Installed 5100's @ 1.75 today...answers those common questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cmbondo, Jul 29, 2014.
  1. Nov 25, 2014 at 3:20 PM
    bbushen6
    bbushen6 New Member
    Brandon
    Bellingham
    2009 TRD Sport
    New to Tacoma World. Just completed a lift thanks to all the posts on the forum. 5100's front (set to 1.75") and 5100 rear with Wheelers 3 leaf progressive HD AAL in the rear. I installed BFG All Terrain T/A KO2 275/70/17. Just wanted to let people know that I do have some rubbing on the UCS's. Going to try Wheelers 1/4" spacers to see if it helps.
  2. Nov 25, 2014 at 3:28 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    all !this prettiness! where's the Dirt For those AT's?!
  3. Nov 26, 2014 at 2:14 AM
    14Tacoma
    14Tacoma Well-Known Member
    Brandon
    New Hampshire
    great write up! thanks!
    truck looks awesome
  4. Nov 26, 2014 at 5:33 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I went with almost the exact same setup. I went with ko's instead of ko2's. Very light rubbing on the edge of the tread at full lock. Can't tell it at all, except in reverse. And even then, barely. Let us know if you do the 1/4" spacers and if they worked.
  5. Apr 27, 2015 at 2:28 AM
    Street_Ops
    Street_Ops New Member
    Gulf Coast
    Black '15 4x4 TRD Sport
    Daytime Running LEDs/Heated SofTex Seats/Infinity Back-up Mirror/TRD Pro Grille/TRD Pro Exhaust/WeatherTech Bed Liner/4Runner TRD Pro Rims/5-Window 15% Tint/AMP Bed X-Tender
    Looking to hook up my 2015 4x4 TRD Sport with the setup on cmbondo's truck. Does anyone know if I would I need any kind of spacers for the diff or extended sway bar bolts? From what I read, lifting the truck 2" max keeps you from needing any of them, can someone confirm.
  6. Apr 27, 2015 at 7:49 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    To the OP, I have the same setup on the front as you. When I took it to get aligned my initial numbers came in at 1.4 for caster on both sides iirc. The truck felt a little less planted on the road so I had the tech up both sides to 2.4. It better than stock, you can let go of the steering wheel and it stays straight. Also the return to center when turning a corner is much better.
    Someone was also asking about if one of the pictures of the leaf springs was the tsb or an aal. It is most definitely an aal. The tsb springs have 3 leaves plus an overload.
    To street ops: Yes it is generally accepted that lifting the truck 2 inches and under you will not need any other parts including diff drop, extended sway bar bolts, uca's, carrier bearing drop, pinion angle shim etc etc.
  7. Apr 27, 2015 at 7:56 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    The hub to fender measurements seem to be the issue in trying to get a level ride.
    Is it just me or are the rear fenders set higher in the vehicle for more clearance? I think so. If you're looking for level, throw a long level on the bedside.
  8. Apr 27, 2015 at 6:14 PM
    cmbondo
    cmbondo [OP] Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I had it realigned at another shop because I was unhappy with my original results. The shop I took it to specializes in custom alignments. They maxed out the caster and it still turned out to be around 2 degrees. I wish I could get a little more to plant the front end more solid. Maybe new UCAs in the future?
  9. Apr 28, 2015 at 5:37 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    What are your alignment numbers for caster? Did that shop do the 1.2 left and 1.9 right?
