installed 883 then unistalled them!
Discussion in 'Suspension' started by brelandt, May 23, 2011.
  1. May 23, 2011 at 3:39 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    OK, I found time to install the 883. I took a few pictures for everyone to see. The truck has a 3" spacer now and the distance from wheel lip to wheel well lip was 16" and after the install it was still 16" so the 883 gave me a 3" lift.
    Now for the bad news. Took the truck for a spin and the first thing I noticed was that the truck was bouncing on it's tires rather than the springs. Then I drove over the speed bump and the front came off the ground and bounced twice!
    Drove down the rode and every little dip sent the frontend off the ground them back down and bounce!
    So I drove right back around and took them off and put my old set up back on.
    So for all out there with a regular cab 4 cylinder prerunner. 883 are way too stiff!
    So I'm just going to put them up for sale on the board.
  2. May 23, 2011 at 3:44 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You got 883s with a reg cab.... Of course its gonna be stiff... You needed the 881s with your truck's specifications.
  3. May 23, 2011 at 3:47 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    did you put the 883's in WITH the spacers on top?
    nevrrmind I see the pics
  4. May 23, 2011 at 3:56 PM
    brelandt
    Terry
    Dublin, CA
    Well, there was talk back and forth on other threads about which was stiffer as the 882 was "heavy" and the 883 are "medium". Lesson learned!
    I was going for the same 3" lift as the spacer gave me and it looked like the 883 would do that. It did....LOL 881 is just too low for me. would still need a spacer.
