Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Apr 1, 2017 at 8:37 PM
    #681
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Are you ever going bigger than 265s?
  2. Apr 1, 2017 at 8:54 PM
    #682
    oorah54
    oorah54 Well-Known Member
    Darren
    Guyton, GA
    2015 Blue Tacoma Base
    Highly unlikely but not entirely out of the question either.
  3. Apr 1, 2017 at 10:53 PM
    #683
    ajsabra
    Sin city
    Well if your interested I have my 4.30 stock gears gathering dust with only 8k'ish miles on them and they will fit in your 8.75" rear diff and 8" front diff. They should suffice for you with 265s but you will need to buy master install kits from nitro to install them.
    https://www.nitro-gear.com/MKT8-75-p/mkt8.75.htm
    https://www.nitro-gear.com/MKT8S-R-p/mkt8s-r.htm
    I'm selling them for less than half of what toyota wants for them ($650 plus shipping), Pm me if interested.
    In total it would be $1450 which is about the close buying new nitro gears, but your not going to high in your gear ratio.
  4. Apr 2, 2017 at 2:54 PM
    #684
    oorah54
    Darren
    Guyton, GA
    Won't I lose my E-locker if I use those gears? Or will it work with them?
  5. Apr 2, 2017 at 3:33 PM
    #685
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    It will work. They are the stock gears that come out of the manual trucks with the e-locker
  6. Apr 2, 2017 at 4:33 PM
    #686
    ajsabra
    Sin city
    It will work just fine, your just swapping your ring and pinions not your whole 3rd member
  7. Apr 3, 2017 at 11:41 AM
    #687
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I did this last summer at SD gear and axle. I do have a Sport so 8" rear. The 4.56s came from Nitro. My thinking at the time was there wasn't a lot of people that had made the modification yet since gears weren't readily available and I wanted the truck to not suck gas on long trips at highway speed (drive to Alaska and around BC) I was and am really happy with the results, but given what I know now and other's experiences, I would have definitely gone 4.88s and added lockers. But if, for whatever reason, you're stuck getting 4.56s, it was still a huge upgrade from the 3.91s.
    daohaus likes this.
  8. Apr 4, 2017 at 6:42 PM
    #688
    oorah54
    Darren
    Guyton, GA
    Do y'all think that towing a camper would be a bit easier with 4.88s? I work construction and I'm about to start having to travel for work because the local shutdowns are almost over, and I don't want to have to rent a hotel every time I go somewhere.
  9. Apr 4, 2017 at 7:46 PM
    #689
    ajsabra
    Sin city
    It would bring you up to higher RPMS at freeway speeds which would mean more torque for accellerating/passing, but MPG would drop significantly on freeways.
  10. Apr 6, 2017 at 9:53 PM
    #690
    Evel Taco
    Evel Taco Well-Known Member
    Scott
    2017 Tacoma OR 4x4 MGM
    My truck has 600 miles on it, I am doing nitro gears, my mechanic says since it's so new no need for master install kit? Should I be worried?
  11. Apr 7, 2017 at 8:14 AM
    #691
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I wouldnt be worried. If he is good he can use whats there. its like 600-800 bucks.
    nitro gears are 220 each and they are charging like 1250 just for the gears and a master kit
  12. Apr 7, 2017 at 8:23 AM
    #692
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    so 2 grand in parts & labor
  13. Apr 7, 2017 at 8:29 AM
    #693
    avitaco
    A
    2017 DCSB 4x4
    Prob more than that... 2500-3000
  14. Apr 7, 2017 at 8:31 AM
    #694
    smitty99
    Scottsdale
    not worth it just to run big tires IMO
  15. Apr 7, 2017 at 8:33 AM
    #695
    avitaco
    A
    2017 DCSB 4x4
    not for just gears.. only if youre doing gears and lockers.
    I wish I could just do it myself. it would be so much cheaper
  16. Apr 7, 2017 at 8:34 AM
    #696
    smitty99
    Scottsdale
    Agreed but Gear work is not something even a typical auto technician will dig into. There's a reason differential shops and specialists exist.
    avitaco[QUOTED] likes this.
  17. Apr 7, 2017 at 8:52 AM
    #697
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I'm sitting at $1300 parts and labor with diffs pulled.
  18. Apr 7, 2017 at 9:02 AM
    #698
    smitty99
    Scottsdale
    to add lockers or just regear?
  19. Apr 7, 2017 at 9:06 AM
    #699
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    A bit confused here regarding gear ration and output.
    - 3.91 (stock) gives you more speed and less torque?
    - 4.88 gives you less speed and more torque?
    How does it translate in driving feel the gear ratio? I understand the ratio is between the ring and pinion (one revolution of the ring means 3.91 revolutions of the pinion) and thus
    - takes the pinion to spin 3.91 times to turn the ring 1 time -> lower RPMs -> cooler engine -> faster speed
    - takes the pinion to spin 4.88 times to turn the ring 1 time -> higher RPMs -> hotter engine -> lower speed
    What exactly is the gain or improvement in getting a 4.88 gear set?
  20. Apr 7, 2017 at 9:07 AM
    #700
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Just regear. Toyota is replacing my rear diff so I only needed the front master kit, and a friend does all the CO guys gear work for pretty cheap.
