Installed 886's: now I am 1 inch off on drivers side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sierrahsky, Apr 9, 2011.
  1. Apr 9, 2011 at 11:34 PM
    sierrahsky
    sierrahsky [OP] Expedition Style
    Josh
    Reno
    09 TRD Tacoma V6 Ex Cab | Extreme Sierra
    So I am not sure why but I installed new 886's with 5100's and I am an inch off in ride height. What would cause this? I had 885 coils before and sat dead level? Please help!
    I am familiar with taco lean but the is just crazy.
  2. Apr 10, 2011 at 6:27 AM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Sorry if I missed it, but one inch off as in drivers side is lower or higher?
    What's your measurements? (center wheel cap to fender)
  3. Apr 10, 2011 at 9:18 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Is one of your bilstiens @ .85 ?
    Is that possible ?
  4. Apr 10, 2011 at 9:31 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Probably unlikely but make sure that the coils were the same length before you put them on. And hopefully they are both 886 - I believe the 885 and the 886 are the same length. The 886 are just a lot stiffer.
  5. Apr 10, 2011 at 9:35 AM
    sierrahsky
    Josh
    Reno
    A local shop in town assembled the coil and strut but appeared accurate.
    The coils are the right ones for sure and measure the same.
    The drivers side measures 1" lower.
    If the strut was set at .85 how could I ccomfirm that
  6. Apr 10, 2011 at 9:47 AM
    sierrahsky
    Josh
    Reno
    Another thing to mention is that when we put in the passenger side strut and coil it went right in, but the driver side coil was a pain. We were thinking that it may have been assembled wrong or something.
    Any chance my coil could be off?
  7. Apr 10, 2011 at 9:50 AM
    OZ-T
    Peter North
    British Columbia
    The driver's side was hard to get in , but it is the lower side ?
  8. Apr 10, 2011 at 9:51 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Normal.......add a toytec spacer
  9. Apr 10, 2011 at 9:51 AM
    OZ-T
    Peter North
    British Columbia
    1" ?
  10. Apr 10, 2011 at 9:52 AM
    sierrahsky
    Josh
    Reno
    Ya, odd. It was a total pain and is the lower side.
  11. Apr 10, 2011 at 9:53 AM
    sierrahsky
    Josh
    Reno
    No way is that normal I had 885's for less than 2 months and was dead level. I would accept 1/4 but a full inch. No way.
  12. Apr 10, 2011 at 9:55 AM
    OZ-T
    Peter North
    British Columbia
    I would suggest " normal " taco lean is about 1/2" , which is why the 1/4" spacer fixes it .
  13. Apr 10, 2011 at 9:58 AM
    sierrahsky
    Josh
    Reno
    So a full inch? What could add that much difference? I also have the 1/4 inch spacer just in case and so I I get left with the taco lean I can correct. But no way am I putting 4 of these on lol
  14. Apr 10, 2011 at 9:59 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    could you take pictures that would help out alot
  15. Apr 10, 2011 at 10:02 AM
    OZ-T
    Peter North
    British Columbia
    I would suggest you drive it and get the coils to do some work .
    Then re-measure your difference after everything has a chance to settle in.
  16. Apr 10, 2011 at 10:03 AM
    sierrahsky
    Josh
    Reno
    Pic of the back. U can see normal taco lean here. Measures 1/8 inch difference
  17. Apr 10, 2011 at 10:06 AM
    sierrahsky
    Josh
    Reno
    The drivers measures 1" lower.
  18. Apr 10, 2011 at 10:06 AM
    OZ-T
    Peter North
    British Columbia
    That's not normal taco lean .
  19. Apr 10, 2011 at 10:10 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Sandbags in the passenger seat for a month
  20. Apr 10, 2011 at 10:10 AM
    sierrahsky
    Josh
    Reno
    Agreed. Even if you look at the garage door line and compare sides.... its bad.
    So to go more in to detail.... We removed the strut and coil assembly, took it to my local tire shop and had them install 886's on the 5100's. When we picked them up they looked just fine. Got home and started to install the passenger side strut and coil assembly. Noticed it was not fitting in and was being a pain so we used the other shock coil assembly. Went in just fine. Then we took the shock that was being a pain and installed it on the drivers side.... this shock was even harder on this side but just barely lined up. In the lower control arm inside of the mount it sits kind of at a funny angle but we did not think any thing of it. Put the truck back together and BAAAM 1" off.
