibrator cause I new the speed was off. then I did exhaust and intake and had been waiting for gears since befor I bought the truck. Once gears were available i did those. and re-calibrated it after the gears again. @DigitalSensei
  12. Nov 30, 2016 at 10:42 AM
    #212
    ROGUE OFFROAD
    Shawn
    Hit me up Im here in Vegas And have the gears in stock !! 702-907-DIRT And the best prices http://www.rogue-offroad.com/
  13. Nov 30, 2016 at 10:45 AM
    #213
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    .58 Transmission gear ratio (6th gear in an auto with the V6)
    285's Tires (32.8")
    4.88 Diff Gears
    2000RPM = 69.4 MPH
    6 speed manual with .71 ratio 6th gear
    2000RPM = 60MPH
  14. Nov 30, 2016 at 10:48 AM
    #214
    ROGUE OFFROAD
    Shawn
  15. Nov 30, 2016 at 12:46 PM
    #215
    Syncros
    Syncros Well-Known Member
    Funny that I considered 4.88s "crawling" gears in my '82 short bed SR5 5spd with a 22R and 33x12.5s. It would keep up with traffic no problem.
    Saw to many 5.29 gear sets break to bother going any lower than 4.88. Less tooth contact and smaller pinion = kaboom.
    jetfishn and 0uTkAsT like this.
  16. Nov 30, 2016 at 12:50 PM
    #216
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
  17. Nov 30, 2016 at 3:34 PM
    #217
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I paid 627 for my 4.88 gear set with mini install kits.
    JoeCOVA[QUOTED] likes this.
  18. Nov 30, 2016 at 5:10 PM
    #218
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    hi guys would this ratio of 4.88 also be good in my 2.7 auto 4x4 planning on 285 /75 /16 a lot of hills everywere I go any input greatly appreciated thanks in advance
  19. Nov 30, 2016 at 5:16 PM
    #219
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    You're going to need all the help you can get with a 2.7 and a 33" tire. 4.88 should help but I think you'll still be down shifting quite a bit.
  20. Nov 30, 2016 at 5:23 PM
    #220
    crispy77
    crispy77 Well-Known Member
    Henderson, Nevada
    2016 MGM TRD Sport 4x4
    17" SCS SR8's King 2.5" Coilover shocks with Remote Reservoir and 650lb coils King 2.5" Rear Replacement Shocks with Remote Reservoir ICON 1.5" Add-A-Leaf pack Total Chaos Suspension Upper Control Arms BF Goodrich T/A KO2 285/70R17 BAMF Grille BAMF CMC Plates RCI Sliders & Front, Xmsn, Xfer Skids SSO Slimline Front Bumper Baja Squadron-R Sport Fogs Baja Designs 20" S8 Lightbar Smittybilt X20 10K with Solenoid Relocated Factor 55 Fairlead & Flatlink JCR Front License Plate QR Bracket RCI Rear Bumper Rigid Instustries SR-Q backup lights Nitro 4.88 Gears ECGS 8" Clamshell Bushing InSight Retrofits BHLM Mesojdm Ultimate LED Turn Signals Breather Mod behind tail light Yeti Bed Mounted Bottle Opener Forty2's 3 Switch Panel with CH4x4 Custom Switches Relentless Fab Bedrail Hi-Lift & Dual Quickfist Mounts 48" Patriot Edition Hi-Lift Nox Lux blackout kit & 4Runner TRD emblem Bussmann Relay Panel Hondo Garage Premium Radio Knobs, Un-Holey Dash Mount, Perfect Squeeze Phone Mount Redline Tuning Quicklift Plus DZ Innovations Shiftsense Pro (not yet installed) coming soon: BajaKits LT Kit Synergy Rear Wheel 1.5" Spacers Ultimate LED mirror turn signals
    Drove my 4:88's for the first time today. Put about 80 miles total all hilly back country roads in NJ, gotta admit so far I'm really liking the regear. The hunting is definitely reduced and drives much like what I expected the truck should drive off the lot. The most noticeable difference was uphill, much improved in my opinion. Lets see how I feel in another 1000 miles but its looking good. I do have a whine on deceleration but its minimal and nothing I can't live with, for the most part my radio is loud enough I don't hear anything anyway
