installed supercharger now engine light is on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggerein, Mar 28, 2012.
  1. Mar 28, 2012 at 2:34 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
    cold air intake, supercharged, lifted
    someone help!! ran good for a while now engine light is on and runs choppy, any suggestions would be appreciated
  2. Mar 28, 2012 at 2:35 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    If you installed it yourself did you take it to the dealer to get the ecu re-flashed ?
  3. Mar 28, 2012 at 2:36 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Or to be properly tuned and adjusted?
  4. Mar 28, 2012 at 2:38 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Or to be properly tuned?
  5. Mar 28, 2012 at 2:39 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
    yes i did.
  6. Mar 28, 2012 at 2:39 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
  7. Mar 28, 2012 at 2:41 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    Take it to a local parts retailer and have them scan the truck and print out the codes for you.
  8. Mar 28, 2012 at 2:46 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
    my buddy works at toyota dealership and we read the codes. its a lean code or misfire
  9. Mar 28, 2012 at 2:47 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
    just not sure what to do now....
  10. Mar 28, 2012 at 3:13 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    cant adjust or tune the stock ECU. when installed u get the dealer to upload a new calibration file. only way to tune these trucks is if u go aftermarket and it shouldnt be necessary with the stock S/C kit with calibration file
  11. Mar 28, 2012 at 3:14 PM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Check your PCV valve. I missed that when I installed my S/C and it lead to misfires and a lean code when it was running. It started running so bad I ended up having it towed the five miles to the dealer where they discovered it during the reflash. If you look in the directions I don't believe it mentions that you need to re-attach it and it is easy to forget when you are reconnecting the 1/2 dozen or so hoses to the S/C and air cleaner assembly.
  12. Mar 28, 2012 at 8:30 PM
    ggerein
    ggerein [OP] Member
    sask.
    08 s/c tacoma
    thanks man ill try that
