Installed HIDs, turns off
Discussion in 'Lighting' started by rondog, Oct 18, 2011.
  1. Oct 18, 2011 at 4:07 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    I installed 4 6" HID off road lights. I have them wired up to two switches. 2 pencil beams on one switch, 2 driving on the other. The driving lights are fine, however, the pencil beams will either flick on for a second and go off or they go on, stay on for 1-5~ mins and then go off. Does that sound like a grounding issue? That is the only thing I can think of, although my driving beams which are fine are grounded to the same place.
  2. Oct 18, 2011 at 5:06 PM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    Street, MD
    11 Tacoma TRD DCLB 4X4
    Bilstein 5100 all around with front set at .85 w/Eibach coil and 1/2 spacer, Rear 2" Deaver AAL, SCS Steath 6 matte black rims wrapped in 265/70/17 Duratracs, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 20% up front and 50% on windsheild), HID 35W 6000K headlights and 35W 4300K fog lights, Smoked Tail lights and 3rd brake light, T-Rex 2 eyelids colormatched, Foglight anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Doug Thorley LT Headers, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, Hella 700FF HID 55W 6000K behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Omega Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns
    here did you buy the HID kit from
  3. Oct 18, 2011 at 5:09 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    sounds like ballast problem! that started happening to a buddy of mines lights and his ballast had burned up
  4. Oct 18, 2011 at 7:10 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    morimoto or customlightz.com ballast is the only after market piece i would wire on my truck.
    they are fully potted like a g shock watch meaning the entire inside is basically floated in premium silicon for water proof functionality and shock resistance. the warm up time on the 2nd gen morimoto ballast is extremely quick imo faster than the matsushida or denso oem ballast.
  5. Oct 18, 2011 at 7:14 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    x a bajillion on the ballast
  6. Oct 18, 2011 at 8:34 PM
    rondog
    Ronnie
    Escondido/San Diego
    they are brand new. I got them from http://www.eagleeyelights.com and they are all internal ballasts so I can't really switch them around. I bought 2 relays for each switch, 2 circuit breakers (didn't use fuse boxes) and then the two switches. If it was a ballast and they are on the same circuit, would one bad ballast cause them both to go out?
  7. Oct 18, 2011 at 8:37 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Sounds like a bad connection to me. Check all of your connections.
  8. Oct 18, 2011 at 8:38 PM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    does DDM send out replacement ballasts for free? mine are doing the same thing...
  9. Oct 18, 2011 at 8:39 PM
    S.B.
    Sean
    You may have to pay shipping.
  10. Oct 19, 2011 at 11:27 AM
    rondog
    Ronnie
    Escondido/San Diego
    checking again
  11. Jan 4, 2012 at 12:53 PM
    rondog
    Ronnie
    Escondido/San Diego
    Ok so since I've had my lights in the wrong order, I cut the wires, reordered and reconnected. Now the opposite lights...my driving lights..are going out.
    Thing to note, is the ones that were going out previously aren't anymore. They are on a different relay and switch now. My guess is the relay is bad...does that sound accurate?
