Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. May 9, 2017 at 10:09 AM
    #761
    Protaco635
    Protaco635 Active Member
    Christian
    Virginia Beach
    Dark grey 2016 Tacoma TRD
    6" lift 35"tires
    Shocks yup acceleration no unless you have different engine lol
  2. May 9, 2017 at 4:13 PM
    #762
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Im not saying its a LOT quicker, but its without a doubt a little quicker. Better traction especially uphill and from a stop means better launches, less wheelspin, and more speed
  3. May 9, 2017 at 4:20 PM
    #763
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Won't beat my TRD sport :benchpress:
  4. May 9, 2017 at 4:38 PM
    #764
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Well gears are ordered... cant wait to get em installed. These 35's are killing me now. :turtleride:
    Diablo169 likes this.
  5. May 9, 2017 at 5:00 PM
    #765
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Dropped my rear 8.75" off yesterday for some 4.88's and an ARB :broccoli:
  6. May 9, 2017 at 5:58 PM
    #766
    Protaco635
    Christian
    Virginia Beach
    6" lift 35"tires
    You have a v6 3.5 and I have v6 3.5 which one are little quicker
  7. May 9, 2017 at 6:33 PM
    #767
    stevotivo12
    Stephen
    Let's see how about the one that has close to 10 gs in suspension work to get power down more efficiently. The only equation for speed/"power" isn't how much horsepower your truck has, if you don't understand that statement then this conversation is effectively over since nothing else I say will likely make much sense either
  8. May 9, 2017 at 7:06 PM
    #768
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    On a truck with this kind of power you'd be lucky if stiffer suspension makes you 0.1 second faster. This is not an 800hp monster we're talking about. Also 10K on suspension. No. Not even close.
  9. May 10, 2017 at 2:15 AM
    #769
    Protaco635
    Christian
    Virginia Beach
    6" lift 35"tires
    Dude what do you smoke lol
  10. May 10, 2017 at 3:55 AM
    #770
    stevotivo12
    Stephen
    While I do smoke, thats because i have a spinal condition called spondylolisthesis, which means that I fell one time when I was younger and a disc in my back slipped forward and the next one up slipped backwards.
    As far as the truck is concerned, im building that to take a run at the Baja 1K in a year or two when I'm ready. Theres not really much point in me going back through WHY suspension parts can make a truck faster. Im not saying it goes from a 7 second 0-60 to a 5, but I would say that it might be a tenth or two quicker in a straight line, along with a couple clicks faster around the corners, and exiting corners at higher speeds means more speed on straightaways too...
    The main thing is not having to break nearly as much for corners, and being able to keep going fast for long periods of time, just like one would in a 1000 mile desert race.
    You say this, but go karts experience the phenomenon I am talking about. It has less to do with the motor, and more to do with the quality of the suspension parts, of which mine are second to none essentially.
    rlx02 likes this.
  11. May 10, 2017 at 4:08 AM
    #771
    stevotivo12
    Stephen
    * Fox 2.5 DSC C/Os: $1800
    * Fox 2.5 DSC Shocks: $1200
    * Fox 2.0 Hydro Bumps/brackets: $300
    * Total Chaos gusseting, fab: 500
    * Total Chaos UCA w/ heims: $1000
    * Polyurethane bushings steering rack: 100
    * S-Runner rear sway bar: 400
    * Icon AAL: $250
    * Hellwig Front Sway bar: $250
    * Timbren Front Bumps: $200 (Light Racing coming soon)
    * All-pro sway bar end links : 250
    * Cryo Treated and slotted brake rotors: $500
    * EBC greenstuff supreme: 125
    * SS Brake lines : 50
    * 4x Innovations shackles: 250
    * 4x Innovations leaf spring cross member: 300
    * Budbuilt weld on traction bar: 500
    Should I pop the hood for you too while im at it? Or you satisfied with being wrong 66% of the time today and dont care to make that any worse than it has to be
  12. May 10, 2017 at 4:25 AM
    #772
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    I thought you were implying that the trd pro had 10K in suspension over the other models. Either way I'm not gonna get into a dick measuring contest with you. I fully understand what suspension does to a vehicle as I've owned nothing but bikes and sporty cars that I've built up to this point.
    stevotivo12[QUOTED] likes this.
  13. May 10, 2017 at 4:32 AM
    #773
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Stevo, you need to take a look in the mirror dude, tell yourself to relax, and that what other people do is just that, what other people do. Relax.
    stevotivo12 likes this.
  14. May 10, 2017 at 4:40 AM
    #774
    stevotivo12
    Stephen
    I got you Gearheadesw, it was just a little misunderstanding anyway. With as much as ive emotionally and physically invested in my truck I cant help but get a little defensive of her :notsure:
    Gearheadesw[QUOTED] likes this.
  15. May 10, 2017 at 5:20 AM
    #775
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I've built some pretty quick cars and some good offroad rigs. This post is pretty damn funny. The oem suspension is better on the street than any lifted rig.
    Now if your talking on the trail than maybe the pro could get around quicker.
    Even my DSM went quicker down track on stock suspension. The after market was stiff causing the car to bounce, hop down the track. OEM worn out suspension allowed car to squat and smoothly launch.
  16. May 10, 2017 at 6:16 AM
    #776
    stevotivo12
    Stephen
    Which is why i have ADJUSTABLE suspension. Did you miss the 'DSC' designations on both shocks?
  17. May 10, 2017 at 6:17 AM
    #777
    JayRolla
    Colorado Springs
    So does my DSM. My point still stands.
  18. May 10, 2017 at 6:18 AM
    #778
    stevotivo12
    Stephen
    If your truck was bouncing all over the track, the shocks were tuned improperly end of story. My truck doesn't bounce around at all, and is without a doubt quicker everywhere than when I got it.
    JayRolla likes this.
  19. May 10, 2017 at 6:23 AM
    #779
    JayRolla
    Colorado Springs
    It was a drag 4 banger turbo car. Not a truck. Just comparing an actual car with power not an underpowered toyota. The car was faster on oem suspension no madder how you tuned the shocks.
    But I bet your right. The trd pro suspension makes it faster in straight lines and turns compared to other trims. Sounds like a line a cars salesman would say.
  20. May 10, 2017 at 6:34 AM
    #780
    stevotivo12
    Stephen
    I was mainly talking about my truck not really the TRD pro. Im sure the Pro is tuned to do what they intended it to do very well, but the comments I made about the speed of the truck were directed specifically at my truck. If your car is making that much power then nothing CLOSE to the OEM suspension is going to do... you would need modified control arms top and bottom with heims to take the torque, reservoirs on all 4 corners with lots of oil capacity, nitrogen charges to fill the shocks, and replace pretty much every bushing with polyurethane, or even nitrile if you can stand the noise. Then after all that, you could think about going with stiffer springs depending on how many G's your pulling on launches to dial out bumps and bottoming out. Thats essentially what Ive done to my truck only I don't have to worry about bottoming out on launches so I was able to tune the rear suspension primarily with controlling hop over bumps and getting the best traction at all times in mind
