Installed New Intake but theres a problem
Discussion in 'Performance and Tuning' started by Taco22, Jul 16, 2008.
  1. Jul 16, 2008 at 8:08 AM
    Taco22
    Taco22 [OP] New Member
    06' Toyota Tacoma TRD, 4 Door, Long Bed,
    Hey all, New to this site and looking for some help. I have an 06 Tacoma V-6 4.0 and I just purchased and installed a Weapon R Intake (Specifically the Secret Weapon Intake). I believe that I have installed everything correctly. However when I started the truck it starts like normal then sputters a little bit then idols between 1/2- 1 RPM. Does anybody know why this is happening? Any input/ideas as to why this is happening would be greatly appreciated.
    :confused::confused::confused:
  2. Jul 16, 2008 at 8:10 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    mine idles a little rough with the URD intake. I just ignore it.
  3. Jul 16, 2008 at 8:10 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds about normal to me. you gotta give the trucks computer some time to adjust to the amount of air coming in now. never heard of the weapon r intake though.
  4. Jul 16, 2008 at 8:11 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Also, you might want to start using premium if you're not already.
  5. Jul 16, 2008 at 8:11 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    clean the throttle body with some seafoam deep creep spray........it'll idle smoother when you do this.plus, it'll pull air in a little better.
  6. Jul 16, 2008 at 9:04 AM
    Taco22
    Hey guys I appreciate the input I'll give those a try
  7. Jul 16, 2008 at 12:31 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    shhhh because its a secret weapon :gossip:
  8. Jul 17, 2008 at 4:14 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Run the truck for 10 minutes in the drive way.
    Then go drive it at 25 for a 5 minutes, then go the freeway for 10 to 20 minutes.
    This should fix it.
    if that fails. Disconnect the battery for 12 hours.
    Then try it over again.
    While the batter is off, make sure you have no air leaks.
    Cleaning the throttle body is a good idea, just use allot of cloths. Do this once a year any ways.
