Installed 4wd strut assembly on my prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Oct 1, 2020.
  1. Oct 1, 2020 at 3:07 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    Ok,
    I messed up and ordered the sr4130/sr4131 kyb strut assemblies for my 2005 pre runner. I installed one already without issue and as I am a about to install the other one I realize that rock auto has these listed for 4wd models. And for the prerunner they have Sr 4134. I already emailed kyb asking about the difference but wanted to get your thoughts.
    Is there harm in leaving the 4wd ones on my vehicle? Seems to fit ok.
    Thanks
    Bruce
    Matic likes this.
  2. Oct 1, 2020 at 3:08 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    You'll be fine, the PreRunner has the same suspension as the 4WD
  3. Oct 1, 2020 at 3:11 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    As posted ^^^ isn't an issue.
  4. Oct 1, 2020 at 3:16 PM
    bruce1271
    Thanks guys. Not sure why the two part numbers from kyb.
  5. Oct 1, 2020 at 3:19 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    1 may have a shim under the spring to adjust for the driver's side Tacoma lean
  6. Oct 1, 2020 at 3:57 PM
    bruce1271
    From kyb
    Bruce,
    The difference is that SR4130/31 for the Tacoma 4WD use a springs with a higher load rating than SR4133/34 for the Tacoma PreRunner. Basically, this means the 4WD truck has a higher ride height in the front than the PreRunner does. Aside from that, there isn't any other difference between these units. It is up to you if you want to keep SR4130/31 on your vehicle, it should not cause any performance problems but may lift the front end of the vehicle a little bit.
    Regards,
    Technical Support
    KYB Americas Corporation
  7. Oct 1, 2020 at 4:07 PM
    bruce1271
    Bruce,
    The shock is made in the Japan, the spring is made here in the USA, and the unit is assembled in the USA.
    Regards,
    Technical Support
  8. Jan 25, 2021 at 7:02 PM
    MaiziemyDog
    MaiziemyDog New Member
    06 taco trd
    STOCK
    So.... What do you think the struts? How’s is the ride a few months later?
  9. Feb 28, 2021 at 11:46 PM
    bruce1271
    Definitely more stable than what I had before which were the original 15 year old struts. A little bit stiff though over some bumps. Guess that’s due to the springs being for the 4x4. I would do it again if I had to repeat. Install wasn’t bad. Did the brakes as well.
