Installed my Detroit Truetrac Thursday Night
Discussion in '1st Gen. Tacomas (1995-2004)' started by prophet, Aug 23, 2008.
  1. Aug 23, 2008 at 6:35 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    Finally did it! I installed a True trac in my 04 Prerunner Thursday night. It took about 3 1/2 hours using the online service manual as a guide. It works just like they say...seemless engagement and you don't notice it's there. It does leave a nice double burnout in the gravel :bananadance: Actually the install guide tells you to test it in gravel. One tire at a time on gravel with the other on pavement. I just threw that test in for poops and grins.
    I have mixed feelings about testing it in snow since I hate winter but we'll see.
  2. Aug 23, 2008 at 6:55 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  3. Aug 23, 2008 at 8:35 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    You want to see a pic of my rear end? It doesn't look quite like the one in your avatar. It looks like a differential. It doesn't change the look of it.
  4. Aug 23, 2008 at 8:40 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    I'll see if I can figure out how to get pics posted of the truck later on today. Nothing spectacualr except 25000 miles so it's pretty clean.
  5. Aug 23, 2008 at 9:06 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great job getting it installed man!!! be sure to put some weight in the bed when you have snow...............you'll have way better grab and wont spin as much. what gear oil are you using now??
  6. Aug 23, 2008 at 11:44 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    Valvoline Dura Blend 80-90 Synthetic
  7. May 6, 2010 at 7:40 PM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    Did you get your old bearings off OK and did use them and any other old parts you could?
    I was going to use any old parts if they looked OK. My 03, 4 cyl, 4x4 has 64k miles on it.
    I found one for $406 on ebay. How much did you find one for and who did you get it from?
    I'm wanting to get one for mine.
  8. May 7, 2010 at 2:52 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    I gave 375 for it but that was almost 2 years ago. The only parts needed would be the bearings and I would just press new ones on for as cheap as they are. You don't want any problems there even if the old ones look "good."
