Installed: Firestone Ride Rite Air Bags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocsTacoma, Apr 15, 2013.
  1. Nov 15, 2014 at 7:33 PM
    #201
    theocean
    theocean Well-Known Member
    San Diego
    13 DCSB TRD OR 4X4
    Eibach 1.6", 5100s at 0, Ride Rites, Daystar Cradles, Koing Contersteer Offroads, 265/75/16 Wrangler Duratracs
    Finally got my Ride Rites installed. Started with 10psi, rode like crap, went down to 5, even worse, then went up to 15PSI and that seems to be the sweet spot.
  2. Nov 17, 2014 at 2:30 PM
    #202
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    For those who use the air bags for a lift make sure to adjust the brake proportioning valve or ad an extension just like you would with any lift. Have been running the airbags for about 10 years on a Tundra and the Cradles for about 2 years...love them! Cradles are great and you don't have to drain the bags when going on a lift with the cradles either!
  3. Nov 24, 2014 at 2:39 AM
    #203
    mike15
    mike15 Well-Known Member
    PA
    2021 Tacoma Limited
    I have a question that maybe someone could answer.
    If you have the air bags installed and you take your truck to a garage and they lift the truck up by the frame and the axle is just hanging with no support.
    Since the frame and the axle are now connected together with the air bag.
    Could that damage the air bag?
    Thanks
  4. Nov 24, 2014 at 3:27 AM
    #204
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Supposed to drain the air out of them first.
  5. Nov 24, 2014 at 4:09 AM
    #205
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    That is why you want the daystar cradles, as they allow you to disconnect the back from the lower support.
    Jon
  6. Nov 24, 2014 at 4:18 AM
    #206
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    +1 On the Daystar Cradles. No more draining air out when they put your truck on the lift. Just one of the benefits running the cradles .
  7. Nov 24, 2014 at 4:23 AM
    #207
    boomer6
    TN
    Tacoma TRD Offroad
    Bicycle pump works fine.
  8. Nov 26, 2014 at 1:46 PM
    #208
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    So are you simply removing the bolt that holds the lower part of the bag to the bracket and then installing these brackets? More info please! I have the Firestone Riderites
  9. Nov 26, 2014 at 2:03 PM
    #209
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Correct. Check my build page 14.
  10. Nov 26, 2014 at 2:28 PM
    #210
    Agro
    San Diego
    Thx. Ordered em
  11. Nov 26, 2014 at 2:34 PM
    #211
    adriancast
    Adrian
    Ontario, Ca
    No problem. Took like 5 mins to install.
  12. Nov 26, 2014 at 4:05 PM
    #212
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
  13. Nov 26, 2014 at 4:09 PM
    #213
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    If you don't mind me asking, how much did this set you back? I want to put airbags in my diesel next spring and want to know a ballpark cost. Installation looks pretty easy from your photos, do they just bolt right in or did you have to drill some holes?
  14. Nov 26, 2014 at 4:18 PM
    #214
    Agro
    San Diego
  15. Nov 26, 2014 at 4:48 PM
    #215
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    do you have the cradles installed?
    I'd like to hear from everyone that does and their experience as well as how many miles they have with the cradles.
  16. Nov 26, 2014 at 4:49 PM
    #216
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    $3-400, install is easy
  17. Nov 26, 2014 at 4:54 PM
    #217
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
    I have about 20,000 miles. It even survived having 1000 lbs in the bed with a trailer which weighed about 2000 lbs and had no problems driving from Washington to san diego.
  18. Nov 26, 2014 at 5:40 PM
    #218
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    how are the cradles holding up and do you offroad at all?
  19. Nov 26, 2014 at 5:55 PM
    #219
    adriancast
    Adrian
    Ontario, Ca
    The cradles were made so you can offroad.
  20. Nov 26, 2014 at 6:22 PM
    #220
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    so are a lot of things, like first gen raptors... just wanted to know how they have been holding up in the real world. as well the air bags and brackets. the article i posted says the brackets werent designed for the shock of coming down hard on the cradle.
