Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Jul 29, 2018 at 3:36 PM
    #1081
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The Land Cruiser guys are die hard people, they will spot something wrong from 5 miles away. They're more die hard than any Tacoma or tundra guy
  2. Jul 30, 2018 at 8:30 AM
    #1082
    mrnoodley
    mrnoodley Well-Known Member
    Michael
    Toms River, NJ
    2017 Quicksand TRD OR
    The week after the Jeep event in Wildwood was an all truck event. You could have brought it out then.
    I was at both events this year.
  3. Jul 30, 2018 at 8:40 AM
    #1083
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    It seems like a lot of us on this board were there within the past week or two.
    JoeCOVA[QUOTED] likes this.
  4. Aug 3, 2018 at 4:59 PM
    #1084
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
    Would you recommend 4.88 for towing from time to time.
  5. Aug 4, 2018 at 11:48 AM
    #1085
    mrnoodley
    Michael
    Toms River, NJ
    Absolutely. You'll have more torque off the line and the trans won't hunt for gears nearly as much.
    Wedge[QUOTED] likes this.
  6. Aug 5, 2018 at 4:31 PM
    #1086
    KruiserIV
    KruiserIV Well-Known Member
    Kanon
    2017 Tacoma TRD OR
    What's total cost (OTD) of re-gearing to 4.88 on a 3rd gen? The reports I've seen are varied, and sounds like a lot of folks are having more than re-gearing done, so price includes extra.
  7. Aug 5, 2018 at 4:47 PM
    #1087
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Reputable shops around here charge $1200 per axle. Add more if you go with lockers.
    -RJM
    inksin likes this.
  8. Aug 5, 2018 at 4:50 PM
    #1088
    KruiserIV
    Kanon
    2017 Tacoma TRD OR
    Thank you, that's what I estimated.
    I plan on staying with 31-32" tires, and off-roading/traveling with a loaded truck (canopy, camping gear, family) and so I'm considering doing the conversion.
    Would I see any benefit?
  9. Aug 5, 2018 at 4:50 PM
    #1089
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    It’s like asking how much a hamburger and fries will cost.
    It could be cheap and crappy or expensive and done perfectly. It could be me buying my own patties and cooking it myself so they come out just right.
    Lots of variables.
    Setting up gears is not an easy task. But the gears and send it to your cousin’s brother’s best man and he does it in the garage and it will be cheap but is it done right? You’ll find out when it breaks and you’ll also find out that the word “warranty” is basically the equivalent to speaking French to a Pigmy.
    Go to a reputable shop and they order the parts and do the install and you pay a lot of money but be comfortable that warranty is part of the vocabulary and you should be covered on parts and labor as long as you weren’t being irresponsible.
    If you got decent mechanical skillz then order a pre build setup from ECGS and be confident that it’s set up right and they stand behind the work, you just get to do all the install labor. You could save a good $600-$1,000 by installing it yourself as long as you have confidence in your own work.
    If I remember correctly I payed about $1,500 for the ECGS built units and installed it myself. Plan on another $600-$1,000 to pay someone to install them for you.
    You can buy the parts cheaper but then you need to pay someone to set up the gears too and that’s the part that is the hardest to do correctly. Set up wrong and you break expensive stuff and It’ll be a tough fight on who to blame cause the installer will put the blame on driver error.
    KruiserIV, Wedge and Loco38SUP like this.
  10. Aug 5, 2018 at 5:29 PM
    #1090
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Crazy talk, I’ve never been quoted above $1200 for both axles. Did you hear that or do you have written quotes because mine are all written.
    alwaysHI likes this.
  11. Aug 5, 2018 at 5:33 PM
    #1091
    inksin
    Hawaii
    I do believe he said $1,200 per axle
  12. Aug 5, 2018 at 5:41 PM
    #1092
    KruiserIV
    Kanon
    2017 Tacoma TRD OR
    Thanks =)
  13. Aug 5, 2018 at 5:49 PM
    #1093
    inksin
    Hawaii
    Will you see a benefit? Depends on what you feel a benefit is.
    31-32 tire size is kinda pushing it for 4.88s. In my opinion, the best benefits of 4.88 driveability is with 33s although many people have been happy with 4.88s on stock tires. 4.56 could also be an option for you but if you have any intention of adding more weight or going any bigger in tires in the future then 4.88s for sure. You will definitely notice the difference of adding gears, just your revs on the freeway may be a tad bit high with that tire size. Not crazy high, just a tad. That’s why it’s hard to say if you’d see it as a benefit, it’s a personal preference. If you got 33s then yes, a benefit no matter how you look at it.
    KruiserIV[QUOTED] and Loco38SUP like this.
  14. Aug 5, 2018 at 5:57 PM
    #1094
    KruiserIV
    Kanon
    2017 Tacoma TRD OR
    Thanks for the great info, guys.
    inksin and Loco38SUP like this.
  15. Aug 5, 2018 at 7:55 PM
    #1095
    JoeCOVA
    Joe
    Colorado Springs
    4.56 are not available, we have 3.90, 4.30, 4.88, 5.29
    KruiserIV and inksin[QUOTED] like this.
  16. Aug 5, 2018 at 7:57 PM
    #1096
    la0d0g
    running for the hills
    For crawling not hauling
    They're not?
  17. Aug 5, 2018 at 8:00 PM
    #1097
    JoeCOVA
    Joe
    Colorado Springs
    Nope. 4.88 was the first aftermarket R&P and now we have 5.29.
    4.30 are Toyota factory gears.
  18. Aug 5, 2018 at 8:02 PM
    #1098
    la0d0g
    Whats the diff size on 3rd gen? 8.75?
  19. Aug 5, 2018 at 8:02 PM
    #1099
    JoeCOVA
    Joe
    Colorado Springs
    Yup
    la0d0g[QUOTED] likes this.
  20. Aug 6, 2018 at 8:13 AM
    #1100
    mrnoodley
    Michael
    Toms River, NJ
    All manual transmission 3rd gens get the 8.75 along with manual and auto TRD OR and PRD Pro models.
    Automatic SR, SR5, TRD Sports and Limiteds get an 8" rear axle.
    JoeCOVA and la0d0g[QUOTED] like this.
