Installed! Camburg Spindles
Discussion in 'Suspension' started by Kenny650, Jul 23, 2009.
  1. Sep 8, 2010 at 12:23 PM
    #61
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    How about a 2" block. Make it level
  2. Sep 8, 2010 at 2:10 PM
    #62
    hockeypoor
    hockeypoor Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    I was talking about wheel spacers. The reason I want spacers and lift spindle is so it will fill up the All pro fenders. I am doing the rear lt first. Then the front later. Long story short Because that is how I want to :)
  3. Sep 8, 2010 at 2:33 PM
    #63
    bajamoon
    STEVE
    Whittier
    so what you are saying is you want glassworks fenders
  4. Sep 8, 2010 at 2:35 PM
    #64
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Ya I would definitely go with Glassworks if you're running spindles with spacers. Look at my pic I posted and you can see how much just spindles kick it out.
  5. Sep 8, 2010 at 3:27 PM
    #65
    hockeypoor
    I want the allpro glass fenders. I think they are a little cleaner.
  6. Sep 8, 2010 at 4:26 PM
    #66
    bajamoon
    STEVE
    Whittier
    Glassworks. looks the same to me minus the spray can paint job.
  7. Sep 9, 2010 at 6:42 AM
    #67
    SWTACOMA
    SWTACOMA Member
    Paul
    NM
    2005 SR5 DBL CAB 4WD
    Are you running the stock springs in the front with the bilsteins? Where did you purchase your spindles?
  8. Sep 9, 2010 at 7:41 AM
    #68
    1BlkT
    Ty
    90603
    Hey bud you have a 4x4 it looks like based off your info.
    Spindles only will work for 2wd prerunners.
  9. Sep 9, 2010 at 8:02 AM
    #69
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    REALLY!? So I could get a 4 inch lift using spindles, and still have a factory ride? Throw on some 5100s at all 4 corners front set at 0 and it be even a better ride right. how do you level it out.
  10. Sep 9, 2010 at 8:05 AM
    #70
    1BlkT
    Ty
    90603
    Yup, if you just install spindles the ride will not change.
  11. Sep 9, 2010 at 8:08 AM
    #71
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You can't use those spindles on a 4x4 :cool: they are for PreRunners.
  12. Jan 24, 2011 at 11:04 AM
    #72
    dubstar2003
    dubstar2003 Active Member
    Jacob
    Texas
    2007 PreRunner
    Projector Headlights Westin Bullguard Westin Nurf Bars Custom Hood Lifts Black'd Out Badges Alpine Headunit w/Ipod Satoshi Grille 6000K HID'S BILSTIEN 5100'S UP FRONT
    Alright Gents,
    I've been up and down TW trying to find info about the Camburg Spindles. I don't offroad other than the beach, so mostly lifting for bigger wheels.
    My main questions are:
    1) Do I have to run 5100's all the way around? If so, what setting in front? (I've seen people set @ 1.75)
    2) What rear setup?
    I seen people running all pro leaf pack, deavers, but from their pics it look like they still have the BRO LEAN, which I don't want. I don't want spend a fortune on reservoir shocks for the rear or a custom leaf pack since I don't wheel.
    3) Will an AAL and longer shocks work in the rear? (5125's) or lift blocks?
    I appreciate the help.
  13. Jan 24, 2011 at 11:10 AM
    #73
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    1) you can run stock shocks with the lift spindles, it will give you a flat 4" lift with the camburgs and 3.5" lift with the TC spindles. If you want to go higher than the spindle lift with the spindles, then you can get billies and crank them up or get coil overs which is the best choice.
    2) rear set up you can go all pro 3" lift springs or deavers or whatever to get 3".
    3) AAL and longer shocks will work, but dont go blocks.
  14. Jan 24, 2011 at 11:11 AM
    #74
    1BlkT
    Ty
    90603
    You don't have to run 5100's up front with the spindles, just keep the stock components. If going with an AAL try to get as much lift as possible to level it out, I know I've seen 2'' ones before that should get you pretty close.
    x2 on no blocks. My brother had a leaf pack that started sagging and tossed a block in there, immediately took it off after one lap around the block. It was giving him a major vibration for some reason.
  15. Jan 24, 2011 at 1:44 PM
    #75
    dubstar2003
    Jacob
    Texas
    2007 PreRunner
    Thanks boys both your rides are sick!!!
    Had a few other questions
    blackhawke
    If I go the AAL and longer shocks, do you have an idea of the length of shock I would need to go with? ie 5125's??
    I plan to upgrade to billies in the future, but for now I will roll with the stock billies. Once I do upgrade if I crank up the front billies, I assume I would need to upgrade my UCA's????
    1BlkT
    Where did you get the Deavers? How much? I been searching, but just pulling up other forums.
    Thanks again!!!
  16. Jan 24, 2011 at 2:07 PM
    #76
    1BlkT
    Ty
    90603
    I got my Deavers from a guy on craigslist, they were pretty beat but I only paid $200. I then dropped them off at Deaver and had them re-arch them, new bushing and add another leaf for about $250.
    New they are pretty expensive, I'd check out All Pro or even Alcan if your aren't set on any particular set yet.
    When I first did spindles I went with an AAL just until I could find a good used set of leafs to switch to so I didn't pay full price.
  17. Jan 24, 2011 at 3:42 PM
    #77
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    youll only need new ucas if after the spindles, you crank up the billies to get 3" of lift out of them. but then youd have 7" of front lift. spindles keep the stock geometry. so by setting the billies to a lower setting shouldnt affect the need for ucas.
  18. Mar 26, 2011 at 5:12 PM
    #78
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    How much lift in the rear do you have? What size tires do you have in this set up? Thanks!
  19. Jul 18, 2011 at 1:06 PM
    #79
    bLaCkMETALTaCoMA
    bLaCkMETALTaCoMA tacomood
    Sergio
    Paraguay, South America
    Short Bed 06 TRD Sport 6 Speed Manual 4.0 V6
    ---Murdered Out--- **********-.tactical Unit Calibrated to KiLL.-*********** -Debadged -RBP Grille RX Black -RBP Black Plate Frame -RBP Eshaust Adapter 3.5" Black Tip, Two Tone Logo w/ Red Star -Blacked Out Third brake light, Radiator frames, skid plate. -Pioneer + Backup Camera -33 Mud Grappler + 20 Inch RockStars -Bulletproof side windows -AT35 Tint Front & AT15 Tint All Corners -K&N Air Intake -TRD Skid Plate -Aftermarket Angel Eyes Headlights + T-Rex Eyelids -Rear LED Lights -URD short shift knob -Billies 5100 all around, front set @ 0.85 w/ eibach coils + 1.5 AAL + Total Chaos UCA's -Redline hood and back door struts -Flex Pod Gauge Mount (volts & oil temperature)
    i have a 4x4 and cant put spindles??? daaaaaaaammmmmmmn!!!!!
  20. Jul 20, 2011 at 9:17 AM
    #80
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
