Installed AAL's, somethings wrong!
Discussion in '1st Gen. Tacomas (1995-2004)' started by wncjim, Oct 25, 2014.
  1. Oct 25, 2014 at 12:19 PM
    wncjim
    wncjim [OP] Active Member
    Western NC
    I need help. The install went well but now the suspension feels solid, like a go cart. It lifted the rear almost 4", they were supposed to be 3" and I expected 2 or 2.5" because my leafs had a slight frown.
    What could be the cause?
  2. Oct 25, 2014 at 12:25 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Pictures would help a bunch in figuring out what's going on.
  3. Oct 25, 2014 at 12:26 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Did you remove your overload spring? Some of those AALs assume that you will remove that thing when you install the AAL.
    I had AALs on my last Tacoma, and the rear suspension felt like a rock. I needed it for the weight I was hauling, but the truck rode like shit after I installed them. I will definitely go with a progressive AAL if and when I put one on my current Taco.
  4. Oct 25, 2014 at 12:31 PM
    wncjim
    Western NC
    I kept the overload leafs. I put the aal above the overload and under the other leafs.
    I will try to get a couple of pic's.
  5. Oct 25, 2014 at 1:02 PM
    wncjim
    Western NC
  6. Oct 25, 2014 at 1:09 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Thats a beefy AAL
  7. Oct 25, 2014 at 1:10 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That's one hell of a thick AAL. Usually, they're the same thickness as the other leaves. Where'd that come from OP?
  8. Oct 25, 2014 at 1:52 PM
    wncjim
    Western NC
    I got them on Ebay, they are called "Tuff Country".
    Maybe they sent me the wrong kit? These must for an F350 dually!
  9. Oct 25, 2014 at 1:59 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    That's the aal that's usually used for 1/2 ton and up trucks. You'd be better off getting a wheelers aal or making your own.
  10. Oct 25, 2014 at 2:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    :rolleyes: Should've at least gotten a semi-reputable brand like Toytec or Pro Comp.
  11. Oct 25, 2014 at 2:17 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    + 1 On that, you get what you pay for?
  12. Oct 25, 2014 at 2:17 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    Yea. That won't settle much or ride smooth IMHO.
    Only fix for that is a different AAL. If you have a bad back, don't even think about larger(e rated) tires.
    The sharp arch that has added to your factory leafs may even be adding lots of stress to them. They look like a V rather than a gradual U. If you you are getting 4" out of that your oem shocks are likely topping out over speed bumps too.
  13. Oct 25, 2014 at 3:38 PM
    wncjim
    Western NC
    Yeah, these things are being replaced. I'm searching for alternatives now.
    At the moment I think I may go with Wheelers 2" aal and bilstein 5100's for the front.
  14. Oct 25, 2014 at 3:44 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    With a rear lift I suggest getting new shocks , like someone else said , you will fully extend your shocks going over bumps and it will ride like poop and will mess up your shocks
  15. Oct 25, 2014 at 3:48 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    get a 3 leaf progressive aal. They last a lot longer, better ride and hold more weight. I have Icon and love it but wheelers also makes a good one I have heard. So worth the extra money, raised my back end up 2.5 inches exactly, well 2.25 over stock since I have a canopy
  16. Oct 25, 2014 at 8:19 PM
    KenLyns
    Belly of the Beast
    @wncjim: Now do you understand that modding the Taco is a slippery slope? :D Have an end goal in mind (pavement queen, rock crawler, expedition, desert jumper) and buy parts toward that goal.
    3 leaf progressive AAL is about halfway in cost between a basic AAL and a full upgraded leaf pack.
  17. Oct 25, 2014 at 8:49 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Look at my build but with the Icon 3 leaf AAL I also got a 1 inch block. The U bolts that come with the Icon AAL are long enough to also add a 1 inch block without needing longer ones. Also go through downsouthmotorsports.com for any shocks (may also have the 3 leaf AAL too), best deal by far
  18. Jan 8, 2015 at 1:18 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Try a Dastar or a tuff country but go for the longest one you can get, I got a Daystar AAl abot 30"+ and it gave me about a 2-1/2" lift and doesn't sag unless I have around >500# in the back. Doesn't ride too stiff, and should last until I can afford OMEs.
    I picked mine up on Ebay from an outfit in Utah.
  19. Jan 9, 2015 at 9:22 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    That thing could crack your leaf pack :eek:
  20. Jan 9, 2015 at 7:12 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Im using the skyjacker softride aal. They get progressively thiner as you go out from the center. So far the ride is pretty good but my oem length shocks are topped out.
