Installed used transmission, now it slips in reverse? Bad tranny or install problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bre, Apr 12, 2015.
  1. Apr 12, 2015 at 4:58 PM
    bre
    bre [OP] New Member
    1999 v6 prerunner 312,xxx miles
    Hi,
    I have a 1999 V6 Tacoma prerunner and I love my truck. A little over 300k miles the flywheel cracked and broke the torque converter and my transmission, so I bought a used transmission from a roll over truck that had 136k miles on it and had a local shop install it. It runs great, except today I tried to reverse up a steep incline and something went wrong. It will reverse at a low speed but when I press the gas to go faster It maintains the low speed and the engine revs up but it doesn't speed up passed a certain point. It made going up the hill difficult. I tried reversing on flat ground and the same thing happened when I tried to speed up. So, do you think the tranny is bad or not installed correctly? Any input is greatly appreciated!
  2. Apr 13, 2015 at 7:55 AM
    Indy
    Indy Master of all I survey.
    There's not much in the install process that would cause this. Used parts are always a risk.
  3. Apr 13, 2015 at 10:46 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I take it this is a automatic transmission?
  4. Apr 13, 2015 at 10:52 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would make sure correct amount of fluid is present. 1 qt low will make transmission slip.
  5. Jun 2, 2015 at 3:04 PM
    bre
    bre [OP] New Member
    Yes it is an automatic and it has enough fluid. Thanks
  6. Jun 2, 2015 at 3:58 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    did they replace the fluid and filter in the tranny when they installed it? it could just be BLOCKED FILTER AFTER BEING ROLLED AND EVERYTHING STIRRED UP LIKE THAT.
    damn cap lock keeps getting in the way, anyways
    all sorts of crap could have been suspended to get into the filter but upside down and still running mare have burned some clutches in it too.
    step one is drop the pan and check for debris or clogged filter, only after that will you be ready to ask the next question.
    I have seen places take salvaged trannies and just bolt em in, period, nothing done but check the fluid level when its running.
    also what year and model truck did the replacement tranny come from?
