Installed a MicroByPass on my ilx-107 today
Discussion in 'Audio & Video' started by Gonzo1982, May 10, 2019.
  1. May 10, 2019 at 4:33 PM
    Gonzo1982
    Gonzo1982 [OP] Well-Known Member
    Tullahoma, TN
    2013 MG DCLB TRD Sport
    5100, OME 885, 1.5” Icon AAL, KO2 275/75/17
  2. May 12, 2019 at 9:04 AM
    Tacomaawayoflife
    Tacomaawayoflife Well-Known Member
    Roy
    Eugene, Oregon 97405
    2013 Tacoma 4x4 Limited Crew Cab
    Stock
    I have the same unit, love it, a little disapppointed that I cain’t view movies with the Interface hooked up to have steering wheel controls. But its a great head unit!
  3. May 12, 2019 at 9:05 AM
    Gonzo1982
    Tullahoma, TN
    What do you mean you can’t view movies?
  4. May 12, 2019 at 9:31 AM
    Tacomaawayoflife
    Roy
    Stock
  5. May 12, 2019 at 10:03 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
  6. May 12, 2019 at 10:18 AM
    Tacomaawayoflife
    Roy
    Stock
    That is correct!
  7. May 14, 2019 at 4:09 PM
    Gonzo1982
    Tullahoma, TN
    Well I can adjust the settings that previously required me to do the brake while moving now.
  8. May 14, 2019 at 6:07 PM
    Tacomaawayoflife
    Roy
    Stock
    Are you using the Idatalink or not using the steering wheel controls?
  9. May 14, 2019 at 6:09 PM
    Gonzo1982
    Tullahoma, TN
    Yes, using the Idatalink maestro rr
  10. Oct 22, 2019 at 7:19 PM
    Jtaoj0
    Jtaoj0 Well-Known Member
    Hi I am in the process of installing an Alpine ILX-207. Using a Crux interface. I also have the MicroBypass. Curious how you installed on the ILX-107. Black tapped into black. Blue/white tapped into blue/white. Did you use yellow black or yellow blue to the the park brake and did you cut the harness or tap into? If you cut, did you cut before the plug goes into the plug to the truck harness? Thanks!
