Installing 2012 stock radio in a pre-2012
Discussion in 'Audio & Video' started by Jerez, Apr 3, 2012.
  1. Feb 21, 2013 at 8:21 PM
    #181
    psychohamster
    psychohamster Active Member
    San Diego
    09 4x4 SR5
    IVD remote res coil-overs, Total Chaos UCAs, ARB Deluxe Bull-Bar, Warn 9.5XP, Luna Dual-Battery Controller
    Sounds like my 2009 jbl – xm inside the head unit and the factory and several 3rd party ipod adapters are a no-go.
    Wiring diagrams seem straightforward enough assuming the parts can be obtained. Thanks to everyone for all the work so far!
  2. Feb 21, 2013 at 8:31 PM
    #182
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    From what I've gathered, the Toyota iPod adapter won't work either. Thats why I'm interested in this idea. As I'm pretty sure the JBL system is the same. But the headunit should be an easy swap since most of that stuff already goes through it (bluetooth).
  3. Mar 4, 2013 at 7:30 AM
    #183
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    I've posted this in another thread, but since this one is so active, and I'm trying for as much exposure as possible, please excuse me -
    I'm looking for the touch screen head unit for the 2013 (and apparently, 2012) Taco...(86140-04080); mine has a cracked touchscreen. PM me if you have changed yours out and want to get rid of it.
    Thanks.
    GOT ONE - Thanks, all who responded!
  4. Apr 26, 2013 at 10:16 PM
    #184
    joczr2
    joczr2 Member
    2012 prerunner
    Where do you get these pdf's from...I would love to be able to look up stuff when I need to.
  5. May 21, 2013 at 1:37 PM
    #185
    dibble9012
    dibble9012 Well-Known Member
    Google "Toyota tis"
  6. Jun 14, 2013 at 2:47 PM
    #186
    benright
    benright Well-Known Member
    Broghan
    Layton, UT
    11, 4x4, Dbl Cab, TRD Sport
    Velocity 3" spacers, Total Chaos UCA's, 18X9 XD Monsters, 275/65/18 Nitto Ridge Grapplers, Toytec AAL.
    I've got a 2011 w/ JBL and have converted to the 2013 entune w/ nav. The only thing that isn't working right now is the microphone. I think this is because of pin 6 on R15. Has anyone who has done this figured out what to splice into?
    Edit:
    Pin 6 for R15 can pull off of Pin 19 (mic voice signal) from the same harness. Hooked mine up and everything is now functional.
    SpeedwayTaco160 likes this.
  7. Jun 16, 2013 at 9:39 PM
    #187
    Beefyferret
    Beefyferret New Member
    Alaska
    2010 4x4 Double Cab TRD OR
    BHLM, Garage door opener between map lights, 2012 Entune Stereo Head Unit, Undercover Tonneau Cover and Tool Box
    Benright,
    I just installed a 2012 into my 2010 w/JBL. My nav isn't working though. Did you install a new antenna or just use the Sat radio antenna? Also, did you install the USB port yet?
  8. Jun 16, 2013 at 10:03 PM
    #188
    Jerez
    Jerez [OP] SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    so i plan to update this thread in the next month...been busy where i just stopped working on this :pout:
    ps. picked up a 2012 mirror with home link that i will be installed on my truck with the back up cam...
  9. Jun 16, 2013 at 10:11 PM
    #189
    galveznano
    galveznano Active Member
    Leo
    Santa ana
    black prerunner
    procomp 2in lift, secondary air filter delete
    I would greatly apreciate if you could send me a pic of what color cable pin u moved to what location to get the mic operational
  10. Jun 20, 2013 at 4:00 PM
    #190
    benright
    Broghan
    Layton, UT
    I don't think the satelite antenna fits for the nav. I bought an aftermarket antenna but it sucks:it's not sensitive enough. I'm gonna try to pick up a used OEM antenna.
    I don't plan on doing the USB right now because I don't know where to find parts for it.
    EDIT:
    I was wrong about the aftermarket antenna, it works fine. I didn't have the vehicle speed signal wire connected. Without that the GPS will not work correctly. The after market ($20) antenna from ebay works just as good as the OEM ($90) toyota antenna.
