Installed All Pro's 3" leaf an they are STIFF!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clzay, Oct 17, 2011.
  1. Oct 17, 2011 at 8:38 PM
    Clzay
    Clzay [OP] Well-Known Member
    Clay
    Modesto, CA
    Cali Lean n mean... ha
    I'm running Camburg spindles an coilovers, so I'm up about 5inches in the front and needed a nice leaf set to match the front without using a block
  2. Oct 17, 2011 at 8:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  3. Oct 17, 2011 at 8:48 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I've got a similar set up. Camburg spindles with 5100@0.85 for around 5" up front. The all pro 3" standard pack gives the truck a real nice stance and a good set of shocks valved to your liking gives it a good ride.
  4. Oct 17, 2011 at 8:50 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i had the all pro standards and thought they were super stiff as well, ended up working out a deal with another member for his deaver j66 pack and some $$ and im so much happier but overtime they will settle down and once you load anything in the bed the deavers start to sag like crazy!
  5. Oct 17, 2011 at 9:15 PM
    Clzay
    Clay
    Modesto, CA
    Here's how she sits... IMG_04911_f0ffd8b6dff161b0e22257f6fd216507cf382d7a.jpgIMG_04871_0786bbc1ce84aa7815e56cd262be7c92e024a3a6.jpg
  6. Oct 17, 2011 at 9:16 PM
    rcfreak201
    ^badass truck man! im really diggin it, different than the usual black rims
  7. Oct 17, 2011 at 9:18 PM
    Clzay
    Clay
    Modesto, CA
    and the rear shocks i'm running...IMG_04751_70ef4a2f72250110143ba68329fd678b1443d0cc.jpg
  8. Oct 17, 2011 at 9:19 PM
    Clzay
    Clay
    Modesto, CA
    thanks! I know i've been wanting to jump on the "black rim bandwagon" but I just can't seem to get myself to pull the trigger
  9. Oct 17, 2011 at 9:22 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I just installed mine, but having OME's before I know I have to wait a bit for them to break in.
  10. Oct 17, 2011 at 9:23 PM
    rcfreak201
    keep them, if anything try fitting some bigger tires but im afraid you will rub too much, probably 285 or 305 is your safest bet with minimum trimming, and stock fenders. if i were you i would just give the leafs some time, they should break in even though all pro claims they are already broken in when purchase. specially with that dirtbike, the deavers suck when i load my bike.
    they ride really really soft but start to sag when i load my bike plus i have two spares on the tire carrier at all times which reduces the life of them by ALOT
  11. Oct 17, 2011 at 9:41 PM
    Clzay
    Clay
    Modesto, CA
    Im running a 285 right now on a 17" wheel and don't wanna go any bigger. And thanks for all your guys thoughts and input, i'm gonna run her like this for a little and see how it turns out.
  12. Oct 18, 2011 at 6:19 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Well there's part of your problem, you have no bumpstops!
    Do yourself a favor and go down to O'Reilly and pick up a set of these:
    http://www.oreillyauto.com/site/c/d...ck=Search_N0958_1382723_-1&pt=N0958&ppt=C0361
    Then drill a hole in the factory strike pad that is mounted to the frame and install these. They'll strike off your flip kit. Trim your flip kit bolts so they don't strike the frame.
    Every time you bottom the rear end out, you're slamming metal on metal. Do it enough and you're going to bend/crack your frame.
    Or you can buy the Timbrems. I have a well broken in set I'd sell you at a good price if you want to go that route.
  13. Oct 18, 2011 at 7:02 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Yeah I was gonna mention that. I went with the timberens and will be breaking them, the leafs, and the new kings in the weekend! OP, try going wheeling with some weight in the bed. Should help.
  14. Oct 18, 2011 at 10:17 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Correct valving on the shocks is very important to performance. Do you know if they are valved correctly for your application?
  15. Oct 18, 2011 at 10:23 AM
    #35
    Clzay
    Clay
    Modesto, CA
    I agree I do need bumpstops, but the leafs havent even came close to bottoming on the frame rail.. Maybe after they settle and break in. So if I decide to keeps these leafs I'll cut down the extra threads showing from the u bolts and install some bumpstops :) An as far as valving goes they're just what Allpro sent me... But it's just the springs being to stiff as of now
  16. Oct 18, 2011 at 10:27 AM
    #36
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    VERY FAR from a similar set up. they got 5 grand plus just in the rear end of their truck. unless thats not crazy money wise for you.
    you need a bed cage... SDHQ charges like 4 grand for that. you can get one dont for easily under a grand through garage fab
    some nice tripple bypasses-1600-2 grand (used)
    bedsides-600
    air bump stops-440
    different front and rear mounts for the leafs, the leafs mount under the axel. longer shackles, alot run 12 inch shackles. 1300
    then you need all the fab work done, plate and box the frame.
    very far from a similar set up dude...
    they are pulling 18 in of travel usually and you got like 11.
  17. Oct 18, 2011 at 11:00 AM
    #37
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Again as others have said those are long travel setups, and are horrid for loading anything in the bed... Sure they soak up a lot and are designed for jumping (usually), they're not designed for towing or bed capacity...
  18. Oct 18, 2011 at 12:13 PM
    #38
    Mxpatriot
    Want to bet?
    These trucks were not designed with uptravel in mind and a thick leaf pack only decreases up travel. You could bottom out the rear end on a harsh speed bump, let alone going offroad.
    It's $15, takes 5 minutes to install, and protects the most expensive part of your truck (the frame).
    Just my $0.02
  19. Oct 18, 2011 at 12:17 PM
    #39
    Clzay
    Clay
    Modesto, CA
    I totally understand the long travel set ups, I was just thinking and hoping that the All pro leafs would perform like the Deavers being a little softer and not so harsh over bumps. My stock tsb leaf pack absorbed bumps better than these so far, I feel like all these did is lift my truck just to be higher... An I'm not going for just the "look of being higher" I wanted to soak up some ground as well
  20. Oct 18, 2011 at 12:22 PM
    #40
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Op, I'll be taking my new rig out this weekend to break it in. I'll have my full toolbox, full cooler, and a recovery box in my bed. If I get time I should have my CBI rear on as well. I'll let you know how things go, but I'd get the timberens if you wheel.
