Installed Lift
Discussion in 'Suspension' started by 2006TRDSPORT, Aug 11, 2011.
  1. Aug 11, 2011 at 2:03 PM
    2006TRDSPORT
    2006TRDSPORT [OP] 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    Here is a few pics of the lift I helped install today. It has a 2" AAL with OME N182 shocks in the rear & Bilstein 5100's set at 2.5" in the front with stock springs/UCA's. Rides great so far, will be putting new Nitto Terra Grapplers on tomorrow & getting alignment done!
  2. Aug 11, 2011 at 2:06 PM
    upnadam
    upnadam Well-Known Member
    Adam
    Wilmington, NC
    11 PreRunner TRD Sport LB
    5100's up front, TSB, tinted windows, tail gate theft deterrent mod, fog lights anytime, de-badged, 7 pin relocate, AFE dry, Magnaflow
    Congrats, looks good. Super White ftw!
  3. Aug 11, 2011 at 6:35 PM
    Freestyler
    Freestyler Well-Known Member
    Duvall Washington
    05 TRD off road
    6" Pro Comp, 315/70/17 Pro Cromp Xtreme mt on 17x8 ultra Goliaths, K&N intake, Westin Sportsman, Flowmaster Exhaust, Alpine Speakers and Amp, JL 8 Inch SUB, Pioneer AVH-P3300 BT, 35W 5k HID Healights and Fogs, 100W 6k HID converted 800 series KC Lights.
    Looks good, will look even better with those Terra Grapplers :)
  4. Aug 11, 2011 at 6:42 PM
    NCTaco
    NCTaco Well-Known Member
    Brandon
    NC
    05 SR5
    secondary airfilter removed, deblinged , bhlm , satoshi grill
    getting ready to do the exact same thing to mine, can u let me know how the alignment goes with the billies at 2.5 with stock ucas .
  5. Aug 12, 2011 at 9:32 AM
    2006TRDSPORT
    Felton, Delaware
    Will do NC, it's in the shop right now, will know in a few hours. It seems just fine so far, and rides great. Once I get the new tires & alignment done I'm gonna take it on the highway to see how it does & will let ya know!
  6. Aug 12, 2011 at 3:28 PM
    2006TRDSPORT
    Felton, Delaware
    The truck rides good after the new Nittos were installed + alignment. The tires are noticably louder being A/T's but not to bad at all. It does not seem to wander to bad at 65 mph even with the stock UCA's but more time will tell. I'll most likely get aftermarket UCA's down the road once I can save up more money. I do not regret setting the Bilstein's at 2.5" and I think the stance is perfect with the 2" AAL. All together with the new tires installed it should be approx. 3" of lift since I got a size bigger then the stock 265/65/17's. Overall, I think it looks great and happy with it. I was a bit worried using the short AAL but it rides just as good as it did stock, not any stiffer IMO.
  7. Aug 12, 2011 at 4:44 PM
    2006TRDSPORT
    Felton, Delaware
    After Nittos Installed + AVS Ventshades. Turned out great.
  8. Aug 12, 2011 at 7:41 PM
    NCTaco
    Brandon
    NC
    05 SR5
    sweet ride .... just orderd the billies from downsouth and 2" aal from wheelers, come on ups lol
  9. Aug 13, 2011 at 12:49 AM
    2006TRDSPORT
    Felton, Delaware
    Thanks! I think you will love it once you get it put on. Are you taking it somewhere or putting it on yourself? I had some help putting mine on, it was a good learning experience all the way around, and glad I was able to install a good bit of it. I know with the Bilsteins up front, the sway bar & skid plate needed to come off to make it easier putting the shocks back on. It took me and 2 other guys about 4 hrs total for the front/back shocks & leafs total so not bad. Being in a auto shop helped alot I must say! My g/f's family owns a shop so all the tools I needed were accessible. Good luck with your Lift NC!! Let me know how it goes! So far so good with mine, it rides great!
  10. Aug 14, 2011 at 7:37 PM
    NCTaco
    Brandon
    NC
    05 SR5
    the mechanic at my work is going to help me instal it , i cant wait !
  11. Aug 14, 2011 at 7:47 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    looks good, i like it! :thumbsup:
    have you considered wheel spacers for a wider stance?
  12. Aug 14, 2011 at 8:05 PM
    2006TRDSPORT
    Felton, Delaware
    That's awesome NC, hope it all goes well! I have not thought much about wheel spacers since they are 265's, but who knows, I might eventually consider getting them. I do want to get 285's one day and would definitely consider them then. I think my 265/70/17's look good for now though. I am about to take a long trip on the highway, will see how it goes. I still have stock UCA's but around town it's fine.
  13. Aug 15, 2011 at 1:29 PM
    NCTaco
    Brandon
    NC
    05 SR5
    yeah im runnig 265 70 17 's to i really hope it looks good , new tires plus i dont wana go any bigger bc its a 4 banger , kills the power,ive got eagle wheels though. which makes the tires rub when they didnt on stock wheels because of the offset. but the lift will fix that
  14. Aug 16, 2011 at 8:28 AM
    2006TRDSPORT
    Felton, Delaware
    After driving about 650 miles after install, and a lot on the highway I had no problems really with the stock UCA's with billies set at 2.5". The steering did feel a little looser at higher speeds but nothing serious that would require you to get aftermarket UCA's right away. It was not wandering all over the place like some have claimed but could vary from truck to truck as they say I guess. I do plan on getting them later on sometime. The billies ride great even at max height, and even though I was afraid the 2" AAL in the back would be very stiff, it's not at all and as good as stock if not better. I also put new OME shocks in the back so I'm sure that helps too. I do have a SLIGHT vibration between 20-30mph I can notice but it's not bad or annoying. I'm guessing that's due to the AAL in the rear. Anyhow, I love the lift & recommend it for others wanting to try the same set-up. :D
  15. Aug 16, 2011 at 8:34 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Why do people call them BILLIES? They are Bilstein's
  16. Aug 16, 2011 at 8:36 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    You know how the forum lingo goes...
    OP,
    Truck looks awesome - congrats!
    Fink
  17. Aug 31, 2011 at 6:42 PM
    NCTaco
    Brandon
    NC
    05 SR5
    got mine installed today. looks shuge to me , wasnt expecting that much lift out of just 2.5 " in the front and 2" rear , rides good , lil of a shutter on take off, getting the alignment tommorow . the 265 70 17s look ok not to small .
  18. Sep 1, 2011 at 5:27 PM
    2006TRDSPORT
    Felton, Delaware
    Great! It does make quite a bit of difference even with 2.5" I agree. I only have a slight vibration around 20-30 mph but nothing serious. I am however going to get my tires re-balanced and the front end looked at when I return to the states because at highway speeds it vibrates a bit & the steering wheel moves back and forth a bit. In town it rides great, no problems whatsoever. I have lifetime balancing included with my tire purchase so I will take advantage of it. Also, I'm gonna add some aftermarket UCA's soon as I can because at times I did notice that the truck felt a bit unstable (nothing serious, just felt like high wind). I did not notice that right away even after driving 650 miles after getting the lift done at first, but did notice it later on. It's nothing major but something that I'm sure the UCA's would fix.
  19. Sep 2, 2011 at 7:39 PM
    NCTaco
    Brandon
    NC
    05 SR5
    after the alignment no more take off shutter and no vibes at all as of yet. steering is a lil touchy not really what id call unstable , ill get some pics up this weekend some time
