Installed My Lift This Weekend
Discussion in 'Suspension' started by aportis72, Sep 24, 2012.
  1. Sep 24, 2012 at 10:59 AM
    aportis72
    aportis72 [OP] Well-Known Member
    Austin
    Supercharger
    So I installed my lift this weekend.
    New Wheels and Tires go on later this week. Wheels are 18 inch BBS RW Tires 275/70R18
    Front:
    Fox 2.5 extended length Remote Resi
    Camburg UNIBALL UCA
    All Pro Sway Bar Links
    Rear:
    AllPro FOX 2.0 REMOTE RESERVOIR WITH ADJUSTABLE COMPRESSION DAMPING
    Defined Engineering Stage 1 SUA kit
  2. Sep 24, 2012 at 3:33 PM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    Looks bad ass throw some 285's on there and your ready to rock.. What kind of rims and tires your putting on? I have the same set up but I went with the TC UCA's as opposed to camburg.
  3. Sep 24, 2012 at 3:45 PM
    aportis72
    Austin
    Supercharger
    Added wheel and tire combo in original post.
    Do you also have the Defined SUA kit?
  4. Sep 24, 2012 at 3:54 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Why did you go with AP swaybar links? I broke an OEM link when putting on my lift, so I decided to "upgrade". After one winter, the heim joints on the AP links are completely rusted.
  5. Sep 24, 2012 at 3:58 PM
    aportis72
    Austin
    Supercharger
    No reason in particular. I thought they were decent, but guess I was wrong. What did you go with?
  6. Sep 24, 2012 at 4:15 PM
    kapolani
    kapolani Member
    St Mary's County, MD
    '12 TRD Sport
    Looks good, man. I like it.
    How high did you lift it?
    How much (ballpark) did a setup like that cost you?
    I'm starting to do some research. Trying to figure out how high you can go until you start running into problems with ride etc. Also trying to figure out what the max size tire you can go as well. I want it to be capable for off road use, but still ride somewhat decently.
    Your setup looks like what I'm going for. Dig it!
  7. Sep 24, 2012 at 4:55 PM
    KenLyns
    Belly of the Beast
    Still running them. If the heim joints seize up this winter, I will replace them with better nickel-plated or stainless ones.
  8. Sep 27, 2012 at 6:37 PM
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    '12 TRD Sport Upgrade, Leather, Moonroof, ICON Stage 5
    TRD Supercharger, TRD exhaust, OEM roof rack, aluminum skid plate, Access tonneau cover, Weathertechs, Tacoma bed mat, OEM black tube steps, Inalfa 925 power moonroof, Katzkin two leather heated, embroidered seats, Icon Stage 5
  9. Oct 16, 2012 at 11:17 PM
    aportis72
    Austin
    Supercharger
    New Pictures with rims and tires :)
  10. Oct 17, 2012 at 8:55 AM
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    How much are you rubbing in the front, and do you have the coilovrs pretty much maxed out?
  11. Oct 17, 2012 at 10:36 AM
    aportis72
    Austin
    Supercharger
    Only barely rubs on the drivers side at half turn like barly barly.
    Only does it at one point when wheels are turned. Turn more it goes away turn less it goes away. And only at lows speeds ?
    I have no idea why only on drivers side? Both shocks are set at factory length.
  12. Oct 17, 2012 at 10:45 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Looks sweet!
  13. Oct 17, 2012 at 11:02 AM
    aportis72
    Austin
    Supercharger
    Figured out why it only rubs a tiny bit on drivers side. Because they are both set the same. I nead to set drivers slightly higher.
    Now I got to get a center punch and a spanner
  14. Oct 17, 2012 at 1:15 PM
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    :dancingbacon::dancingbacon:BINGO
    Yeah it sucks the FOX C/O's don't come with a spanner wrench.. I ordered mine from a website downsouth gave me.
    Are your C/O's maxed out in terms of length or did you keep them the way the came? I believe they're set to 2.25-2.50 in length when you receive them.
  15. Oct 17, 2012 at 1:18 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    That looks sick all you need is bigger tires.
  16. Oct 17, 2012 at 1:22 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2012 TRD double cab
    ARE topper LED light bar Spidertrax
    Good looking truck man, check out the old Toyota in the background. Mid 70's model maybe?
  17. Oct 17, 2012 at 1:23 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    South FL
    '09 Tacoma TRD
    What kind of tires on there in the pics?
    Looks good buddy
  18. Oct 17, 2012 at 1:35 PM
    aportis72
    Austin
    Supercharger
    I kept them the way they came yes they come about 2.5 just depending mine were both right at 2.5. I didn't go any higher as I was told the ride would be stiff.
    Tires are Toyo open country MT 275/70R18
    Did you notice the TRD BBS center caps. :). I have the stock silver BBS ones but ordered the TRD ones from TRDparts4U
  19. Oct 17, 2012 at 2:14 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    South FL
    '09 Tacoma TRD
    PM sent
  20. Dec 17, 2012 at 8:16 PM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Very nice!
