Installed my bi-xenon SlimHID kit
Discussion in 'Slims Depot' started by S7ICKlVlAN, Mar 4, 2012.
  1. Mar 4, 2012 at 1:15 AM
    S7ICKlVlAN
    S7ICKlVlAN [OP] Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    First off, I gotta give a huge shout to Paul for putting together a killer kit, with killer service & price point.
    My kit arrived in the mail this morning and having anticipated it, I had all the equipment/tools I needed to install so I charged into it.
    Tools/Materials
    10mm Gearwrench (Removal/installation of battery hold down, washer fluid tank, factory grounding points, negative/positive battery terminals)
    12mm Socket (Removal/installation of positive battery post nut for add-on accessories)
    Flathead screw driver (Removal of plastic clips for radiator shroud)
    Industrial Velcro (installed on the bottoms of the relay, ballasts & resistors/inverters?)
    Needle nose pliers (Removal/installation of factory clip that holds headlamps in housing)
    I followed the instructions by CableTec listed here: Link
    Tips
    1) I did remove the battery completely to give me more room to mount the ballast/inverter. I would recommend this to expedite the install.
    2) I disconnected the washer fluid tank and swiveled it as far out of the way as possible to allow for more room to remove the headlamp. Once you've removed the halogen/installed the HID lamp you can put this back.
    3) I mounted the ballasts on vertical surfaces to minimize the chance for moisture penetration. On the driver side, I mounted to the fender near the battery. On the passenger side, I mounted to the radiator support. I determined the mounting locations based on the grounding points which limit where you can mount the ballasts due to wire length.
    4) Mounting the ballasts and determining the locations takes the longest. Everything else is just a matter of plugging and refastening.
    5) I used the factor grounding points. Driver side is near the battery. Passenger side is to the right of the washer fluid tank, towards the engine block.
    6) Test fit all of your wires/connections before finalizing your ballast mount location. Make sure all the wires that need to be plugged into the ballast can reach the connection point.
    7) The first and last thing that you remove/install should be the negative battery terminal.
    I ordered the 8000k kit to match the LED parking lights and DTRL's I ordered from CSJumper. In retrospect, I think the 6000k would've worked as well. Ah well, it still looks sick and the light output is head & shoulders better than the stock halogens. Once I buttoned everything up, I fired up the Taco and tested both the low/hi beams and everything worked flawlessly.
    I would highly recommend this kit to anyone looking to retrofit to HID without using a projector kit. The price kicks ass and Paul is awesome with his customer service. Needless to say, the quality of the kit will only make itself apparent in time, but based on what I've seen of it (I do commercial lighting for a living), the components are high quality and should provide excellent service. I lucked out and did not need to adjust the height of my lights. If you do have to do this, I would recommend you err on the safe side and aim low.
    Unfortunately I didn't take a whole lot of pics of the install due to the following reasons: It went really fast, and it was raining. I can go back and take pics of the mounting locations if you really need to see them. Here are the pics of the before & after:
    I have not taken a light/lumen meter to it, but I would say a 50% increase in photopic lumen levels would not be surprising with the visual effect lumens being even higher due to the color temperature.
  2. Mar 29, 2012 at 8:31 AM
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    Beautiful write up thanks for the post and feedback of my kit. :)
    If you are on Facebook please like our page and feel free to post any pics up on your page tagging us. ;)
  3. Mar 29, 2012 at 10:00 AM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    Will do Paul. Thanks brutha.
  4. Apr 9, 2012 at 7:19 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    thanks for the write up op!!! buggah looks cherry!!!
  5. May 1, 2012 at 8:37 PM
    Redneck08
    Redneck08 Well-Known Member
    Wa
    2012 tacoma
    pro comp 6" lift, 20x12 fuel octanes, 305/55 nitto m/ts, afe stage 2 intake
    Did you go with the 35w or the 55w? I'm going to be putting HID's in my 2012 pretty soon and was wondering. Do you have any pics at night? Thanks bro
  6. May 1, 2012 at 8:47 PM
    slimsdepot
    SoCal
    08 PreRunner
  7. Aug 2, 2012 at 6:30 AM
    stolleee
    stolleee Well-Known Member
    Memphis
    2012 Tacoma Supercharged and 1970 Toyota FJ40
    Fox shocks, TRD Supercharger, leather, wheels/tires, exhaust, audio.... etc....etc
    Hello,
    New to the forum and new Tacoma owner. I sold my BMW 135 and stepped into a Tacoma. I am interested in the Xenon bulbs as this is something I cannot give up and have to own.
