Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Jun 10, 2017 at 5:07 PM
    #821
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    it helped out on mine, i definitely have to give it less gas to back up uphill into my driveway
  2. Jun 13, 2017 at 7:11 AM
    #822
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Got my 4.88's installed yesterday and so far so good!! The truck feels awesome and doesn't bog down like it used to with stock gears. I haven't really gotten a chance to cruise on the highway yet, but it sits at just about 2100 rpm at 65mph which is perfect!
    Still obviously going through the break in and haven't really been able to get a feel for the full MPG and acceleration benefits but I'm happy so far!
    edit: I have 285/75/16 tires
    90yota and Diablo169 like this.
  3. Jun 13, 2017 at 7:14 AM
    #823
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Kind of an expensive solution though. If you don't have larger tires, you will be turning high rpm on the highway.
  4. Jun 13, 2017 at 9:02 AM
    #824
    Rein
    Rein Well-Known Member
    Cole
    San Diego
    2017 TRD Offroad DCLB
    Suspension, racks, tune, bed, lights. See build thread.
    Talked with a local gear shop on putting 4.88's in. They explained to me that they had another 3rd gen do the same and it experienced some mild humming. They replaced them with another set and had the same hum. Anybody else experience mild noise with Nitro 4.88 in the off-road?
  5. Jun 13, 2017 at 9:37 AM
    #825
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Rein likes this.
  6. Jun 13, 2017 at 9:51 AM
    #826
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Little bit of humming with only 30 miles on them so far. I'm going to withhold judgement till I get more miles and a fluid change.
    Rein likes this.
  7. Jun 13, 2017 at 10:06 AM
    #827
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    No hum at all
    Rein[QUOTED] likes this.
  8. Jun 13, 2017 at 10:11 AM
    #828
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    From what I understand humming comes from improper spacing/bad installation. A friend at Toyota said the shims for the 3rd gen are hard to come by. When he was re gearing mine he said there were none left in the country. If I had to guess I'd say that these shops can't get the proper shims in and are calling the spacing "good enough" and hoping for the best.
  9. Jun 13, 2017 at 10:21 AM
    #829
    Rein
    Cole
    San Diego
    Looks like ill need to discuss it a bit more with them. Anybody have recommendations for a gear shop in the San Diego area?
  10. Jun 13, 2017 at 10:26 AM
    #830
    mark1285
    mark1285 Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    I have a hum from about 55mph to 65mph on the highway. Slightly frustrating, cant even hear it if the radio is on quiet. I'm particular with my truck. Its louder on the deceleration.
    My question: is there anything I can do about it? Can these gears be adjusted? I have 3k on them.
  11. Jun 13, 2017 at 10:44 AM
    #831
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    You have it with new 4.88 gears? Or factory gears?
  12. Jun 14, 2017 at 6:53 PM
    #832
    E$Yota
    E$Yota Well-Known Member
    Ethan
    Dothan, AL
    2016 Tacoma TRD Sport 4X4
    FN wheels' version of the TRD Pro 4Runner, TRD Pro front skid plate, Low Range Offroad 3/1 lift, JBA Offroad upper control arms, TRD Pro Shift knob, OV Tuned, 4.88s, 285/70/17 BFG KO2s
    Attention everyone looking to regear a TRD Sport auto V6 or a SR5 auto 4cylinder!!! The master install kit coming from Nitro DOES NOT HAVE THE CORRECT CARRIER BEARINGS!!! As of right now, getting the correct ones is an act of Mexican congress cause they are not a US made part. I ended up having to use a pair of front carrier bearings and shave a half inch on either side of the axle housing to stuff everything in. If you do a regear, DO NOT REMOVE THE STOCK CARRIER BEARINGS!!! They must be reused. I informed Nitro they needed to put this information on their website so others don't run into the same issue as me. As far as the gears go and drivability? It's great!!! I have only about 20 miles on them as of now but will be driving 150 tomorrow and 300 miles on Saturday so we'll see how everything breaks in...
  13. Jun 14, 2017 at 6:58 PM
    #833
    TWTaco
    TWTaco Well-Known Member
    Dave
    Thanks for the heads up! That sucks!
    mikestaco17 likes this.
  14. Jun 14, 2017 at 7:00 PM
    #834
    E$Yota
    Ethan
    Dothan, AL
    I scored some actual bearings that it needs though. I'll hang onto them in case this thing comes a part.
    TWTaco[QUOTED] likes this.
  15. Jun 14, 2017 at 7:06 PM
    #835
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    Did Nitro say they would possibly get correct ones for their kit? seems like some people who have this kit could be in some trouble...
  16. Jun 14, 2017 at 7:15 PM
    #836
    E$Yota
    Ethan
    Dothan, AL
    Drew at Nitro didn't say yay or nay. I told him where I sourced thw correct ones from. And told him the disappointment and frustrations I had with their suppos-ed master install kit. He said they had sold a bunch and I was the first one that had really complained. I guess everyone is just doing a ring and pinion swap and not replacing the carrier bearings. Most everyone's trucks don't have a lot of miles so... also there is relatively small amount of people regearing the open diff 8 inch. They only come in trd sport auto and 4cylinder autos. Everyone else has the new 8.75 which is what the master install kit has bearings for. The 8 inch non e locker carrier is a 53mm inside diameter bearing and the 8.75 rear is a 50mm bearing. Luckily the front carrier bearings are 53 mm but are 16th of an inch wider which is why we had to cut into the diff housing.
    Danactive[QUOTED] likes this.
  17. Jun 14, 2017 at 7:51 PM
    #837
    Danactive
    Dan
    Upstate New York
    I hope they resolve this issue... I have a sport as well and plan on doing gears next summer!
  18. Jun 15, 2017 at 4:24 AM
    #838
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    thank you!! very very much was going to be pulling trigger on the nitro gears, I better hang out and wait, if the exact parts are unavailable, why didn't the rep I spoke to yesterday from nitro tell me this?
  19. Jun 15, 2017 at 4:30 AM
    #839
    mikestaco17
    MIKE
    BAD ASS UTILITY CAB
    im remembering that a guy on here I think his name here is HONEY with a beautiful truck, he had noises or hum as well , I do believe he has since resolved the issue, I think they were nitro gears , I better do some digging on the forum here to see for sure.
  20. Jun 15, 2017 at 5:14 AM
    #840
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    What's the deal with the rms polish? Do you order them that way? Or is that something you do 3rd party?