    If you're converting a JBL system and are searching for the vehicle speed signal wire, you can find it near the fuse box. It's a purple and white wire in pin #5 of the black wiring harness (There is only one black harness down there). If someone needs pictures let me know.
  11. Jun 20, 2013 at 4:16 PM
    #191
    benright
    Broghan
    Layton, UT
    Galveznano,
    With the way mine is wired I don't think a picture will help. I used the write up done by dibble (link is below) for the wiring. However he left out what to do with Pin 6 from the wiring harness (R15).
    I spliced into the wire from Pin 19 (mic voice signal) on the same harness and connected it to pin 6. Now the microphone works. If you familiarize yourself with the dibble's write up I think this should make sense. If not let me know and I can take a picture of it.
    http://www.tacomaworld.com/forum/au...ing-2012-entune-nav-into-pre-2012-tacoma.html
  12. Jun 20, 2013 at 7:22 PM
    #192
    galveznano
    Leo
    Santa ana
    black prerunner
    Thanks for the heads up benright it looks like jerez has this mod in a bag, im gonna have to order r15 from the stealer And once i have it ill be hitting jerez up to help out with the pin locations if i cant figure em out with all the cool info and pics i found here, so far i just need to get my mic signal working and my steering controls, no going back now i just sold the oem headunit
  13. Jun 22, 2013 at 5:18 PM
    #193
    Beefyferret
    Alaska
    So, I have the Sat antenna plugged in and it works for Satellite radio, but the nav does not work. What aftermarket antenna did you use and how did you plug it into the head unit?
  14. Jun 22, 2013 at 5:50 PM
    #194
    skygear
    skygear                    
    theres no GPS in alaska :spy:
  15. Jun 22, 2013 at 10:10 PM
    #195
    benright
    Broghan
    Layton, UT
    I think you misunderstood me. The navigation antenna plugs into a different slot (in the bottom left if you're looking at the back of the unit). You can buy the antennas on eBay.
  16. Jun 23, 2013 at 9:47 AM
    #196
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    where are you guys finding this head unit? and how much are you paying? i have a 2012 and i'd love to add in the touchscreen
  17. Jun 23, 2013 at 2:08 PM
    #197
    benright
    Broghan
    Layton, UT
    I got mine from user Nat2012. He seems to have a quite a few of them. He sent me a 2013 entune w/ nav for $300. It was brand new/never used, sat radio works too.
    I'm no detective but I noticed he lives in San Antonio; Toyota has a plant that assembles tacos/tundras in San Antonio. Come to your own conclusions...
  18. Jun 26, 2013 at 1:03 PM
    #198
    blktaco58
    blktaco58 Well-Known Member
    Hawaii
    2019 off road dc
    Can someone explain to me how to get the bluetooth mic working.
    Basically I have top buy a R15 harness and wire it.....its the wiring part I'm a little lost. Do I have to wire all those pins to get the bluetooth calling/microphone to work....
    note- i don't have steering controls for the bluetooth, so I have no wiring for that.....
  19. Jul 8, 2013 at 6:09 PM
    #199
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    Rod did you get the USB to work on the 2013 touchscreen?
    I only ask cuz I didn't see an update. It looks like your picture here could be labeled incorrectly. http://www.tacomaworld.com/forum/au...012-stock-radio-pre-2012-a-7.html#post6019233
    Are you sure that unit has satellite? I believe that port is the USB port. I think the adapter that goes with it is this part PT546-00120-US I found it here. http://www.toyotanation.com/forum/1...5-new-toyota-panasonic-86120-0r130-radio.html
    I don't mean to question but from what I have seen all the satellite ports are a blue connector and slightly dif. I am going to go to the dealer and see if I can pick up the part plus I want to see what is on the other side for a connector. Hopefully something to connect to 86190-0C020
    Just a thought :notsure:
  20. Jul 8, 2013 at 7:21 PM
    #200
    Jerez
    Rod
    Ontario Ranch
    Estock
    I ordered that same part like 5 weeks ago an nothing.
    I did label it wrong. It was a quick labeling months ago without any short of diagram showin me what it was. I too think the gray plug is the usb
