Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Apr 7, 2017 at 9:21 AM
    #701
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I think 2500 to 3000 estimate is for regear AND lockers
    avitaco likes this.
  2. Apr 7, 2017 at 9:31 AM
    #702
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Ahh that would make more sense.
  3. Apr 7, 2017 at 9:31 AM
    #703
    mrnoodley
    mrnoodley Well-Known Member
    Michael
    Toms River, NJ
    2017 Quicksand TRD OR
    'The easiest way I have to describe it is that stock gears are like trying to ride up hill on a bicycle in too low of a gear. You crank slowly, but it's hard to push. Shifting to a lower gear is like downshifting. You'll pedal faster, but with less load and can get up the hill easier with less strain on the driveline.
    nDub likes this.
  4. Apr 7, 2017 at 9:56 AM
    #704
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    OK got it, makes sense, but...(on flat surface)
    - in 3.91 gear I drive at 75MPH @ 2000RPM & 20MPG
    - in 4.88 gear I drive at 75MPH @ 2700RPM & 17MPG
    I miss to see the advantage of regearing unless hauling, climbing or towing a lot. Also it may improve start and roll from dead stop but after that is not an improvement. At least the way I see it.
  5. Apr 7, 2017 at 10:22 AM
    #705
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Unless your truck can't even get to 5th gear at highway speeds :anonymous:
  6. Apr 7, 2017 at 2:16 PM
    #706
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I'm not replacing anything and I have way more miles than that. Only thing I'd recommend would be to replace the crush sleeves, $20 from Toyota and pinion nut, about $8 from Toyota, and maybe a pinion seal $18 from Toyota. But I've reused both in the past and have been 100% fine. New bearings and seals are not needed unless you have 75K + miles.
    My front seals still had factory grease in them that hadn't been worked out yet. No need to spend $500 + on master install kits.
  7. Apr 7, 2017 at 2:21 PM
    #707
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Biggest advantage you missed is you lower the load on the engine at any given rpm, and that is where you save MPG.
    2,100rpm with 90% throttle to maintain 70mph = bad MPG.
    2,800rpm with 25% throttle to maintain 70mph = better MPG
    Also, you put your engine back in the powerband it was designed for.
    jetfishn, taco 16 and TRD-OffRoad_Ben like this.
  8. Apr 7, 2017 at 2:59 PM
    #708
    Evel Taco
    Evel Taco Well-Known Member
    Scott
    2017 Tacoma OR 4x4 MGM
    Thanks for the info,I'm not going to sweat it. I appreciate your time.
    rlx02 and Diablo169[QUOTED] like this.
  9. Apr 7, 2017 at 6:58 PM
    #709
    Dacon
    Danny
    Gilbert, Arizona.
    All I see in numbers are disadvantages. Not a gear expert but logic is not motivating me to move to lower setup.
    2,100rpm with 90% throttle to maintain 70mph = cool engine = longer oil life = longer engine life
    2,800rpm with 25% throttle to maintain 70mph = hot engine = all the bad stuff
    Why not regear with something like 9.72? Think about how much gas you save!!!
    6500rpm with 0.2% throttle to maintain 70mph = super MPG.
    But then again, what do I know? Is your truck and can do whatever you want to keep you happy. For me is not logical. And spend $3000+ to save a few $$$ on gas. :crazy::facepalm:
  10. Apr 7, 2017 at 7:20 PM
    #710
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    I did sort of mistype, by 90% throttle, I also meant 90% engine load which equals poor fuel economy. More throttle more engine load.
    Less load on the engine the better mpg was the main take away from my post.
    This is why taller tires hurt mpg, not just because of increase weight and rotational mass, but because the increase in engine load to maintain speed.
    I had a meter on my Cummins that would tell me percentage of load on the engine. Stock with cruise at 70mph was 27% engine load. 37's with cruise at 70mph 38% engine load. Which one do you think is better for the truck, and better for mpg's.
    Just because you are turning lower rpm does not mean you are getting better mpg.
    Sorry if this is scattered, I've been posting from my phone.
    TRD-OffRoad_Ben, nDub and 0210 like this.
  11. Apr 7, 2017 at 7:23 PM
    #711
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Also I can't see anybody regearing simply for an mpg increase. That's just an added bonus.
  12. Apr 7, 2017 at 7:46 PM
    #712
    Dacon
    Danny
    Gilbert, Arizona.
    Forgiven for mistype. Here is a beer :cheers:.
    Stock I have 265/75/16 and want to replace with 275/65/18. Will be pushing a bit but not warranted to regear. Not used for off-road, towing or hauling. Just mall-ing :bananadance::anonymous:
  13. Apr 7, 2017 at 7:53 PM
    #713
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    I'd stick with stock rim size. More sidewall will give you a cushier ride which is much more beneficial than a couple inches of wheel size in looks.
    JoeCOVA likes this.
  14. Apr 7, 2017 at 11:29 PM
    #714
    Dacon
    Danny
    Gilbert, Arizona.
    Cushion? Cushion? What 'r you talking about cushion?
    The PRO stock shocks are too soft for me, waiting to install my Icons w/700# springs on the stock front. No need tire cushion..
  15. Apr 10, 2017 at 8:16 AM
    #715
    gearguy911
    gearguy911 Well-Known Member
    Boulder, CO
    2016 Magnetic Grey Tacoma TRD OR DCLB
    I got quoted by 4wheel parts for 1200 just for labor front and rear! That seems crazy compared to what some guys were posting in here.
    Anyone know a good place for gears in the Frontrange of Colorado area?
    THanks!
  16. Apr 10, 2017 at 8:20 AM
    #716
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Would like to know as well since I'll be back to the CO soon. In VA I was quoted $1000 per axle so $1200 for both looks pretty good. lol
  17. Apr 10, 2017 at 8:45 AM
    #717
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    Very good info.
  18. Apr 10, 2017 at 8:49 AM
    #718
    smitty99
    Scottsdale
    wow I would probably not go to 4WP for any labor, much less any gear work that's just me though
    nDub and mikestaco17 like this.
  19. Apr 10, 2017 at 9:17 AM
    #719
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Shoot me a pm and I'll give you the name of the CO guy who does all the gear installs.
  20. Apr 10, 2017 at 10:35 AM
    #720
    gearguy911
    Boulder, CO
    Pm Sent!
    yea wasn't crazy about them either, just figured it was a starting point for price, and my local auto shop said gears isn't something they normally do.
    smitty99[QUOTED] likes this.
