Installed Doug Thorley headers and a flowmaster exhaust. now runs like shit
Discussion in 'Performance and Tuning' started by 97yota4wd, Jun 24, 2011.
  1. Jun 24, 2011 at 4:52 PM
    97yota4wd
    97yota4wd [OP] Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    so i installed doug thorley headers last night, and i had a exhaust leak but didnt have time to fix it, drove to work and dropped it off at a muffler shop, about 1/4 mile before i got to the muffler shop my check engine light came on. but they fixed my exhaust leak and put on a flow master exhaust. i got my truck back and it started to run like shit, idled rough, was noticebly slower.
    so i went to o reileys to see what the check engine light was for, he said it was a 02 sensor reading rich.
    he told me i can try to unplug the negative terminal of the battery and let it sit for 15 minutes or so and put it back on and it might fix it might not.
    he also said if i drive it for a couple days the system could remap its self and run okay.
    do you guys have any ideas/thoughts about this? thanks!
  2. Jun 24, 2011 at 5:36 PM
    97yota4wd
    Eric
    Mesa, AZ
    no it doesnt
  3. Jun 24, 2011 at 5:43 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    maybe.. i dont see how we would have damaged the sensor cause we didnt drop it or anything
  4. Jun 24, 2011 at 5:45 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    also eric id check back with that shop and ask if they even checked everything after the install cause it was fine last night and now it doesnt? i would think they should be making it right you know?
  5. Jun 24, 2011 at 5:46 PM
    97yota4wd
    Eric
    Mesa, AZ
    yeah i know its pissing me off. im going to put the negative back on the battery and drive it in a couple hours and see if that fixes it....
    is there anything else i can do to see if the code will not pop up again?
  6. Jun 24, 2011 at 5:47 PM
    97yota4wd
    Eric
    Mesa, AZ
    well the ceck engine light came on as i was pulling INTO the shop so it couldnt have been anything they did right?
    they didnt touch the o2 sensors or anything
  7. Jun 24, 2011 at 5:47 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    well call the shop. dont they close at 6?
  8. Jun 24, 2011 at 5:48 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    ohh. i didnt see that part. i dunno. i got extra o2 sensors if you wanna tr those maybe?
  9. Jun 24, 2011 at 5:52 PM
    97yota4wd
    Eric
    Mesa, AZ
    oh fuck yeah you do!!!!
    let me see if this fixes my problem then i will let you know man!
  10. Jun 24, 2011 at 5:55 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    the cel on my 02 is on cause of some catalyst bs that i dont care about fixing and i think there was another code but im not sure. im positive the sensors on there are ok so i can pull one off my 03 for you which i know for a fact is ok. just gotta make sure the connections are the same and all that bs
  11. Jun 24, 2011 at 6:06 PM
    97yota4wd
    Eric
    Mesa, AZ
    you know the electrical tape job we did? yeah didnt work for shit.
  12. Jun 24, 2011 at 6:10 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    yeah didnt think so.. i still told you to replace that asap
  13. Jun 24, 2011 at 9:19 PM
    pizza
    pizza Active Member
    Phoenix
    2010 Tacoma TRD 4x2
    Stock right now.
    Kinda what I'm thinking.. Do stock ECU's "re-program" themselves or does the MAF and o2 sensors just do what they do? By that I mean, read whats coming in and going out and automatically adjust air/fuel?
  14. Jun 24, 2011 at 9:19 PM
    97yota4wd
    Eric
    Mesa, AZ
    well i figured out that hose is my dam problem. its a dealer part, calling them in the AM
  15. Jun 24, 2011 at 9:20 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    4cy, bigger tires, no back pressure, i know oliver lost a lot of bottom end power before he re-geared
  16. Jun 24, 2011 at 9:21 PM
    97yota4wd
    Eric
    Mesa, AZ
    Idk... but its cause my intake hose has a hole in it so its acting like it has a really bad vaccum leak:)
  17. Jun 24, 2011 at 9:21 PM
    PLC721
    Patrick
    Chandler, Az
    ohhh gotvha
  18. Jun 24, 2011 at 9:22 PM
    97yota4wd
    Eric
    Mesa, AZ
    i got a exhaust now:)
    so it has way more back pressure than it did
    wrapped duct tape around the tube to get me home and ran great!
  19. Jun 24, 2011 at 10:06 PM
    pizza
    pizza Active Member
    Phoenix
    2010 Tacoma TRD 4x2
    Stock right now.
    the crank case breather? That wouldn't cause much of an issue, if any at all..
  20. Jun 25, 2011 at 2:17 PM
    97yota4wd
    Eric
    Mesa, AZ
    its this... but this is a acter market one i believe...
    i wrapped duct tape around the hole and it runs great.
    but its a dealer only part and they want 75 fucking dollars for a little price of rubber
