Installed driveshaft bearing, have vibes still
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TNT4X4, Mar 11, 2016.
  1. Mar 11, 2016 at 4:42 PM
    TNT4X4
    TNT4X4 [OP] Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    alright, let me prefix this with my vibration issue is also partly due to needing to install the ECGS front diff bushing. In the process of sorting thru my vibration issue, I found that my rear driveshaft bushing had a lot of playing in it, I figured this was contributing to the issue and the bearing wasn't too expensive so I replaced it. Reinstalled everything and now I've got a different kind of vibration. Instead of having a vibration on acceleration, once I get past 25-30, I get a driveline feeling vibration and it doesn't go away (I only got up to about 50 during the test drive). So what's my issue?
    I've got two hunches, #1, I put the drive shaft together out of sync and just need to take it apart and make sure the u joints are all aligned properly to each other. #2 I need a bearing drop installed, with the old bushing being so worn out, it was allowing my driveshaft to get closer to flat and mitigate the high speed driveshaft vibe and now that I have a bearing that holds it tight and good, it's causing a vibration from being at an angle.
    Any ideas? I'll be tearing back into it tomorrow
  2. Mar 13, 2016 at 5:54 AM
    TNT4X4
    CENTRAL NEW JERSEY
    2006 Tacoma
    For anyone looking for an update or that stumbles upon this during a search with a similar problem....I wasn't paying attention and put the front half of the drive shaft back on 180* off of where it was balanced and that was what was causing my vibration. I realized it shortly after posting and tore everything back down yesterday and verified. Problem is all fixed now.
    Bastek and IpaMan like this.
  3. Mar 13, 2016 at 6:18 AM
    IpaMan
    IpaMan Active Member
    Nice job man.
