Installed my ARB compressor and bed mount Plus RTMR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Red18Taco707, Nov 4, 2018.
  1. Nov 4, 2018 at 8:44 PM
    Red18Taco707
    Red18Taco707 [OP] Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Finally go around to installing my ARB single compressor in the bed with the Expedition Essentials bed mount. Here are some pictures.
    ^ Didn’t like how the top was open so I decided to make a lid for it.
    ^ Should be enough to keep things from falling in. Time for some paint.
    ^ Much better. Next is some holes for the bolts.
    ^ Decided I wanted my switch in the bed as well. Found some material to mount the switch.
    ^ Drilled holes then cut it to a square.
    ^ A little crooked but I’ll take it.
    ^ Rough layout of where I want things to go.
    ^Onto the wiring harness. I took apart the harness that came with the compressor and just used wire for the compressor, relay and switch.
    ^ Soldered and heat shrunk the connections.
    ^ Wiring done. Just need to clean it up.
    ^ Two rolls of tape later.
    ^ Removed the cubby. I also painted all the holes I drilled out. Time for some bolts.
    ^That was exhausting.
    ^ Now we’re talking.
    ^ I had to drill holes for the compressor mount. A little off center but now one will notice.
    ^ It was a lot easier taking the bottom plate out to bolt up the mount.
    ^Compressor bolted. Next is drill out the holes for the bed mount them route the harnnes.
    ^pretty easy just center the template as best as you can and drill out the holes.
    ^Compressor is in and hooked up!! All that is left is cut off the lid off the old cubby and hook up the power and ground. I was too excited so I forgot to take pictures of the rest.
  2. Nov 5, 2018 at 8:46 AM
    NateWest
    NateWest Well-Known Member
    Nate
    Maple Valley WA
    2017 Super white DCSB TRDOR
    Good work!
    Red18Taco707[OP] likes this.
  3. Nov 5, 2018 at 9:17 AM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    nice, i need to get around to doing mine
  4. Nov 5, 2018 at 9:25 AM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    93C25C99-18BB-4196-A629-E12D6105C9CC.jpg Here’s how it looks all done.
    jmneill, quis23, usernotfound and 3 others like this.
  5. Nov 5, 2018 at 9:46 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    My '18 has the bed side cubby; however, I think it was eliminated in the '19?
    Noch likes this.
  6. Nov 5, 2018 at 10:41 AM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    I haven’t looked at what all is changed on the 19s. Super convenient it would suck if they did.
  7. Nov 5, 2018 at 10:42 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Nice work
  8. Nov 5, 2018 at 10:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How come you opted to buy their mount if you have skills and access to that shop? Looks like you could make something easily and cheaper.
    Shellshock, quis23 and TOP TACO like this.
  9. Nov 5, 2018 at 10:55 AM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    I got the compressor and mount as a bday gift from the mrs. So I just went ahead and used it. But I’m sure I could’ve
  10. Nov 5, 2018 at 10:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's cool! What a great gift. You'll love the compressor.
  11. Nov 5, 2018 at 11:10 AM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Yeah it feels/ looks solid! Definitely happy with it. Time to plan more camping trips.
    EatSleepTacos[QUOTED] likes this.
  12. Nov 7, 2018 at 6:05 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I'm hoping you have a fuse up at the battery as well and not just the one back at the compressor. Isn't doing any good way back there
  13. Nov 7, 2018 at 6:53 PM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Why is that?
  14. Nov 7, 2018 at 7:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If the power cable ends up rubbing on something and becoming exposed, there’s nothing to stop it from shorting out potentially causing a fire.
  15. Nov 7, 2018 at 7:15 PM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Valid point :thumbsup: thanks.
  16. Nov 7, 2018 at 7:36 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Fuses are meant to protect the wire, not the device. As the post above mentions, if the wire somehow gets shorted anywhere between that fuse and the battery, it will more than likely set the rubber insulation on fire and that could potentially set the vehicle on fire.
    This is some 4awg I pulled out of a car where the guy installed an amp himself and didn’t fuse the wire. Burnt through the insulation, and caught his floor mat on fire that burnt up the passenger floor board
  17. Nov 7, 2018 at 7:49 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Mmm toasty.
    I loved seeing the DIY’s where the firewall route was too hard so the good ol’ drop it inside the fender and tuck it under the door weather stripping method. :rofl::bananadead:
  18. Nov 7, 2018 at 8:26 PM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
  19. Nov 7, 2018 at 8:42 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    This one was in a Tahoe. Went down under the vehicle and was rubbed up against the exhaust right after the headers
  20. Nov 7, 2018 at 10:15 PM
    Gary99
    Gary99 Well-Known Member
    Gary
    SoCal
    19 QS TRD OR DCSB
    Correct :(
