Installed PIAA 510 Fog Lamps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 95SLE, Oct 10, 2009.
  1. Oct 10, 2009 at 5:33 PM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I began the install of the PIAA 510 fog lamps last weekend. It rained 3 mornings this past week and the lights work well.
    Here is a pic of the install lamps.
    I drilled a hole 2” from the rear of the fog lamp assembly and that gave me the clearance for the fog lamp to fit in the opening.
    However under the hood was a temporary wire job. Butt Ugly.
    Today I went to work on a fuse panel/relay center that I had planned for under the hood.
    I needed to cut the buss bar to 6”
    Here is the finished install with room to add 3 more relays and an extra fused circuit that may be required in the future.
    A few night time pics of the new lights.
    What is nice is that now adding lamps to the bed or a set of driving lamps will be an easier project. All I need to do is add wiring to the lamps and add a switch. I ran an extra 8 wires from the fuse paned to the area where the existing fog lamp switch is located.
  2. Oct 10, 2009 at 5:39 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Nice addition!!! Good job bro!!!:thumbsup:
  3. Oct 10, 2009 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Well Done!
  4. Oct 12, 2009 at 1:35 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Thank you for the kind remarks.
  5. Oct 20, 2012 at 1:28 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    how much brighter are they than stock?
    i wanted to get hids. and get the same fogs
  6. Oct 20, 2012 at 1:36 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    My Tacoma did not have stock fogs so I really do not know.
  7. Oct 20, 2012 at 1:41 PM
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    Looks great. I wish I was that handy. My wiring job looks like a gang bang of copper and fuses.
  8. Oct 20, 2012 at 1:45 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Just take your time and do not be in a hurry.
