Installed Raceling Rengade 6 wheels with 285/70 17 and vibration is super bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deathbeard, Dec 13, 2010.
  1. Dec 13, 2010 at 9:51 AM
    Deathbeard
    Deathbeard [OP] Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    Hey all,
    installed some 17x9 Raceline Renegade 6 wheels with 285/70 17 tires and the vibration is super bad,especially above 50+mph..Performance plus tire installed et lugs and hubcentric rings...They mentioned that they could not peform roadforce balancing since the wheel was too big and did the normal laser balance..Can anyone advise what I need to do?
  2. Dec 13, 2010 at 9:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You need to find a place that'll roadforce balance them.
  3. Dec 13, 2010 at 10:02 AM
    Deathbeard
    Yorba Linda, CA
    Do I need a place that has the Haweka adapter? Anyone in Socal recommend a place?
    Thanks in advance
  4. Dec 13, 2010 at 11:15 AM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    it took me about 5 attempts to get mine right!Finally discount tire got it to where the shake is almost gone. Just have them balance it till they get them right. I had to talk to the manager and say I wanted a refund if they could not resolve the issue. Suddenly the shake is gone! I did reward the tech with 12 beverages of his choice and that did not hurt anything.
  5. Feb 7, 2012 at 7:50 PM
    xenadogs
    xenadogs Active Member
    LA / OC
    2019 TRD OFF ROAD DCSB CEMENT
    Hey hope you got the problem figured out. If you can, do you have some pictures you can post so I can check it out.
    Thanks!
  6. Feb 7, 2012 at 8:38 PM
    badger
    badger Well-Known Member
    07 SR5
    It's always a good idea to watch when your tires are being balanced and look for runout as the tire spins. I've rejected a few tires over the years when I spotted that. They will often tell you that the runout will smooth out over time. It won't. If you were unfortunate enough to get a tire with excessive runout, it will never run smooth.
