installed billys 5100 now want more
Discussion in 'Suspension' started by KaliTaco, Oct 12, 2008.
  1. Oct 12, 2008 at 9:17 PM
    KaliTaco
    KaliTaco [OP] Well-Known Member
    i just installed the front billys and set them at 2.5. but kinda wanna go higher. give me the full 3 inch! so what can i do?
    set the billys to stock setting? and get ome 3 inch front coils?
    if that is the case i just wasted 170 on the billys because the ome front coils will work for the stock shocks.
    any other option that i probably missed?
    toytec sell a 3/4 top front spacer kit...would that work. that would be 3 1/4 inch lift in the front. on stock shocks
  2. Oct 12, 2008 at 9:34 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  3. Oct 12, 2008 at 9:36 PM
    KaliTaco
    i just finished and its dark already. you know what time it is? ill upload some pics tomorrow. but i guess you dont have any kind of answer beside wanting to see pictures.
  4. Oct 12, 2008 at 9:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    get the ome coils. yes...they will work with the stock shocks....but, the 5100's will ride alot better.
  5. Oct 12, 2008 at 9:44 PM
    KaliTaco
    thanks for the reply. toytec 3/4 inch top plate spacer will not work right? billys adj 5100 recommand not to use with spacer but would it be a problem?
  6. Oct 13, 2008 at 7:23 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    or buck up and buy the coilovers for the 5100's from toytec. i think they're adjustable to 3-3.5".
  7. Oct 13, 2008 at 4:17 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    3-3.5" lift,Yes they are.:)
  8. Oct 15, 2008 at 9:59 AM
    sooner02r1
    sooner02r1 Well-Known Member
    Get OME coils and run the bilsteins at the stock setting. Should be 3". Do NOT run spacers with the bilsteins. You didn't waste money, the stock shocks will ride like crap and will destroy themselves over time with the OME springs.
  9. Oct 15, 2008 at 10:08 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    The OME coils come with a top spacer plate.. are you talking about that spacer? or the 3" spacer lift?
  10. Oct 15, 2008 at 10:10 AM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Show some pics!!!
  11. Nov 24, 2008 at 7:52 PM
    jjacks
    jjacks Member
    Grainger Co. TN
    08 Dbl. cab Trd 4x4 Silver
    Steelcraft brush guard, afe air filter, Lift kit (coming soon) Maybe a throttle body spacer
    quik one here... Do i need ucas after doin 5100's up front? Will I some day, because others on this site say that after so long your tire wear screws up. Am I completely off mark on this or what?
  12. Nov 24, 2008 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you dont have to have uca's.....but they will help in getting your total alignment back to where it needs to be. i think they are a good idea.......damn...i need to save up for a pair!!:D
  13. Nov 27, 2008 at 10:09 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I would have to agree with tacomaman. I just got my TC UCS's the other day because I have heard from alot of people that after I put my lift kit on that the alignment wouldnt be right until I got some UCA's. They were a little pricy but lots of people said it would be worth it. I will have my lift on here in a few weeks so I'll post another thread when its ready and post some pics. You can check my profile to see what kind of setup I have and what I am going to get installed.
  14. Nov 27, 2008 at 11:18 AM
    bwhit
    bwhit Well-Known Member
    07 4x4 Double Cab
    i have the billy's set at 1.75, haven't had the alignment done yet cause i'm waiting on wheels and tires. Are UCA's necessary at this height????
  15. Nov 27, 2008 at 1:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    At 1.75" lift, its a judgement call. See how your alignment numbers look, and how it drives.
  16. Nov 27, 2008 at 10:14 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    I was in the same boat as you, after having the 5100s for over a month I decided I wanted a little more. I just ordered a Toytec coilover conversion kit and some total chaos UCAs yesterday :D.
  17. Nov 28, 2008 at 10:04 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    The UCA's are an absolute MUST. Think about it you now have an additional 3" of lift on a ball joint that has been designed to run at a flat operating angle. Think about the droop travel, the reason for the aftermarket UCA's is to correct the improper ball joint angles associated with additional lift. Without the UCA's your stock BJ's are goinf to be toast. The real kicker is once a BJ goes, you cant replace just the BJ. They only offer a FULL REPLACEMENT UPPER ARM! Also stacking the Bilstiens with a spacer is a bad idea. Either way you go, new springs or a spacer its going to add a bunch of preload to the spring. The OME springs are made taller and with an additional 50lbs of spring rate I belive. Add that to a coil spacer that again adds preload to the equasion and what you get is a crappy ride. Best bet is to co with a adjustable coiul over that was designed with the adjustability to go 3" higher without adding too much preload.
  18. Nov 29, 2008 at 3:26 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    What up D/S? Thanks & Welcome to TW.Glad you're here.:D
  19. Nov 29, 2008 at 9:49 AM
    bwhit
    07 4x4 Double Cab
    I just bought my 5100's from you guys, set them at 1.75. What do you think about UCA at this height??
