Installed LED dome lights & map lights
Discussion in 'Lighting' started by RPain, Jun 21, 2010.
  1. Mar 14, 2014 at 8:31 AM
    #61
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I did more reading on this and realize that you guys are right. The vehicle system thinks the bulb is burned out due to the resistance being so low...who could guess it would be too smart for its own good.
    My post tho does explain why the dimmer doesn't work very well when you use LEDs in the dash. Using a rheostat to adjust the voltage works well for incandescent lights not so well for LEDs since they only work in a certain voltage range. The brightness of LEDs won't dim very smoothly with only a rheostat.
  2. Mar 14, 2014 at 9:38 AM
    #62
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    I think you meant resistance is high.
  3. Apr 13, 2014 at 11:46 PM
    #63
    StrikerTRD
    StrikerTRD Active Member
    Central Point, Oregon
    01 Pre Runner DoubleCab TRD
    Engine: Injen CAI, Doug Thorley Headers, FM high flow cat, Borla cat back exhaust. Front suspension:Fox 2.5 remote reservoirs/Camburg UCA/ Rear suspension:Fox 2.0 rear shocks/Wheelers Add A Leaf. Appearance: Smoked LED Spyder taillights. Satoshi Grill, Black Spyder Headlights, Led Headlight conversion
    Hey jumper just spent a pretty penny on led's had I know about your service I would had picked them up from you. Wha size resistor would one need to make the dome and map light work and how would I attach it, if its possible? I am interested in the head light LED. I have an 01 Tacoma. Thank you so much
  4. Jun 6, 2014 at 9:01 AM
    #64
    murder
    murder Member
  5. Jun 6, 2014 at 9:12 AM
    #65
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    I'm pretty sure you got the wrong bulb (31mm), you need to get the longer one (42mm).
    this is the one I use
    http://www.ebay.com/itm/White-5050-...ht_Bulbs&var=410258111560&hash=item19e6a3ce11
    #65
  6. Dec 26, 2014 at 4:40 PM
    #66
    shawnboy99
    shawnboy99 New Member
    Great ideas, thanks! Option 2 worked for me! I registered this forum so I can share what I did.
    Some measurements on 2004 Tacoma Double Cab.
    .36 Amp with a 5W incandescent bulb at 12V. LED is drawing .24 Amps, so I'm adding .12 Amp to add up to at least .36 Amp, since I know for sure at .36 Amps, the dome light works! (All current measured with un-fused "20 A" terminal on multi-meter.)
    To add .12 Amp, I need a 100 Ohm (R=V/I=12/.12) resistor, rated at 1.44W or higher (P=V*I=12*.12). Since I have not a higher powered resistor than .25W, so I added a few .25W resistors (quarter inch long in body length) in parallel. They need to be at least 576 Ohms each to avoid overheating ( R=V*V/P=12*12/.25). So I found a few resistors between 600 and 1200 Ohms in parallel, the net resistance is measured to be 115 Ohms.
    Everything works! The resistors feel warm to the touch when the light is on. Otherwise, no voltage is measured across the resistors.
    Hope this helps!
  7. Dec 6, 2018 at 5:24 PM
    #67
    Okiboki
    Okiboki Member
    Billy
    2003 4 door
    Ran a resistor across the back of an LED purchased from AutoZone. Now, "on" position works fine, "door" only works when key position to acc. With key out, door open has no light whatsoever on my 2003 dc Taco
  8. Dec 29, 2018 at 5:12 AM
    #68
    will e
    will e Well-Known Member
    World Wide
    04 pre-runner
    Dominic Toretto Tuned with Extra Blinker Fluid
    hey OKI....BY any chance did you snap any pics?!?!
