Installed a flatbed on my taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rangerfab09, Sep 16, 2015.
  1. Sep 16, 2015 at 8:35 PM
    jerent66
    jerent66 Well-Known Member
    Santa Cruz County
    TRD OFFROAD 6SPD MT 4x4
    True working truck :thumbsup:
  2. Sep 16, 2015 at 8:37 PM
    rangerfab09
    rangerfab09 [OP] Active Member
    san antonio
    09 tacoma
  3. Sep 16, 2015 at 8:38 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Just out of curiosity do your tires rub on the underside when going over large bumps or when it's weighted down? Before I put the AAL in mine it used to rub the underside of the bed at mild articulation. Seems to be the main issue with a true FLAT bed with no wheel arches.
  4. Sep 16, 2015 at 8:42 PM
    rangerfab09
    san antonio
    09 tacoma
    The hellwig 981 spring helper lifted the rear about 1.5" and the tires dont rub on big bumps. before it rubbed a little on big bumps. It all depends on how you mount the flat bed height. since it was my first time I winged it but so far it works fine. As far as heavy loads I would probably put about 500 lbs of feed but nothing more than that.
  5. Sep 16, 2015 at 8:44 PM
    rangerfab09
    san antonio
    09 tacoma
    Mind I still have stock springs....however if I upgrade to heavy duty 7 pack leafs then I can put a bigger load.
  6. Sep 16, 2015 at 8:46 PM
    RustyVT
    Vermont
    Sounds about the same as mine. Almost put spacers to lift the bed up an inch or so, but the AAL lifted it enough. Heaviest I put in mine is an old honda fourtrax atv. Even at that it sags the rear end big time. Pretty sad leaf springs on these Tacos lol.
  7. Sep 16, 2015 at 8:47 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I think it might look better in a long bed and some new wheels. But it's still pretty f'in cool.
  8. Sep 16, 2015 at 8:48 PM
    rangerfab09
    san antonio
    09 tacoma
    The do have a recall on them but havent received the 2nd remedy notification on when to take the truck for replacement springs.
  9. Sep 16, 2015 at 8:49 PM
    RustyVT
    Vermont
    ^ +1 on some new wheels as well, would look really nice.
  10. Sep 16, 2015 at 8:50 PM
    rangerfab09
    san antonio
    09 tacoma
    You know I always wanted a long bed but at the time it was hard to find one at a good price. I got mine a 09 with 100,000 miles for 15k in austin tx, and only one previous owner and they took care of it so I jumped on the deal.
  11. Sep 16, 2015 at 8:50 PM
    medic2230
    Murph
    Bama! Roll Tide
    Looks really nice! :thumbsup:
  12. Sep 16, 2015 at 8:50 PM
    RustyVT
    Vermont
    I actually had the recall for the springs done when I got a new frame. Honestly the new springs seem weaker if anything. They ride a lot better, but sag with anything significant in the bed.
  13. Sep 16, 2015 at 8:52 PM
    RustyVT
    Vermont
    You got a good deal on the truck too, that truck around here is a 18-20k truck easily. And that's not even dealer pricing. Clean first gens are still 5 digits here.
  14. Sep 16, 2015 at 8:54 PM
    rangerfab09
    san antonio
    09 tacoma
    I dont like these springs because they cant handle weight well. the truck drives like a car now that I put the spring helper. The stock springs create alot of axle wrap and wear out your carrier bearing. The helper springs it will stop the axle wrap or minimize it greatly. Mines about worn already. Rockauto sells it for $41.
  15. Sep 16, 2015 at 8:58 PM
    #35
    RustyVT
    Vermont
    Yeah good point, my carrier is smoked, squeaks terribly at anything under 15 mph. But it's original with 172k on it so I can't give it too much crap. Next real upgrade will probably be a decent leaf pack. But that helper spring doesn't sound like a bad idea
  16. Sep 16, 2015 at 8:59 PM
    #36
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Put a four wheel camper on that sucker! Looks awesome
  17. Sep 16, 2015 at 9:02 PM
    #37
    rangerfab09
    san antonio
    09 tacoma
    Thanks trowbocop :)
    The hellwig spring helper cost $95 free shipping off ebay. worth the money even for stock non work trucks the truck handles alot better on curves and just over all control.
    #37
  18. Sep 16, 2015 at 9:04 PM
    #38
    rangerfab09
    san antonio
    09 tacoma
    I was going to put a bolt on hunting tripod for photography and varmit hunting.
  19. Sep 16, 2015 at 9:10 PM
    #39
    RustyVT
    Vermont
    Yeah that's not bad at all price wise for helpers. I was all excited at first when I got my lift done because the rear gained over 4 inches of travel, then the springs settled :/ This is how it sits now, It started off about 2 inches higher in the rear. I'm just happy I'm not alone in the flatbed game around here haha. Even though yours is a hell of a lot fancier. I like the tripod idea too. Sadly not much for varmint hunting here unless you count squirrels.
