Installed Bilstein 5100s and Toytec AAL with Carrier Bearing Drop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Simon2150, Jun 10, 2009.
Do you like it?
  1. Love it!
    24.2%
  2. Hate it!
    0 vote(s)
    0.0%
  3. Will look better once rims/tires are installed.
    66.7%
  4. WTF BBQ?!!
    9.1%
  1. Jun 10, 2009 at 7:25 PM
    Simon2150
    Simon2150 [OP] Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I went to Krawltex today to have my lift installed which included 5100s and AAL with carrier bearing drop. I tried to have the 3 degree shims installed; however, the guys working on the truck confirmed they were uncomfortable with the clearance of the centering pin with the shim. I'm trying to get them to forward me the pics they took and they sent it to Toytec for confirmation of what they found. They said the hole in the middle of the shim was too big and I needed to find one that wasn't as big (they were complimentary though on the no slip/grip design of it).
    To note, I can feel the slightest of vibes between 1-7mph and again between 18-27mph. Installer took a test drive with me and said he felt confident that the right fitting shims would correct the problem. Can anyone recommend some other shims?
    I'm very happy with the look and will be even freakin' ecstatic once the vibe problem is corrected.
    On to the pics. Packages arrive last week:
    Here is what it looked like yesterday:
    After lift installed:
    My driveway is on an incline, so it's not that really noticeable. I measured it to be only 1/8" higher in the back, so it does sit pretty level. That's all the pics I have for now. I will take pics of it on level ground tomorrow.
    XD revolvers and Nitto TGs will be installed either later this week or next week (already ordered from 4WP and deposit placed). This thing is screaming for bigger tires.
    Let me know what you all think and what kind of other shims can be put on there.
    1 more thing, is it normal for my ucas to be at this angle (sloping down towards the tire)
  2. Jun 10, 2009 at 7:37 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    looks great, will look better once you put new wheels on, first question. did you drive the truck without the cb drop. I havce a slight vibe below 5 mph and that is all, no cb drop. when i put the 3* shim it made it worse, toytec sells 2 1/4 shim.
  3. Jun 10, 2009 at 8:25 PM
    Simon2150
    Austin, TX
    No I didn't drive it without the cb drop. The installer (who is also the owner of krawltex) felt that the cb drop combined with the shims is a good thing to have. I'm going to leave it for now and hope I can find the right 3 degree shims. when you installed your shim, how much clearance did you have on the centering pin head?
    krawltex felt that it was a potential safety issue and that's why the didn't want to install it. i trust their opinion. they have a pretty big offroad following.
  4. Jun 10, 2009 at 9:28 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Looking good man! Now about the UCA's, I was always told to go with the uni-ball ones so I bought some TC UCA's to go with my 3" lift. The stock ones just always looked a little off to me cause they were at such an angle! But I have also heard from others that the stock ones worked just fine.:cool:
  5. Jun 10, 2009 at 9:49 PM
    bajamoon
    STEVE
    Whittier
    you mean uni-ball uca's, there was enough room for the pin that i was not worried about it, the 3* mad my vibes go all the way to 20 mph instead of 5, i am going to put in the cb drop next week when i get it, i will post results when i get it. Remember that every truck is different, so sometimes nothing is needed and in my case it may be a combination of things.
  6. Jun 10, 2009 at 9:54 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah thats what I meant.:rolleyes:
  7. Jun 10, 2009 at 10:00 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Looks good. Now for the new shoes!
    How is the ride at 2.5?
  8. Jun 11, 2009 at 4:33 AM
    Simon2150
    Austin, TX
    I can definitely tell that it has stiffened up some, but I like it that way, feels like a truck (not a car). Also, I really have to make myself feel the vibes. They aren't that bad and under normal acceleration, barely noticeable. It's when I acclerate at a real slow rate that I can feel it ever so slightly.
  9. Jun 11, 2009 at 4:34 AM
    Simon2150
    Austin, TX
    got a pic of how your tc ucas look? i'd love to get some, but with new rims & tires on the way, money is ultra thin right now, lol...
  10. Jun 11, 2009 at 6:13 AM
    bajamoon
    STEVE
    Whittier
    here are my tc uca's with sway a way 2.5 coil overs.
  11. Jun 11, 2009 at 6:30 AM
    Simon2150
    Austin, TX
    drool... i may have to do this @ some point. yours is not at the angle mine is and that looks better.
  12. Jun 11, 2009 at 8:34 AM
    Simon2150
    Austin, TX
    Updated pic during install, here is the toytec 3 degree shim.
    for reference, this was taken on the passenger side with the skinny side of the shim pointing towards the front. not sure that you can see the centering pin head in the pics, it's barely visible, hence the safety issue. any comments?
  13. Aug 16, 2009 at 9:04 PM
    countryboy22
    countryboy22 Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    hey guys I am looking to buy billy's for all 4 corners and a set of toytec aal for the rear. I would want to set the front ones at 2.5. And i am wondering if it would sit level?
  14. Aug 16, 2009 at 9:55 PM
    bajamoon
    STEVE
    Whittier
    should be pretty close, maybe a slight rake in the front but it would be close.
  15. Oct 6, 2009 at 5:19 AM
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    i just put that setup on mine two days ago and it sits pretty damn close to level
  16. Oct 6, 2009 at 1:05 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Looks great man! Can't see how anyone can not like that
  17. Oct 6, 2009 at 1:23 PM
    beginah
    beginah Well-Known Member
    I have my billys set at 2.5 and i have a slight shudder at 5-10 mph and slight vibes at 40 mph. I hoped that installing the 3* shim from toytec and the carrier drop would help, but it hasn't.
  18. Oct 6, 2009 at 10:19 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 tundra crewmax trd
    tacoma sold 11/13/13 Not much on Tundra yet, just Husky Weatherbeaters front and back
    looks good, i want to lift my truck, just not sure which way.. keep us updated w/how things are working out
  19. Oct 7, 2009 at 12:26 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    thats what I get around 50-55mph if im expecting it, nothing major and it goes away.
    thats with no carrier drop and a 2* steel shim. the hole was small and I got new(longer) centering pins, so it was part of the leaf pack now.Both leafs and shims are from Deaver.
  20. Oct 7, 2009 at 12:39 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    I like the look. Taller is better, but not that tall. Just need bigger tires to finish it off.