    Are there any specials that I need to know about like the expired group buy that I missed out on?
  8. Aug 3, 2012 at 7:23 AM
    slimsdepot
    SoCal
    08 PreRunner
    stolleee, if you want to get a kit for your truck I am offering free shipping for the month of August through my website. Go to www.slimshidxenonsource.com and add the kit to the cart and use coupon code "FREESHIP" to get free shipping. If you need to know what kit fits your vehicle you will want the H4 Bixenon kit for the headlights and H10 single beam for the fogs. If you have the newest model Tacoma your fogs will be H11.
  9. Aug 3, 2012 at 7:31 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :proposetoast:
  10. Aug 5, 2012 at 6:28 PM
    Kurtztaco12
    Kurtztaco12 New Member
    Kurt
    Windermere, FL
    12 PreRunner SR5
    MBRP Exhaust, AFE Pro Dry
    Which kit fits the 2012 headlight and fog? Website does not 2012 listed.
  11. Aug 5, 2012 at 6:29 PM
    Kurtztaco12
    Kurt
    Windermere, FL
    12 PreRunner SR5
    Correction : "have the 2012 listed."
  12. Aug 5, 2012 at 6:35 PM
    NtacomaR
    NtacomaR Well-Known Member
    nick
    sparks
    2012 Tacoma Baja
    suspension, wheels, rims, trd exhuast, CAI
    Not trying to sell another company. but got my HIDs from HIDSRUS.com and it was incredible quality. perfect fitment. great color
  13. Aug 5, 2012 at 7:12 PM
    slimsdepot
    SoCal
    08 PreRunner
    The bulb size is H4 Bixenon for the headlights and H11 Single Beam for the fogs. :)
  14. Aug 6, 2012 at 5:17 AM
    stolleee
    Memphis
    Just ordered.....thanks for the help
  15. Sep 5, 2012 at 9:48 PM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    Not to be an ahole or anything but the 55w ballasts are not even 50w if you go off of the working amps and voltage it would be Around 40. But my mom has the same slim style 55w kit with the external igniters and are still pretty bright compaired to my 55w's. Also it's nice you offer the h4 3000k bixenons. They are very hard to find I just recently put those in my headlights they shine way better than 8000k
  16. Mar 10, 2013 at 9:14 AM
    ToyoTaco12
    ToyoTaco12 Member
    Vallejo, CA
    '12 Tacoma 4x4
    non, Stock
    Just installed my HIDs on my 2012 Tacoma and was wondering if anyone has problems with their high beam. My high beam is just all scattered everywhere and is pretty much useless.
  17. Oct 1, 2013 at 7:39 PM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Bump, I was thinking of doing this to my 2012. Yours still scattered or did you figure it out? We don't have projector lenses so that would be just my guess
  18. Oct 18, 2013 at 7:24 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Is anyone around selling a complete kit for an HID/Projector installation. Like I mean the WHOLE thing, not just parts and then you do it yourself. I have been thinking about this just because I don't want to tear my current lights apart and bake them in the oven. But I would like a TRUE projector HID setup like in my old BMW. Anyone got any idea?vI know its gonna run about $450-$700 if it were an option.
  19. Oct 21, 2014 at 1:44 PM
    slimsdepot
    SoCal
    08 PreRunner
    I would think you can buy aftermarket headlight housings that come with projectors and then install an aftermarket HID kit like mine to achieve this. I am not sure if anyone out there sells a projector headlight with the HID kit but I could be wrong.
  20. Dec 20, 2014 at 10:25 PM
    Cancer FREE
    Cancer FREE Active Member
    Kimowahapalu
    Seal Beach, Ca.
    2012 DCLB 4X4 TRD Sport
    Bilstein 5100's up front set @ 2.5 inch with 1 inch block in back UPDATE as of 06/14: 4inch rough country upfront with Bilsteins set at .85 for total lift of 4.85 and rear with 2 inch block with Bilsteins 5100's shocks. UPDATE as of 0615 4 inch lift Rough country with Bilsteins set at 2.5 and rear 2 inch add a leaf with 3 inch block sitting on 285/75-17 34's...
    I too just got done installing my HID and am having the same problem with my high beam being scattered all over the place… Hopefully someone can figure this out…
