Installed Eibach Lift, It adds 2" in front and 1" in the Back. Would aftermarket UCAs be necessary?
Discussion in 'Suspension' started by jn2399, Feb 15, 2021.
  1. Feb 15, 2021 at 9:20 AM
    jn2399
    jn2399 [OP] Well-Known Member
    Jon
    2018 TRD Sport 4x4
    Pro Wheels.
    I was wondering if anyone else that got this setup kept their stock UCAs or whether or not it would be a good idea to get stock UCAs. The guy at the shop told me the stock UCAs would be fine for this setup.
  2. Feb 15, 2021 at 10:58 AM
    Iyabyas
    Iyabyas Active Member
    Paul
    DCSB TRD OR 4x4
    None
    You are fine with stock UCAs. Anything more - 2.5-3” I’d say yes.
  3. Feb 15, 2021 at 11:06 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You should be fine with the stock UCAs as far as alignment is concerned. If you have the Eibach 2.0 coilovers then you may or may not get close to making contact between the coil and UCA at full droop. In my experience some clear and some don’t. That point is moot if you still have the sway bar since it’ll limit your droop unless you have both wheels off the ground.
    I’d at least do a visual check by jacking the drivers side front wheel off the ground. If you don’t make contact there, then you’re fine on the passenger side as well.
