Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Apr 29, 2019 at 10:16 AM
    #1141
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    Unless you want your axles spinning at different speeds, I'd reccommend getting both :)
  2. Apr 29, 2019 at 10:49 AM
    #1142
    dreday
    dreday Well-Known Member
    18’ TRD SPORT 4x4
    ok thnx.
    i have no clue. i am new to trucks/4x4's. this is my first pick up.:D
  3. May 14, 2019 at 10:37 AM
    #1143
    Hightorque1973
    Hightorque1973 Member
    Florida
    18 Offroad DCSB (OVTune 4.88's)
    Falken Wildpeak AT 265/70/17
    I just had my gears installed two weeks ago. REM polished 4.88 gears and have the exact same noise.
  4. May 14, 2019 at 11:09 AM
    #1144
    jrcuevasv
    jrcuevasv Well-Known Member
    2018 TRD Off-Road
    Finally jumped to 285/70/17s and boy can I feel the difference going uphill.
    On flat roads it's not bad at all. Guess I have to save up next for a regear
  5. May 14, 2019 at 11:33 AM
    #1145
    Hightorque1973
    Florida
    They sure make a difference. The transmission doesn't jump around anymore and holds 6th gear up small grades now.
    jholc21 likes this.
  6. May 17, 2019 at 5:19 PM
    #1146
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    Just had mine done at the 1st of the month and they are quiet also. no whine. Some trucks make this noise even from the factory.
  7. May 17, 2019 at 5:38 PM
    #1147
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    had the whine with my Stock 3.90's and had the TSB done before going to Nitro 4.88's - the Dealer replaced rear leaf springs and rear cab mounts. The whine is a factory defect in all TRDOR 8.75" rear diff housings that causes harmonic vibrations. Strangely not all TRDOR 8.75" trucks exhibit this noise. Mine has a slight whine with the 4.88's and only at 55 mph (same speed as the 3.90's). I also run stock viscosity rear diff fluid but will go to a higher/heaver viscosity at next change. All in all I would take the 4.88's over the stock 3.90's as the performance and drivability is way better than stock.
    Hightorque1973 likes this.
  8. May 20, 2019 at 11:47 AM
    #1148
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    Very tempted to regear before adding a lift or tires. How much are you guys paying out the door? nitro gears with the added rem polish and oil is like 1800 I believe. It seems pretty high.
  9. May 20, 2019 at 6:08 PM
    #1149
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    I never REM’d mine. But with gears, shipping to hawaii via FedEx, and install with gear oil, about 1900
    rainyben45[QUOTED] likes this.
  10. May 22, 2019 at 7:21 AM
    #1150
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Paid about $1400 for nitro 4.88 with REMs from a group buy.
    Installation was another $1500.
    SpeySquatch likes this.
  11. Jun 25, 2019 at 11:33 PM
    #1151
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Where did you have the installation done?
  12. Jun 26, 2019 at 5:45 AM
    #1152
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Rear End Specialties Santa Clara, CA
    Bunk Moreland[QUOTED] likes this.
  13. Jun 26, 2019 at 10:37 AM
    #1153
    Bunk Moreland
    Bunk
    It's complicated.
    Thank you.
    sd1uh8as[QUOTED] likes this.
  14. Jun 26, 2019 at 10:38 AM
    #1154
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    You're visiting the Bay? :)
  15. Jun 26, 2019 at 10:44 AM
    #1155
    Bunk Moreland
    Bunk
    It's complicated.
    No. I have a friend who has been talking about doing this for his 2018 Tacoma, but hasn't because he's not found a reliable shop who will do it. He lives in California, so having a recommendation is very helpful--I'll pass it along to him.
    I'm buying a 2019 TRD OR DCLB, and am going to get this done. I'm in Oregon, and am looking for a shop as well (I don't have the skills, tools, or shop space.)
  16. Jun 26, 2019 at 10:46 AM
    #1156
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Ahh gotcha! RES has been in business for a very long time. They do perfect work so your friend should be fine.
  17. Jul 23, 2019 at 6:53 AM
    #1157
    Hightorque1973
    Florida
    Update on my 4.88's. Swapped out the noisy REM polished 4.88's for a set of standard Nitro's followed the break in cycle. The gear whine is barely noticeable around 55-60 and a bit on deceleration, love the gears even more now.
  18. Jul 23, 2019 at 8:50 AM
    #1158
    rainyben45
    Ben
    Ventura County
    Mmmm I thought REM polished made the gears more smooth, any idea why they were loud?
  19. Jul 30, 2019 at 7:14 AM
    #1159
    Hightorque1973
    Florida
    ECGS said the REM polished gears have been noisy in previous installs as well as mine. Not sure exactly why. With the REM gears installed, I had so much noise at highway speeds, the radio couldn't drown it out. Constant loud harmonic or hum. I installed sound dampening material to the floor and behind rear seat. That helped, but eventually it drove me nuts. I called ECGS to swap out the gears to standard 4.88's and now I have very, very mild gear noise between 55-65 mph. I can listen to the radio at minimal volume levels again.
  20. Jul 30, 2019 at 7:45 AM
    #1160
    GoldenBrew
    Golden, Colorado
    Check with @SpeySquatch = I think he is up your way and just got 4.88's installed.
