Installed tc uca today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ozmon420, Jul 1, 2009.
  1. Jul 1, 2009 at 5:04 PM
    ozmon420
    ozmon420 [OP] Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    IT RIDES SO MUCH BETTER NO MORE WANDERING WHEN DRIVING. WANTED TO KNOW IF I NEED TO GET ALIGNMENT NOW THAT I PUT THOSE UCA'S ON?[​IMG]
  2. Jul 1, 2009 at 5:06 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    yes you do...
  3. Jul 1, 2009 at 5:08 PM
    ozmon420
    miami, florida
    08 tacoma
    i guess i'll be getting the alignment done tommorow
  4. Jul 2, 2009 at 1:21 AM
    powerban
    powerban Well-Known Member
    SoCal
    09 PreRunner DC LB Sport
    Wait, the wandering on the freeways is due to the LCA's? Oh man, I need to buy me a set then. But just curious. If i get them, and get the alignment, wouldnt it still have the stock positive camber?
  5. Jul 2, 2009 at 6:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wandering is useually caused by loss of Caster when lifted. You can add caster with UCA's that have more Caster built into them, i.e., Total Chaos. This gets your Caster back in check, and reduces the wandering.
  6. Jul 2, 2009 at 6:10 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    what he said... :thumbsup:
  7. Jul 2, 2009 at 12:12 PM
    powerban
    SoCal
    what if its wandering and its stock suspension? no lift. 2009 prerunner longbed. Just to clarify, when driving at highway speeds, the truck likes to go to the left or right of the lane on its own. It doesnt always go to one direction. By the way, is the truck supposed to have positive camber from the factory?
  8. Jul 2, 2009 at 1:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Have it aligned. The Camber can be off either a little bit - or a little bit +, but it should be as close to 0* as possible.
  9. Jul 2, 2009 at 1:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    So I put the TC UCAs on the truck and now I've got a wicked tire squeal on higher speed/harder turns on concrete.
    I'm thinking an alignment and a tire pressure check- Is there anything else I should look at??
  10. Jul 2, 2009 at 2:14 PM
    ozmon420
    miami, florida
    08 tacoma
    just got my truck aligned today and its riding better but i might have to get the tires rebalaned cause im still getting a little shake on highway
  11. Jul 2, 2009 at 2:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe its your tires sliding?
  12. Jul 2, 2009 at 2:21 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I think you are taking turns too slow. Just go a bit faster and see if it corrects itself
  13. Jul 2, 2009 at 2:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    That's why I'm curious about the alignment-I say "high speed" but it's not like I'm taking corners at NASCAR speeds. No faster than I ever have before.
    Will the lift geometry just make it so I have to corner slower?? Or maybe the alignment is off in such a way that makes the tires scrub but still hold true straight tracking??
  14. Jul 2, 2009 at 2:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sounds like a bad alignment.
  15. Jul 2, 2009 at 3:37 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I had my alignment done 4 times since I owned the truck (14 months)
    all at the same shop that I got my tires , sears unfortunately. The 1st time was without any lift, just got new tires.2nd with only Icons in front and the rest with Deavers in the rear. Each time I went it drove like a different truck, sometimes the wandering and sometimes it pulled to the right. This last time I really hovered around the guy and I believe they finally got it right. Good thing I got the alignment "warranty" :)
    The specs that were listed on this site are good for your alignment. Learn them, live them. Don't let ol wrenchy McGee make your truck drive like a pig.
