Installed my fog light housings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mongo1958, Apr 26, 2015.
  1. Apr 26, 2015 at 12:38 PM
    Mongo1958
    Mongo1958 [OP] Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab w/convenience pkg.
    Carbon filter removal. Intermittent Wiper Stalk. Cruise Control. Fog Lights.
    I installed the new fog lights into my Tacoma. I'd like to ask how the switched 12 VDC is fed through the fire wall. I'm planning to feed the wire along side of he hood release cable. What did you do ? Thanks
  2. Apr 30, 2015 at 2:31 PM
    Mongo1958
    Van
    Newnan, GA
    Just finished the installation and it works and looks good.
    The set I got was sold by Max Liner on eBay.
    I also used an add a circuit fuse connecting it to the the tail lights so
    they only turn on when the lights are turned on and they also work
    with the bright lights. I highly recommend the add a circuit fuse holder!!
    I routed the cable from the right fog lamp over the radiator and around
    the battery along the head light cables. When I got to the fire wall, I
    Found a nipple in the grommit just under the main harness.
    I cut the end off the nipple off and fed the wire though it to the
    new switch that came with the kit. Made the final connections
    and tide the cables up and tested everything, we are good to go.
    I have not aimed them yet so I hope I won't be tweaking anyone
    In the eye on the way to work.
