Installed bed stiffeners, is it necessary to treat the drilled holes to prevent rust?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trucks2019, Sep 8, 2022.
  1. Sep 8, 2022 at 8:16 PM
    Trucks2019
    Trucks2019 [OP] Well-Known Member
    I installed some bed stiffeners and wondered if it is necessary to treat the drilled holes with an anti-rust spray? They have washers on either side and are tightly bolted. I am hoping not (as the stiffeners are already installed) but if some treatment is needed, would fluid film aerosol can work? I understand there is no curing time which would be ideal to complete the work
  2. Sep 8, 2022 at 8:19 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Anti seize would help.
  3. Sep 8, 2022 at 8:20 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    Where you live
    How long you will keep your truck
    How much time you have
    How much primer or paint costs
    Friday posts
    soundman98 and BigEasy like this.
  4. Sep 8, 2022 at 8:34 PM
    Trucks2019
    Live in the PNW. It’s a 2021 Tacoma and planning on owning long term I think.
  5. Sep 8, 2022 at 8:40 PM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    I also live in the PNW... I back painted the drilled holes when I installed bed stiffeners on my 2015... Just seemed prudent given the weather conditions here. YMMV
  6. Sep 8, 2022 at 9:00 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Why would you not paint the bare metal edges of the holes you drilled?
    BigEasy and alwaysHI like this.
  7. Sep 8, 2022 at 9:09 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    CAUSE I FORGOT AND DON’T WANT TO TAKE IT ALL APART AGAIN!
    That and I cut the fuck outta my hand putting it all back together. Lessons learned for the next truck I suppose
    GrizzledBastard likes this.
  8. Sep 8, 2022 at 9:21 PM
    Huha
    Huha Well-Known Member
    2017 Tacoma trd off road
    Arm rest organizer, dash cam, popnlock, anytime backup cam
    Make sure you clean up the all the metal shavings because if they're sandwiched between the bed and the bed stiffeners, you'll get a bunch of small rust spots where those are at. I discovered this when I removed my bed stiffeners and it wouldn't hurt to fluid film or paint those holes for peace of mind.
    BigEasy and AmateurTaco1313 like this.
  9. Sep 8, 2022 at 9:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I personally wouldn’t worry about it if they are already installed.
    If you are worried about it, and don’t want to take it apart.
    Maybe a clear coat touch-up pen and go around the bolt and washer head.
    Yeah, it might look “funny”. But it should help a little.
    Again, it’s not something I’d worry about. I’d worry about something else. Like the frame.
  10. Sep 8, 2022 at 10:03 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Since they're in, maybe loosen significantly and Fluid Film the bajeezuz out of them so it penetrates the threads?
    Thanks for the reminder. I've got a set of Total Chaos stiffies to install this week on my rig. I'll probably repaint the affected areas and do some "proofing" to them, as well. ;)
  11. Sep 8, 2022 at 10:16 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Okay, I understand you cut yourself. But seriously, just do it for your investment that you put into your vehicle.
    It’s not hard to uninstall vs reinstall.
    i only say this cause I’ve done the stiffeners, and hammer hangers recently. The stiffeners are no where near the difficulty as the hammers.
    Just do it
    if it makes you feel better - I recently did my trans oil. I went to empty my collection container and realized I forgot to replace my crush washer.. Anyways - before running the truck on the road I decided to wait till it cooled off, and repeat the procedure and change the crush washer.
    a few hours worth of my time is a better peace of mind. So I say, just do it.
    AmateurTaco1313 likes this.
  12. Sep 8, 2022 at 11:22 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    lookup POR 15.
  13. Sep 9, 2022 at 4:42 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I think it depends…
    1) is the rest of the truck? Yes do it No you don’t need to start now.
    2) do you like to finish a job? Yes do it. No don’t ask the question you don’t finish things
    3) are you keeping the truck? Yes. Do it. No others will see how the truck has been cared for.
    pick one
    BigEasy likes this.
  14. Sep 11, 2022 at 9:03 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    so a normal vehicle project then!
    if i don't cut myself at least once while doing anything even as simple as an oil change, i keep doing stuff till something happens.
