Installed RC 6" lift...wheel and tire fitment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Evanpawlik1, Feb 8, 2024.
  1. Feb 9, 2024 at 9:09 AM
    #121
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Interesting.
    TS4x4, wi_taco and Strictlytoyz like this.
  2. Feb 9, 2024 at 9:10 AM
    #122
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    Lol you did get me on that one, you have to butcher the shit out of the cross member.
    I was thinking more along the lines of the fender and pinch welds.
  3. Feb 9, 2024 at 9:11 AM
    #123
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    LOL.
    TS4x4, Bikinaz and wi_taco like this.
  4. Feb 9, 2024 at 9:11 AM
    #124
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Options to run larger tires are DB with minimal body work or body work with no DB. One of these maintains low COG.
    wi_taco likes this.
  5. Feb 9, 2024 at 9:13 AM
    #125
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I chose body work. I can stuff 37's at stock ride height.
    wi_taco and tacotroy17[QUOTED] like this.
  6. Feb 9, 2024 at 9:13 AM
    #126
    batt700
    That's true. I've never worried about tipping my truck from a higher COG since it isn't even barely as high as a stock f150.
  7. Feb 9, 2024 at 9:14 AM
    #127
    batt700
    Do the 37's rub under real off-roading articulation or at full lock?
  8. Feb 9, 2024 at 9:14 AM
    #128
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Nope. like I said. I chose body work
    wi_taco and tacotroy17 like this.
  9. Feb 9, 2024 at 9:15 AM
    #129
    batt700
    Are you also running extended LCA's or still stock? I find it hard to believe you have no rub under real articulation with stuffed 37's.
  10. Feb 9, 2024 at 9:15 AM
    #130
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    This is the way. If OP is gonna start cutting frame he should do it right. JD fab pivot, RCLT, portals. I wanna see 41s OP! 36s are rookie numbers, you gotta pump those numbers up!
    TS4x4 and wi_taco like this.
  11. Feb 9, 2024 at 9:16 AM
    #131
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    +2, but like I said...I can stuff these tires in stock form
    batt700[QUOTED] and wi_taco like this.
  12. Feb 9, 2024 at 9:16 AM
    #132
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I don’t think you are taking the term BODY WORK seriously enough in his statement.
    wi_taco, 0xDEADBEEF and Strictlytoyz like this.
  13. Feb 9, 2024 at 9:18 AM
    #133
    batt700
    He is also running extended LCA's which makes sense. He could stuff 37's stock but it would rub a dub under real articulation, or maybe he relocated the cab mounts as well as destroyed the pinch weld with that body work.
  14. Feb 9, 2024 at 9:20 AM
    #134
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    @Strictlytoyz tubbed?
  15. Feb 9, 2024 at 9:20 AM
    #135
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    By stuff he means the tire doesnt touch anything from bump to strap, lock to lock. The proper way to clear tires.
  16. Feb 9, 2024 at 9:21 AM
    #136
    batt700
    Right, which would require destroying the pinch weld and butchering or relocating the cab mounts.
  17. Feb 9, 2024 at 9:22 AM
    #137
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Not destroying anything, simply cutting it out and putting some new steel in....
  18. Feb 9, 2024 at 9:22 AM
    #138
    batt700
    You mean like a DB lift does the front crossmember?
  19. Feb 9, 2024 at 9:24 AM
    #139
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Imma let y’all finish but have to say this thread is great entertainment. Really shows how little understanding some people have of suspension and actual off-road performance, and blatant ignorance of facts when it comes to justifying their doodoo donk derp lift. Please carry on!
    TS4x4, Bikinaz and Strictlytoyz like this.
  20. Feb 9, 2024 at 9:27 AM
    #140
    batt700
    If you are not on 35's or higher, don't talk about actual off-road performance. Also how are your CV axles handling that 2.5" horrific angle with that derp lift?
    A level dry dirt trail is not off-roading.
    Every serious long travel off-road setup runs 35's or higher.
