Installed a 360 cam to my 2021 DCLB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChinaMan28, Sep 12, 2021.
  1. Sep 12, 2021 at 1:55 PM
    ChinaMan28
    ChinaMan28 [OP] Member
    Minneapolis
    2021 Tacoma DCLB Off Road
  2. Sep 12, 2021 at 3:29 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    That's pretty cool!
  3. Sep 13, 2021 at 11:45 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Nice.
    The other method for a front camera is dying/failing on me at the moment, I might just swap to this.
    I would assume there's no issue with this working on a 2019, other than ordering the correct harness
  4. Sep 13, 2021 at 2:15 PM
    ChinaMan28
    Minneapolis
    with the correct harnesses it would be pretty easy to do...it was hard for me cause no one has any good wiring diagrams, so I just got the harnesses to make things easier on me.
  5. Sep 13, 2021 at 2:19 PM
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Which front cam system do you run, and what is it doing to be "dying"? I had a front cam that out of nowhere randomly caused a system glitch and the manufacturer wasn't very helpful... They basically said check your wires.. nothing was wrong with them.
  6. Sep 13, 2021 at 5:46 PM
    Sand_In_My_Taco
    NOR*CAL
    I think it's CarPro?
    It no longer auto-opens the rear camera when in reverse, when it used it.
    It functions fine for front/rear if I manually toggle it.
  7. Jul 2, 2022 at 4:49 PM
    jfranks
    jfranks New Member
    OME LIft Kit, Leer 180 Shell, Prinsu Rack, Kicker 12in Sub and Key Amp
    I just finished the install on my 2020 DCSB TRD and it works great. Only issue is I don't have a manual for it and can't find the calibration or what appears to be a password blocking most of the settings.
    Even still I'd recommend doing it. The front and rear view is fantastic
    My1Yoda likes this.
  8. Jul 26, 2022 at 5:33 PM
    Ldplatt
    Ldplatt Member
    Lee
    I’m planning on doing this mod on my 2022. Do you think this same harness will work? Any ideas how to make it function similar to the mtm from the advanced tech package where you can cycle between front, rear and side cameras anytime?
  9. Aug 8, 2022 at 12:50 PM
    cxmoney
    cxmoney Well-Known Member
    2022 Wind Chill Sport
    did you ever do this? my 22 comes in next week and i am wanting to add a 360 cam system to it and so far this is the only thread ive really seen referencing adding a 360 cam to our trucks
  10. Aug 8, 2022 at 1:01 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Any pictures of what the integrated picture looks like (R side + front + L side). Is there any way to remove the graphic of the car, showing which camera is on?
  11. Jul 16, 2023 at 11:01 AM
    Potamus
    Potamus Well-Known Member
    Keith
    Oregon
    2022 Limited Blue Crush Metalic
    2.75 lift on 33s
    I know this is an older post, so I hope you or someone is still listening.
    Anyway, how did you calibrate the cameras?
