installed 5100s, having some questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by mx04taco, Jun 14, 2011.
  1. Jun 14, 2011 at 3:44 PM
    mx04taco
    mx04taco [OP] Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    Long story short, before I had 5100s.. I was running 1" coil spacers on my stock coils and struts. I left them off(obviously) when installing the 5100s. I already have all pro 1.5 shackles on the rear end lifting the rear about 3/4" over stock height. When I installed the 5100s I put them on the middle setting because I didnt need the 2.5" (that the top setting claims to be), and i didnt want it to sit at stock height (bottom setting). After driving the truck over the weekend I noticed that the front simply doesnt sit as high as it did with the 1" spacers. How high is that middle setting supposed to be actually? Has anyone else experienced anything like this? and is this normal? I dont think the truck looks bad, but I really liked the way it sat before. The site that I purchased the 5100s from didnt specify what the middle setting actually was and I wouldve thought bilstein would have included something with the strut that would explain this.
    In case anyone is interested the measurement from the bottom/center of the tire to the bottom/center of the fender is 37 1/4" in the front, and 38" in the rear.
  2. Jun 14, 2011 at 4:59 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The middle setting is 1.25, but this is approximate, and I assume is based on a stock, new coil, which I will assume yours are not. I have seen some sites advertise it as 1, and other as 1.25. Also, this does not factor in the engine type, cab type, bumpers/bullbars, hood ornaments of excessive dimension, etc. So I think it may be a matter of "your results may vary," because it is dependent on the coil's condition and other stuff weighing down the front end.
    The settings are 0, 1.25, 2.5.
  3. Jun 14, 2011 at 5:52 PM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    i believe i have reached a decision. Tomorrow at work im just going to take it apart again and set it to the top setting and see what happens. I dont have really any weight adders up front other than the v6. And maybe my coils are a little worn, im not gonna worry about that right now tho. Thanks for your help
  4. Jun 14, 2011 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Here's something to consider. If the coil spacer you had on before is actually 1" thick, it would be considered a 2" lift spacer. You get approximately twice the amount of lift when a device like a spacer is placed in between the coils spring and the top mount.
    This math also applies to the billies. The actual distance between the highest setting and the lowest setting is not 2.5". Its more like 1.25" total. Yet that total ends up lifting the front of the truck almost 2.5".
  5. Jun 15, 2011 at 5:18 AM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    really? I never really thought of that, alright well im just gonna bump it up and see what happens. I will update tonight after i do it
  6. Jun 15, 2011 at 6:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The 4 setting notches for the spring perch on the 5100s = 0, .85, 1.75 & 2.5............If you are saying "middle" being next to top slot, that means you set the fronts on 1.75" of lift. So if you had 1" coil spacers before, that would be 2" of lift so yes, 5100s set at 1.75 would be lower than coil spacer 2" lift.
  7. Jun 15, 2011 at 6:33 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    ^ Second gen biliies do not apply here. 1st gen billies are what was mentioned by scocar. dam 2nd genners confusing the noobs
  8. Jun 15, 2011 at 7:04 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Damn me!!!!....missed that AND was after coffee even.
  9. Jun 15, 2011 at 7:04 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    the factory rake has something to do with it i believe. for example a 1 in rear lift will be the same as a 2in front lift or somthing like that. those figures arent right but it gives you the basic idea..
  10. Jun 15, 2011 at 9:29 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Yes, ye old factory rake. Mine was about 1 inch lower in the front (I got this truck with about 90k miles on it and worn suspension, so everything is relative).
    When I bought a new leaf pack, it was a 1.5 advertised lift. Actual with my cap on is about 1.25.
    I wanted to level the front, so this meant compensating for the 1.25 lift in the rear plus the ~1 rake.
    Just to clarify (or confuse, take your pick), the notches for the spring perch on the shock are each about .5 inch apart. However, this translates to 0, 1.25, and 2.5 lift out at the hubs. So, each .5 inch on the shock tranlates to 1.25 inches of lift at the hub.
  11. Jun 15, 2011 at 11:23 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :facepalm:You are quibbling (or confusing) over .125"........ OK. Having never held one of those in my hand, it was a pretty good guess... :smack:
  12. Jun 15, 2011 at 11:32 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    No no no. I was just expanding on what you said, and I have had them in my hand...
    A long time ago, you were the first person to lucidly explain how X lift at the shock translates to X+more lift at the hub that made me go A-ha, I understand this better now. :cheers:
  13. Jun 15, 2011 at 11:42 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I know, I was just messing with you. :eek: Are you left handed or right handed? :D
  14. Jun 15, 2011 at 11:56 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    I am ambi-derptious. :homer:
  15. Jun 15, 2011 at 1:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :bowdown:
  16. Jun 15, 2011 at 4:16 PM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    update, adjusted to the top setting. my front is now 38 1/8", rear 38". back to where I like it. thanks for the help everyone
  17. Jun 15, 2011 at 6:14 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    front high eh? well at just an 1/8th of an inch i guess it'd be hard to notice.
  18. Jun 15, 2011 at 7:54 PM
    mx04taco
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    im way happier being an eighth of an inch too high and 3/4 of an inch too low
  19. Jun 15, 2011 at 9:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    An 1/8' aint too bad. Glad to hear you figured it out man.
