Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Jun 27, 2017 at 5:54 PM
    #861
    J2L4U
    J2L4U Well-Known Member
    Jay
    FLORIDA
    2016 SR5 Tacoma 4x4 quicksand A/T
    6" bds lift fox rear socks and front res coilovers, 20x10 Fuel Vapor wheels wrapped in 285x65 20s Nitto Ridge Grapplers, Magnum rt step bars, regeared from 3.90 to 4.56 to 4.88 and finally to 5.29 with a Nitro worm gear LSD . Hypertech speed calibrator, camo hydro dipped interior, front wanna be a raptor lights. Alpine halo 9 with added amp and accessory module for light switches Kicker tweeter and door speakers Fab fours rear bumper C4 fab low pro front bumper with warn Evo 10s Rough country black series single row light bar KDMax tune
    Not sure. I got faith in him, just never heard of those gears i just wanted to see if anyone had any review on them. If his shop didn't have really good reputation i would be more worried. I even asked him about nitro gears and he said these are better. Fingers crossed lol
  2. Jun 28, 2017 at 4:55 PM
    #862
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    Is it true the automatic sport owners can go with 2nd gen gears due to the sports having the 8" housing? I was told that was an option verses going with nitro and "hoping" to get the correct bearings for the 8" housing verses the 8.75" housing for the OR's
    90yota and TWTaco like this.
  3. Jun 28, 2017 at 5:11 PM
    #863
    TWTaco
    TWTaco Well-Known Member
    Dave
    :popcorn: I would like to know as well ? ANYONE
    Danactive[QUOTED] and 90yota like this.
  4. Jul 19, 2017 at 11:22 PM
    #864
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Mmm, I in no way followed break in procedures with my Nitro 8.75 4.88's. Towed right off the bat, went on a road trip, stayed at a constant 70mph for hours at a time, still haven't changed he initial fluid, over 2,500 miles on the oil and gears. Reused all old bearing and seals and crush sleeve, and my rear end is 100% silent and smooth. I did however use amsoil 80w90, and took it to rearend specialties. All they do is rearends, I never have to worry about their work.
    Taco_AZ, Danactive and 90yota like this.
  5. Jul 22, 2017 at 12:15 PM
    #865
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    What RPM do you sit at at 75? Trying to figure if a auto or manual will be better for what I want to do.
  6. Jul 22, 2017 at 3:13 PM
    #866
    sig916
    sig916 Well-Known Member
    Can someone tell me if the mini kit comes the nitro solid preload spacers? If no, is it recommended?
    According to nitro, it says that "Solid Preload spacer replaces stock type crush sleeve improving bearing preload retention, eliminating possible crush sleeve damage if the yoke is impacted offroad and allows the pinion seal to be serviced without complete disassembly of the differential to replace a crush sleeve and reset pinion bearing preload."
    I only have 6k on my truck. Should i get just the mini kit or the package kit?
    I'm new at this. Any reccomend shop in Sacramento CA?
  7. Jul 22, 2017 at 4:35 PM
    #867
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    I would stay away from off road shops, unless they have a good reputation for gear installs. Most of the times Drive Shaft Shops or Transmission shops will have a lot of experience setting up gears. I'm spoiled and have Rearend Specialties less than an hour away.
    There isn't really a need to replace anything with such low miles. If it makes you feel better, at the most new crush sleeve, pinion nut and pinion seal.
  8. Jul 22, 2017 at 6:02 PM
    #868
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    I don't know lol. 75 and 35's don't mix
  9. Jul 22, 2017 at 6:03 PM
    #869
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    fair enough :oops:
  10. Jul 22, 2017 at 7:05 PM
    #870
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Maybe that's what is wrong with my stock rear end.
  11. Jul 22, 2017 at 7:08 PM
    #871
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    May I ask why?
  12. Jul 22, 2017 at 7:09 PM
    #872
    90yota
    88 T4R / 15 F350
    Stock....ish
    Cuz they are heavy AF and even with 488s i would be in 4th gear trying to hold 75.
    MESO[QUOTED] likes this.
  13. Jul 22, 2017 at 7:38 PM
    #873
    Johnny0
    Johnny0 Well-Known Member
    Los Angeles
    1989 4Runner. 2000 4Runner. 2018 Ford F-150
    bone stock
    what is the stock ratio? Does TW have a thread that shows what gearing comes stock on what taco? how much did it cost to bench the 3rd member and get new gears installed?
  14. Jul 22, 2017 at 7:42 PM
    #874
    harrycary
    Harry
    I wonder if the crushsleve is yielding, on the stock rear axle, and if that is the culprit for the howling rear end after some time goes by. Perhaps a heat cycle issue.
  15. Jul 22, 2017 at 8:48 PM
    #875
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Yep bad spacing. Known issue.
  16. Jul 23, 2017 at 6:26 AM
    #876
    harrycary
    Harry
    That should be an easy fix then. I wonder why Toyota is not fixing it.
    tacoflavoredkisses1 likes this.
  17. Jul 23, 2017 at 8:29 AM
    #877
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    The stock crush sleeve is pretty stout. There was a thread on Pirate4x4 that showed that a Snap-On Impact couldn't crush it, and they had to do it on a press. That being said I've reused Toyota crush sleeves many times with no failures, and running big tires.
    Doubt they have the techs to perform the work, from what I read Toyota is just replacing the diffs.
  18. Jul 23, 2017 at 8:35 AM
    #878
    harrycary
    Harry
    I understand. Do you think heat cycling could change the characteristics on the crush sleeves. I imagine it would take a good bit if heat or poor quality metal.
  19. Jul 23, 2017 at 11:40 AM
    #879
    kashtyaatsi
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Mine was replaced under warranty and then I had the 4.88's installed in the brand new diff.
  20. Jul 23, 2017 at 11:46 AM
    #880
    harrycary
    Harry
    Cool. Is the howl 100% gone now?
