Installing 1/4" spacer, do I need to seperat UCA from spindle?
Discussion in 'Suspension' started by larry2375, Jan 5, 2011.
  1. Jan 5, 2011 at 3:24 AM
    larry2375
    larry2375 [OP] Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    Can I just remove the wheel and the 3 top mounting bolts on the shock and install the 1/4" spacer? Or do I need to separate the UCA from the spindle? The spacer is going on top of 5100's set at 2.5"
    I want to install it myself and get the shop to align it. Thanks:)
  2. Jan 5, 2011 at 4:10 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Unbolt, push down, put spacer in, bolt back up, align.............
  3. Jan 5, 2011 at 4:49 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    There are two bolts holding the LCA to the lower balljoint housing. Removing those allows the LCA to drop down to full extension. You can see if that gives you enough wiggle room to lower the shock. This way you don't have to disturb the balljoints.
  4. Jun 7, 2011 at 8:22 AM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    Just checking to see how easy it was for you to do with only removing the wheel and the top plate bolts. I need to get a 1/4 spacer to correct the lean since it's much more noticeable after the lift. Thanks!
  5. Jun 7, 2011 at 11:24 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    I didn't disconnect my UCA when installing the 1/4" spacer. I did have to remove (loosen) the swaybar to get enough wiggle room. Don't know which one is more of a PITA to do.
