Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Apr 10, 2017 at 10:36 AM
    #721
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    You'll want to take to a differential shop
    Good chance 4WP would outsource the job to a specialist shop and just collect a percentage rake on it... subcontract work.
  2. Apr 10, 2017 at 11:13 AM
    #722
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    The 18s are better for Mall Crawling.
    Bigger wheels garner more bro points and the smaller sidewalls attract more hoes.
    Really, the shorter side wall is better for towing and stability by being more ridged.
  3. Apr 10, 2017 at 5:51 PM
    #723
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Slee offroad in Golden.
  4. Apr 10, 2017 at 6:01 PM
    #724
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    If not Christo aka Mr. Slee, try RSG and check the Colorado Regional site for other sources - at least one wrencher there who knows how do them. PM me where you go - I will be doing the same after warranty expires.
  5. Apr 13, 2017 at 12:29 PM
    #725
    gearguy911
    gearguy911 Well-Known Member
    Boulder, CO
    2016 Magnetic Grey Tacoma TRD OR DCLB
    Does switching to taller gear ratio's INCREASE your vehicles payload capacity? Or say increase your GVWR (gross vehicle weight rating). Looking at numbers on the 2016 tacoma TRD OR DC Long Bed, its payload capacity STOCK is 1120, or 5600 GVWR. Curb weight being 4480 stock.
    With all the accessories we enjoy as tacoma owners... going over this number seems quite easy when you have a double cab and throw 3 people in it, on top of all the fixed equipment.
  6. Apr 13, 2017 at 12:54 PM
    #726
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Nope, you are limited to as it is setup from the factory regardless what you do.
  7. Apr 13, 2017 at 12:56 PM
    #727
    gearguy911
    Boulder, CO
    Yes under factory setup, but with taller gears and upgraded suspension, shouldnt this give you more payload capacity? Lower gears will strain Powerplant less?
  8. Apr 13, 2017 at 12:59 PM
    #728
    Cold_Toad
    Cold_Toad Well-Known Member
    A majority of payload limits are based around the braking capabilities of the vehicle.
    And changing the suspension can potentially decrease your payload limit.
  9. Apr 13, 2017 at 1:00 PM
    #729
    gearguy911
    Boulder, CO
    But that would include towing as well on the brakes though, since the tacomas total weight with towing number is 11000 or so lbs.
    So it doesnt seem that brakes would be limiting factor on Payload since you could have a 2-3K lb trailer on the back and still be within limits
  10. Apr 13, 2017 at 1:04 PM
    #730
    Cold_Toad
    In theory yes. But there is no actual way of increasing the stated payload of a vehicle. You'd have to have you vehicle retested and meet whatever the standards are for the increased payload, but I've never heard of anyone every actually trying to do this.
    If you are actually worried about this I'm afraid you bought the wrong truck if you are wanting to carry a bunch of weight.
  11. Apr 13, 2017 at 1:09 PM
    #731
    smitty99
    Scottsdale
  12. Apr 13, 2017 at 1:10 PM
    #732
    gearguy911
    Boulder, CO
    oh, so this is more of a legal question. Like you are not allowed to exceed the weight based on laws?
    I was talking from a more practical perspective. Like does switching to taller gears actually help the truck carry more?
    Tons of builds on this form of overland style builds, steel bumpers winches ect. Just saying I am adding up the numbers with aluminum components and you can start exeeding the limits quite easily when you start adding passengers in the truck.
    I would imagine there are a bunch of overweight vehicles on this form from a legal perspective then...
  13. Apr 13, 2017 at 1:13 PM
    #733
    Cold_Toad
    Yes it's a law thing.
    Taller gears will make the engine not have to work as hard to get up to speed. But does nothing to help you when you have to stop.
    You are probably quite correct. There are a lot of overweight vehicles on the road.
  14. Apr 13, 2017 at 1:16 PM
    #734
    gearguy911
    Boulder, CO
    Ok so when we come to a stopping thing, I would imagine the tacoma is fine because the GCVR (gross combined vehicle rating) is 11000 or so lbs.
    That is weight rating of the total truck GVWR, and the Trailer in tow. So with the tow package tacoma, this should give you plenty of stopping power for even going over your GVWR by a few hundred pounds....
    now from a legal perspective...
  15. Apr 13, 2017 at 2:04 PM
    #735
    jomopdx
    jomopdx Well-Known Member
    jomo
    2016 Tacoma Sport
    Looking for shop recommendations for the regear of my 2016 Tacoma Sport. Want the 4.88 and most likely ARB lockers front and back.
    Portland Oregon or nearby. Thanks!
  16. Apr 13, 2017 at 2:16 PM
    #736
    JTM1
    Justin
    West Houston
    I believe the word you are looking for is "Deeper"; "Taller" refers to gearing that is numerically smaller, for example a 3.73 is taller than a 4.10, but a 4.30 is deeper than both.
    Edit to add, the limiting factor for payload in the Tacoma is most likely a combination of the rear springs, composite bed, and frame.
    JayRolla likes this.
  17. Apr 13, 2017 at 2:26 PM
    #737
    gearguy911
    Boulder, CO
    Yes, sorry meant deeper gears.
    So lets say we have a tacoma with upgraded leaf springs, and front suspension. weight is distributed on the frame instead of all in the bed.
  18. Apr 13, 2017 at 2:36 PM
    #738
    JTM1
    Justin
    West Houston
    No need to apologize. From a legal stand point the limit is what the manufacturer states on the door jam tag, if you want to change that you would have to contact your state agency to ask if that is even allowed to be altered or increased over the manufacturer stated limit.
    In a hypothetical world where I accept no blame for your actions and there could never be a bus full of nuns to be killed or hurt if you lost control of your vehicle, the frame as engineered would be the limiting factor. Remember Toyota has never been know for good quality frames and many of us have witnessed FJs, Toyota Pickups, and even First Gen Tacomas ripping sections of their frames off during a recovery.
  19. Apr 13, 2017 at 3:45 PM
    #739
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I know guys personally that exceed the payload basically half the year.
  20. Apr 13, 2017 at 3:49 PM
    #740
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I used to manage a truck stop. So many people are over weight. Including me!! HAHA.
    kashtyaatsi[QUOTED] likes this.
