Installed LR UCAs today and...
Discussion in 'Suspension' started by solus, Dec 10, 2009.
  1. Dec 10, 2009 at 5:17 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    got and alignment and boy was my alignment jacked the hell up!
    now its
    left
    Camber = -.1
    toe = .01
    caster = 2.3
    right
    camber = .1
    toe = 0
    caster = 2.5
    WAS:
    left
    camber = .9
    toe = -.47
    caster = 3.9
    right
    camber = .6
    toe = -.37
    caster = 5.1
    For anyone driving around on 2.5 lift (bilsteins or OME) and no aftermarket UCAs... get some asap.
    I also think I got a slight lift from the change...
  2. Dec 10, 2009 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Those are MUCH better numbers! :)
  3. Dec 10, 2009 at 5:23 PM
    VenomTaco88
    VenomTaco88 Just Got Engaged!
    Mtn Home AFB, ID
    Love my Venom Taco
    K&N cold air intake, Full Double Wall stainless steel Megaflow exhaust, custom nerf bars
    i wish i knew what the numbers meant could someone explain this for me
  4. Dec 10, 2009 at 5:27 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    the closer to...
    camber = 0
    toe = 0
    caster = 2.4 (w/265/70/17 tire)
    the better
  5. Dec 10, 2009 at 5:32 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    But what does all that mean?
    What are the benefits?
  6. Dec 10, 2009 at 5:39 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    camber is the angle the wheel sits from the top to bottom like this when looking at it from the front / \... 0 means this | |
    toe is the angle of the wheel when looking at it from the top down / \ 0 means | |
    caster is the position it sits in the wheel wheel. 2.4 is optimal for this truck with this size tires
    so a 0, 0, 2.4 will reduce tire wear, and make the truck drive straight...
  7. Dec 10, 2009 at 7:45 PM
    hunter1111
    hunter1111 Well-Known Member
    Granger Tx
    2010 trd 4wd
    I was going to try to explain these numbers for them but solus you did a good job of explaining.....i t would of taken me an entire page to get the same point across.lol.
    Those numbers arent bad. Its always good to have about a 0.5 degree more caster on the right side to compensate for road crown.
  8. Dec 10, 2009 at 7:52 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    caster? how would that help don't you mean camber?
  9. Dec 10, 2009 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No...he is right. .5* more Caster will prevent the vehicle from wanting to wander tward the right side of a crowned road.
  10. Dec 10, 2009 at 8:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No no...Mine is Perfect. :cool:
  11. Dec 10, 2009 at 8:05 PM
    Drock42
    Drock42 Well-Known Member
    Derek
    Albuquerque, NM
    09 TRD Sport 4x4
    Toytec Coilovers, LR UCAs, OME Dakar leafpacks w/5100s, 18" 951s, 285/60 TGs (6ply), Grillcraft MX upper & lower, Wet Okole seat covers, Rec-rac bike racks
    My truck is going under the knife tomorrow :yay: and I'd like to know what caster number would be ideal. What's being installed is the Toytec ULK w/Dakar rear & LR UCAs. Wheels are 18x9 (4.53 bs -12 offset) w/285/60 tires. I just want to make sure it's good before we roll out of there. Also, to make sure I have everything straight, the Toytec Coilovers arrive set at 2.5" right? That's how I understood it to be from what it says on their website. Thanks! I can't frickin' wait!
  12. Dec 10, 2009 at 8:07 PM
    dragon
    dragon Well-Known Member
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    what's the factory specs for the rear?
  13. Dec 10, 2009 at 8:19 PM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    going to install my uca's soon, but kinda confused about what side goes up etc, and how the ball joint goes through the arm? OP if you have any tips/install help i'd appreciate it
  14. Dec 10, 2009 at 8:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BAH! They are tinted. Same as the back.
  15. Dec 10, 2009 at 9:10 PM
    hunter1111
    Granger Tx
    2010 trd 4wd
    Rear is non adjustable so most of the time it wont matter......the thrust angle is the major thing, (rear end square). Some trucks allow you to install shims to correct camber and toe problems but usually its not a problem.
  16. Dec 10, 2009 at 9:22 PM
    hunter1111
    Granger Tx
    2010 trd 4wd
    Caster will cause a "pull" or "drift" way more than camber. Ive never aligned a toyota truck but i do align alot of high end cars....On 90% of the cars i align they dont offer caster adjustment. 0.5 degree more positive caster on the right wheel is ideal. Anything 1.0 degree or more will cause a vehicle to wander to the left. Your specs look fine, as long as you have more caster on the right wheel you will be fine. It really only becomes trouble when you have less caster on the right.
    Camber can affect a vehicle from driving straight but it usually has to be a major difference from one side to the other. If caster isnt adjustable we can sometimes adjust either right or left camber to compensate a slight pull but the problem is you will get uneven tire wear.
  17. Dec 11, 2009 at 12:19 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    hmm okay... makes sense
  18. Dec 11, 2009 at 12:20 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ok cool
