Installed US OffRoad Winch Mount and Engo 12K
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smd3, Jan 9, 2016.
  1. Jan 9, 2016 at 2:19 PM
    smd3
    smd3 [OP] Well-Known Member
    US OffRoad has a really good deal on their winch mount and Engo 12k winch combo. Actually, they've got a good deal in a package with lights, too.
    The install is fairly straight-forward, although I found getting a lot of the plastic clips off to be difficult. Especially the small trim pieces under the headlights.
    One thing to note with the Engi 12k is that the solenoid box won't fit as designed on top of the winch. You could mount the box remotely, but I chose to rotate it 90 degrees, and all the way to one side. It barely fits, and required some extra trimming of the bumper, to clear the remote's plug in. (Hidden behind the plate anyway)
    I think I'll find a flip up bracket for the plate, even though the winch came with the wireless remote.
    The wireless remote didn't come with installation instructions, but it's fairly easy to figure out. I took the time to splice the wireless unit and the remote wires, so I could use either.
    I do have one warning...the wireless remote has some lag in both activating and decativating. So, when you press the button to move the winch it takes a second to start, and when you let go it takes a second to stop! (Be careful) The wireless remote itself is also very cheaply made, the on-off switch in particular seems like it could fall apart at any minute.
    DoorDing and Biscuits like this.
  2. Jan 9, 2016 at 4:52 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I like those winch mounts, sceptical about any "unknown " winch. They always seem to crap out at just the wrong moment.
    smd3[OP] likes this.
  3. Jan 9, 2016 at 5:50 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    smd3[OP] and sr5vic like this.
  4. Jan 9, 2016 at 5:51 PM
    smd3
    I did a little research, didn't find any horror stories and Engo fared pretty well in a comparison test from one of the off-road magazines.
    I forgot to mention above, I also used Relentless Fab's reinforcement plates when installing the winch mount.
    adanfon and sr5vic like this.
  5. Jan 9, 2016 at 6:34 PM
    smd3
  6. Jan 10, 2016 at 5:43 AM
    Gearheadesw
    Davenport Fl
    Interesting about winch. Tell how it performs, and how it lasts. Hopefully times have changed for the smaller winch brands. Electronics have come a long way in the last decade.
  7. Jan 10, 2016 at 12:58 PM
    smd3
    My budget just can't handle spending that much on a winch, especially when it probably won't see all that much use. I don't wheel a lot, but occasionally take trips where it will be good to have. I'll make sure ops-check it, and repack the grease periodically/as needed.
    When it comes down to it, pretty much everything is made in China. Even Warn, who assembles most products in the states, sources from overseas. The Engo and the Warn VR have the same 1yr/lifetime mechanical warranties. The Warn sure does look a lot nicer! Engo has a cheesy carbon fiber look on it; I'm glad it's hidden.
    I'll make sure to post if it ever fails me.
  8. Jan 10, 2016 at 3:49 PM
    Gearheadesw
    Davenport Fl
    All good points. Like you say, everyone outsources parts for profit.
  9. Jul 11, 2018 at 3:33 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Hello OP:
    Please post a picture or 2 of the solenoid box mounted in/on the truck. Did you build a mount plate?
  10. Jul 11, 2018 at 3:56 PM
    AaronNY
    AaronNY Well-Known Member
    Syracuse NY
    2011 MGM 4x4
    Bilstien 5100s Hella 500s and 700s
    Looks good, I'm jealous. Hope it serves ya well
  11. Jul 11, 2018 at 5:40 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    2yr old thread and OP hasn't logged in since Jan 2017.
    MadRiverTaco likes this.
  12. Jul 11, 2018 at 5:49 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    :facepalm:
