Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Aug 6, 2018 at 8:16 AM
    #1101
    mrnoodley
    mrnoodley Well-Known Member
    Michael
    Toms River, NJ
    2017 Quicksand TRD OR
    Sounds about right. That's around what we charge at our shop here in NJ.
  2. Aug 6, 2018 at 8:19 AM
    #1102
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    This is correct.
    Also, there are many more ratios available for the 8" vs the 8.75" at ECGS's site such as 4.56.
  3. Aug 6, 2018 at 1:18 PM
    #1103
    Arpatton86
    Arpatton86 Well-Known Member
    Ontario Canadia
    2017 DCSB TRD OFF-ROAD OV TUUUUNED
    Anyone heard of an ETA for 4.56 in the 8.75? I’m holding out for this, I feel like 4.88 and 265/75/16r is a little much but I’d love to have the low end torque.
  4. Aug 6, 2018 at 6:46 PM
    #1104
    ROGUE OFFROAD
    ROGUE OFFROAD [OP] Well-Known Member Vendor
    Shawn
    4.56 isn't on any companies radar at the moment. In real-world testing, the 4.56 hasn't shown any point in being produced for a 3rd gen . We have done an 8in 3rd gen with 4.56 and it wasn't impressive at all vs the 4.88 even on stock tires. SO as of right now no future what so ever with any of the companies. Nitro, motive, Yukon or revolution. I'm sure if I can get 300+ confirmed orders of 4.56 in 8.75in I could definitely make it happen though!
    Arpatton86[QUOTED] and Loco38SUP like this.
  5. Aug 6, 2018 at 11:50 PM
    #1105
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    I was charged 700 labor for both axles
  6. Sep 17, 2018 at 7:26 PM
    #1106
    Potato Taco
    Potato Taco Active Member
    I was quoted $2400.00 for both axles parts and labor, Nitro gears.Does that sound about right? I need to ask them about the REM option. Any other questions I should ask. Thx TW peeps
  7. Sep 17, 2018 at 10:02 PM
    #1107
    alwaysHI
    2017 MGM DCSB
    If you can, get multiple quotes from a handful of reputable shops.
  8. Sep 17, 2018 at 10:40 PM
    #1108
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    4.56 would be negligible difference. 4.88 is a good ratio. I’m now on 5.29s with stock tires and truck drives great.
    commbubba19, jholc21 and ChronicTaco like this.
  9. Sep 18, 2018 at 12:45 PM
    #1109
    HawaiianSON
    HawaiianSON Blood makes the grass grow, OORAH!
    Nasty
    San Diego by way of HILO, HI
    2015 white DCLB
    Kustom54lighting /bruteofrce/brushed BRONZE
    Sure does. I just got a quote from pro gear here in San Diego for 4.88 gears front/ back, arb locker and labor plus a military discount= $3400ish
  10. Sep 18, 2018 at 2:15 PM
    #1110
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
  11. Oct 10, 2018 at 8:36 PM
    #1111
    17Tacoforme
    17Tacoforme Active Member
    2017 Tacoma Off-road
    2” lift Bilstien 6112’s and 5160’s. 265/70/17 Nitto Grapplers G2. TRD wheels. TRD Grill. ARE shell. Exhaust.
    So I have been following many topics on TW and finally decided to sign up and join the conversation.
    In regards to the 4.88 thread I saved up the $$$ and pulled the trigger on putting new gears in.
    My 2017 4wd off-road package Tacoma has 22000 miles on it. I will be having my 3rd set of 4.88’s put in the rear diff to try and resolve a whine between 55mph and 70mph ( more pronounced on deceleration ). Of course the manufacturers says it the installer and the installer says it the manufacturer). No need to throw anyone under the bus so I don’t want to name names. HAS ANYONE ELSE HAD THIS PROBLEM?
    I have followed break in procedure 100% maybe even more than required.
  12. Oct 10, 2018 at 9:32 PM
    #1112
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Yikes. It’s a 3rd gen problem. Interesting that even aftermarket gears aren’t fixing it.
    I had the Toyota TSB installed and I’m still getting the howl.
    See https://www.tacomaworld.com/threads...oise-howling-when-feathering-throttle.442341/
    Who’d you buy the gears from?
    I’m hoping it’s not Yukon. I’ve had a lot of luck with their stuff.
  13. Oct 10, 2018 at 11:16 PM
    #1113
    Dg7leon27
    Dg7leon27 Well-Known Member
    Daniel
    Super white 2017 trd pro
    i'm interested if you still have any available?
  14. Oct 11, 2018 at 6:31 AM
    #1114
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    wrong - it's the greatest thing ever
  15. Oct 11, 2018 at 6:44 AM
    #1115
    17Tacoforme
    Yes I read the thread about factory whine, but mine never had that problem with stock gears.
    I do not have any extra gears. The installer has just replaced them and kept the gears. I really like the 4.88’s but can’t handle the whine. Makes my $40000 truck worthless.
  16. Oct 11, 2018 at 7:48 AM
    #1116
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Why did they keep the gears? Those are your gears...
  17. Oct 11, 2018 at 8:00 AM
    #1117
    commbubba19
    '23 TRD PRO
    warranty. you don't keep gears you say are bad and do a warranty exchange on.
    my shop explicitly stated they would buy the gears so any warranty issues would go through them. i paid about $2500 for everything including ecgs bushing.
  18. Oct 11, 2018 at 8:05 AM
    #1118
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I may have misunderstood. I thought the installer kept the stock gears..
  19. Oct 11, 2018 at 8:12 AM
    #1119
    commbubba19
    '23 TRD PRO
    i'd assume the shop has to return the gears to the manufacturer
  20. Oct 11, 2018 at 8:14 AM
    #1120
    17Tacoforme
    I have stock 3.90 and will not go back to them. I’m going to try one more set that they are willing to put in to try and see if it’s better. The 4.88’s are way better than stock as far as drivability. It should come from the factory with them or at a minimum 4.56’s. ( a small 4.7 V8 would fix everything!!).
    commbubba19 likes this.
