Installed DT Header Strange faint ticking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Jan 13, 2011.
  1. Jan 13, 2011 at 3:55 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Hello everyone. Installed a Doug Thornley Header today in the taco. Nice header but what a bitch to get in-5 hours. I figured I might as well remove the secondary filter since I had everything appart. Everything went good drove around for a half hour and thank god no lights came on. When Im driving and I get on it I can hear almost like a ticking noise really faint. I dont know if this is normal due to the header or due to secondary air filter removal. Any help or advice on this would be appreciated.
  2. Jan 13, 2011 at 3:59 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Windham Maine
    09 TRD SPORT
    TRD Short Throw, TRD Exhaust, 5100 1.5, Weathertech floor liners, AFE Filter, Projector Head and fogs, Weathertech vent visors
    yup sounds like small exhaust leak
  3. Jan 13, 2011 at 3:59 PM
    Cossi
    Cossi TacoTacoTaco
    Sounds like an exhaust leak under load. Retighten the header bolts.
  4. Jan 13, 2011 at 4:07 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    you'll find that tons of people have that stock. my truck right off the lot sounds like it has a small exhaust leak under acceleration. very common. weird, but true.
    that said, if you redo the torque, and don't have a warped flange or crappy gasket, it could very well be the same sound that many of us experience as a result of certain valves and other mechanisms of the 4.0.
  5. Jan 13, 2011 at 4:08 PM
    A7XT
    A7XT Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    x2, make sure the gaskets are not damaged in any way as well
  6. Jan 13, 2011 at 4:25 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I used the original bolt spring configuration where the header attached to the mid pipe. Do you think I should have used regular bolt and nut setup.
  7. Jan 13, 2011 at 4:30 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I don't know what kind of gasket those headers come with but the trick I use for V8's with paper gaskets was to soak the gasket in water before an install and let them expand a bit and when everything is bolted and torqued to run the motor until it's hot and re-torque when it's cooled to help with the seal.
  8. Jan 13, 2011 at 4:34 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Alright guys I will try to re-tighten all the bolts. I did not torque them because you cant get to most of them with a torque wrench so I just made them as tight as I could using either rachet or box wrench. Thanks - always appreciated
  9. Jan 13, 2011 at 6:06 PM
    westport toyota
    westport toyota Active Member
    is it faster?
  10. Jan 13, 2011 at 6:24 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Glendale, AZ
    I hope you fixed it man.... i had a hell of a time getting my leaks all sealed up after my URD y-pipe and DT longtube install. I originally bought new gaskets from Toyota, but then it leaked about 6 months later, so i ordered FEL PRO gaskets (btw, the fel pro gaskets cost $12 for 2 whereas the OEM ones are about $20 each).... The felpro ones are 100X better.
    So in the future, if you get more ticking, switch the gaskets and just tighten the bolts as much as you can since there is NO WAY you can get a torque wrench in there.
    Best of luck.
  11. Jan 13, 2011 at 8:16 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    No doubt bro. Real pain in the ass I really cringe when I think about having to pull this header. A couple of the bolts are a f*&king nightmares to get at. Ill try to tighten down everything again tomorrow.
  12. Jan 13, 2011 at 8:18 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    It feels like throttle response is better so maybe
  13. Jan 14, 2011 at 8:29 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Problem fixed . Exhaust leak comming from flange between header and mid pipe. You cant use the original bolt/spring/nut this setup does not let you marry the two flanges together tight enough. I replace with a grade 8 bolts and nuts. Perfect no leak or ticking noises. Thanks to all of you for your input.
  14. Jan 14, 2011 at 8:37 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    now you just need a URD MAF CAL to tune it up right and you'll be running real good.
