Installed RC 6" lift...wheel and tire fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evanpawlik1, Feb 8, 2024.
  1. Feb 8, 2024 at 3:48 PM
    #81
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    Did you re gear yours and does your Tacoma have 35’s on it?
  2. Feb 8, 2024 at 3:49 PM
    #82
    TacoTuesday1
    FL
    I have 35’s on and gears waiting to go in.
  3. Feb 8, 2024 at 3:49 PM
    #83
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I just don't understand why more people don't listen to your advice
  4. Feb 8, 2024 at 3:53 PM
    #84
    batt700
    Wait you just claimed every Tacoma needs a re-gear as the first thing done yet yours isn’t even re-geared yet you put 35’s on it??
  5. Feb 8, 2024 at 3:54 PM
    #85
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    He literally has gears waiting to go in lol
  6. Feb 8, 2024 at 3:54 PM
    #86
    batt700
    Maybe because he hasn’t even followed his own advice and isn’t even re-geared.
  7. Feb 8, 2024 at 3:55 PM
    #87
    batt700
    Damn bro literally no cap?
    He just said first thing it needs is a regear and yet hes on 35’s with no regear.
    I bet he has a slew of other mods as well after claiming it’s the first thing that needs to be done. Lmfao
  8. Feb 8, 2024 at 3:58 PM
    #88
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    For real no cap. To each their own. Some folks like to upgrade, some like to downgrade apparently :cheers:
  9. Feb 8, 2024 at 3:59 PM
    #89
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  10. Feb 8, 2024 at 4:00 PM
    #90
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Take out the install instructions and maybe read them. You can read right? I found it in like 5 seconds.
    ace96 likes this.
  11. Feb 8, 2024 at 4:00 PM
    #91
    batt700
    ikr, Toyota engineers are big dumb and i’m so much smarter than them.
  12. Feb 8, 2024 at 4:03 PM
    #92
    gotoman1969
  13. Feb 8, 2024 at 4:05 PM
    #93
    gotoman1969
  14. Feb 8, 2024 at 4:08 PM
    #94
    TacoTuesday1
    FL
    They put a non replaceable TOB sleeve, among other things. Doesn’t really get more low IQ than that. Then kept doing it without a revision that “less reliable” automakers do.
    I’m sure old Taco frames are the best thing ever made too, among other features.
    poor gear ratio choice is implemented for one reason and one reason only. Emissions and fleet economy. On a stock new vehicle. Same as plastic bumper air dams.
    yep. It has 35’s. Has needed a regear. Does need a regear. Will get a regear. So did it with 33’s. Even more so with added weight like armor.
    Got a good offer on my old 33’s. Got 35’s for a good deal. Took time to find spare donor diffs and acquire parts from RevolutionGear which was out of stock.
    pretty common.
  15. Feb 8, 2024 at 4:13 PM
    #95
    Taco-Grinder
    Dan
    Fond du Lac, WI
  16. Feb 8, 2024 at 4:14 PM
    #96
    batt700
    A non replaceable throw out bearing sleeve?
    Are you saying you can’t replace the throw out bearing and sleeve on a tacoma?
  17. Feb 8, 2024 at 4:22 PM
    #97
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    24x14 -77mm wrapped with 325/45/24 tires :crapstorm:
    wi_taco likes this.
  18. Feb 8, 2024 at 4:23 PM
    #98
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They do NOT have low down power.
    They have 5 or 6 gears.
    Gears 5 - 6 put the truck in the too low of an RPM range with 31" tires. Throw 36" on there and you might as well leave the truck in 4th gear on the highway.
    Just because I own a 2nd Gen doesn't make it "better" nor make it have magical "power" that it doesn't have....
    It's a DOG......All the Tacomas have been thus far. We shall see what Gen 4 brings.
    Strictlytoyz likes this.
  19. Feb 8, 2024 at 4:24 PM
    #99
    TacoTuesday1
    FL
    what do you mean it doesn’t have power
    It’s rated the same power as a 20yo $1000 sedan
    It’s basically a Ram TRX
  20. Feb 8, 2024 at 4:26 PM
    #100
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    It basically gets more power as the tire size goes up
    TS4x4 likes this.
